Problems optimizing (quantization) dinov2 - ONNX to HEF
I’m deploying a custom-trained DINOv2 model on a Hailo-8L with a Raspberry Pi 5 using DFC’s notebooks as base tutorials. The DINOv2 model was fine-tuned as a classifier with an additional top layer.
To convert the ONNX DINOv2 model into a HEF format, I’ve broken the process into three steps:
  1. ONNX to Hailo-Compatible Representation (HAR)
  2. Quantization to 8-bit
  3. Compiling the network into a HEF model
1. ONNX to HAR Conversion
I successfully transformed the ONNX DINOv2 model into a HAR. Here’s the key configuration I used:
    onnx_path,
    onnx_model_name,
    start_node_names=["x.1"],
    end_node_names=["1144"],
    net_input_shapes={"x.1": [1, 3, 224, 224]},
Node names and shapes were extracted using Netron. Here’s the output from Hailo Visualizer.
2. Quantization Step
I encountered errors in the quantization process but first, let me walk through the steps I took before the issue arose.
Preprocessing & Postprocessing Functions:
# Pre processing (prepare the input images)
def preproc(image, output_height=224, output_width=224, resize_side=256, normalize=False):
    """imagenet-standard: aspect-preserving resize to 256px smaller-side, then central-crop to 224px"""
    with eager_mode():
        h, w = image.shape[0], image.shape[1]
        scale = tf.cond(tf.less(h, w), lambda: resize_side / h, lambda: resize_side / w)
        resized_image = tf.compat.v1.image.resize_bilinear(tf.expand_dims(image, 0), [int(h * scale), int(w * scale)])
        cropped_image = tf.compat.v1.image.resize_with_crop_or_pad(resized_image, output_height, output_width)
        if normalize:
            # Default normalization parameters for ImageNet
            cropped_image = (cropped_image - [123.675, 116.28, 103.53]) / [58.395, 57.12, 57.375]
        return tf.squeeze(cropped_image)
# Post processing (what to do with the model's outputs)
def _get_imagenet_labels(json_path="../data/imagenet_names.json"):
    imagenet_names = json.load(open(json_path))
    imagenet_names = [imagenet_names[str(i)] for i in range(1001)]
    return imagenet_names[1:]
#imagenet_labels = _get_imagenet_labels()
imagenet_labels = ['apple', 'banana', 'drink_carton', 'metal_can', 'mixed', 'organic', 'paper', 'paper_coffee_cup', 'plastic_bag', 'plastic_bottle', 'pmd', 'rest']
print(f'Labels of dataset: {imagenet_labels}')
def postproc(results):
    labels = []
    scores = []
    for result in results:
        top_ind = np.argmax(result)
        cur_label = imagenet_labels[top_ind]
        cur_score = 100 * result[top_ind]
        labels.append(cur_label)
        scores.append(cur_score)
    return scores, labels
# Visualization
def mynorm(data):
    return (data - np.min(data)) / (np.max(data) - np.min(data))
def visualize_results(
    images,
    first_scores,
    first_labels,
    second_scores=None,
    second_labels=None,
    first_title="Full Precision",
    second_title="Other",
    # Deal with input arguments
    assert (second_scores is None and second_labels is None) or (
        second_scores is not None and second_labels is not None
    ), "second_scores and second_labels must both be supplied, or both not be supplied"
    assert len(images) == len(first_scores) == len(first_labels), "lengths of inputs must be equal"
    show_only_first = second_scores is None
    if not show_only_first:
        assert len(images) == len(second_scores) == len(second_labels), "lengths of inputs must be equal"
    # Display
    for img_idx in range(len(images)):
        plt.figure()
        plt.imshow(mynorm(images[img_idx]))
            plt.title(
                f"{first_title}: top-1 class is {first_labels[img_idx]}. Confidence is {first_scores[img_idx]:.2f}%,\n"
                f"{second_title}: top-1 class is {second_labels[img_idx]}. Confidence is {second_scores[img_idx]:.2f}%",
        else:
            plt.title(
                f"{first_title}: top-1 class is {first_labels[img_idx]}. Confidence is {first_scores[img_idx]:.2f}%",
Loading the Har model:
model_name = "dinov2"
hailo_model_har_name = f"{model_name}_hailo_model.har"
assert os.path.isfile(hailo_model_har_name), "Please provide valid path for HAR file"
# By default it uses the hw_arch that is saved on the HAR. For overriding, use the hw_arch flag.
Loading the Dataset:
images_path = '/home/jetshu/Documents/PLAEX/code/PLAEXDatabaseManager/GranularDataset/val' #"../data"
images_list = [img_name for img_name in os.listdir(images_path) if os.path.splitext(img_name)[1] == ".jpg"]
# Create an un-normalized dataset for visualization
image_dataset = np.zeros((len(images_list), 224, 224, 3))
# Create a normalized dataset to feed into the Native emulator
image_dataset_normalized = np.zeros((len(images_list), 224, 224, 3))
for idx, img_name in enumerate(sorted(images_list)):
    img = np.array(Image.open(os.path.join(images_path, img_name)))
    img_preproc = preproc(img)
    image_dataset[idx, :, :, :] = img_preproc.numpy()
    img_preproc_norm = preproc(img, normalize=True)
    image_dataset_normalized[idx, :, :, :] = img_preproc_norm.numpy()
Then is evaluated with Native Emulator and everything is fine for the moment. I got decent accuracy metrics:
# Notice that we use the normalized images, because normalization is not in the model
with runner.infer_context(InferenceContext.SDK_NATIVE) as ctx:
    native_res = runner.infer(ctx, image_dataset_normalized[:IMAGES_TO_VISUALIZE, :, :, :])
#print(native_res)
native_scores, native_labels = postproc(native_res)
visualize_results(image_dataset[:IMAGES_TO_VISUALIZE, :, :, :], native_scores, native_labels)
Applying modifications as adding Normalization layer at the end:
model_script_lines = [
    # Add normalization layer with mean [123.675, 116.28, 103.53] and std [58.395, 57.12, 57.375])
    "test_normalization1 = normalization([123.675, 116.28, 103.53], [58.395, 57.12, 57.375])\n",
    # For multiple input nodes:
    # {normalization_layer_name_1} = normalization([list of means per channel], [list of stds per channel], {input_layer_name_1_from_hn})\n',
    # {normalization_layer_name_2} = normalization([list of means per channel], [list of stds per channel], {input_layer_name_2_from_hn})\n',
# Load the model script to ClientRunner so it will be considered on optimization
runner.load_model_script("".join(model_script_lines))
runner.optimize_full_precision()
Running the SDK_FP_Optimized produced reasonable accuracy metrics:
# Notice that we use the original images, because normalization is IN the model
with runner.infer_context(InferenceContext.SDK_FP_OPTIMIZED) as ctx:
    modified_res = runner.infer(ctx, image_dataset[:IMAGES_TO_VISUALIZE, :, :, :])
modified_scores, modified_labels = postproc(modified_res)
visualize_results(
    native_scores,
    native_labels,
    modified_scores,
    modified_labels,
    second_title="FP Modified",
However, I encountered an error during the optimization process with the following code:
# The original images are being used, just as the input to the SDK_FP_OPTIMIZED emulator
calib_dataset = image_dataset
# For calling Optimize, use the short version: runner.optimize(calib_dataset)
# A more general approach is being used here that works also with multiple input nodes.
# The calibration dataset could also be a dictionary with the format:
# {input_layer_name_1_from_hn: layer_1_calib_dataset, input_layer_name_2_from_hn: layer_2_calib_dataset}
hn_layers = runner.get_hn_dict()["layers"]
print("Input layers are: ")
print([layer for layer in hn_layers if hn_layers[layer]["type"] == "input_layer"])  # See available input layer names
calib_dataset_dict = {"dinov2/input_layer1": calib_dataset}  # In our case there is only one input layer
runner.optimize(calib_dataset_dict)
Here’s the log output:
Input layers are:
['dinov2/input_layer1']
[warning] Reducing optimization level to 1 (the accuracy won't be optimized and compression won't be used) because there's less data than the recommended amount (1024)
2024-10-20 17:32:09.390079: E tensorflow/compiler/xla/stream_executor/cuda/cuda_driver.cc:1279] could not retrieve CUDA device count: CUDA_ERROR_NOT_INITIALIZED: initialization error
2024-10-20 17:32:09.554167: E tensorflow/compiler/xla/stream_executor/cuda/cuda_driver.cc:1279] could not retrieve CUDA device count: CUDA_ERROR_NOT_INITIALIZED: initialization error
[info] Mixed Precision is done (completion time is 00:00:02.23)
[info] Starting LayerNorm Decomposition
Calibration:   0%|          | 0/64 [00:00<?, ?entries/s]2024-10-20 17:32:52.778889: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype int32
	 [[{{node Placeholder/_0}}]]
2024-10-20 17:32:52.805111: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  12%|█▎        | 8/64 [02:24<16:48, 18.00s/entries]2024-10-20 17:35:10.773695: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  25%|██▌       | 16/64 [02:24<05:56,  7.43s/entries]2024-10-20 17:35:11.065021: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  38%|███▊      | 24/64 [02:24<02:42,  4.06s/entries]2024-10-20 17:35:11.353900: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  50%|█████     | 32/64 [02:24<01:19,  2.47s/entries]2024-10-20 17:35:11.652946: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  62%|██████▎   | 40/64 [02:25<00:38,  1.59s/entries]2024-10-20 17:35:11.947633: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  75%|███████▌  | 48/64 [02:25<00:17,  1.06s/entries]2024-10-20 17:35:12.239267: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  88%|████████▊ | 56/64 [02:25<00:05,  1.37entries/s]2024-10-20 17:35:12.529566: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration: 100%|██████████| 64/64 [02:26<00:00,  2.28s/entries]
[info] LayerNorm Decomposition is done (completion time is 00:02:54.00)
Calibration:   0%|          | 0/64 [00:00<?, ?entries/s]2024-10-20 17:36:06.437562: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype int32
2024-10-20 17:36:06.458755: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  12%|█▎        | 8/64 [04:16<29:50, 31.97s/entries]2024-10-20 17:39:47.898910: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  25%|██▌       | 16/64 [04:17<10:39, 13.32s/entries]2024-10-20 17:39:48.773738: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  38%|███▊      | 24/64 [04:18<04:51,  7.29s/entries]2024-10-20 17:39:49.582326: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  50%|█████     | 32/64 [04:19<02:22,  4.45s/entries]2024-10-20 17:39:50.377881: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  62%|██████▎   | 40/64 [04:20<01:09,  2.88s/entries]2024-10-20 17:39:51.189714: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  75%|███████▌  | 48/64 [04:21<00:30,  1.94s/entries]2024-10-20 17:39:51.984864: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration:  88%|████████▊ | 56/64 [04:21<00:10,  1.34s/entries]2024-10-20 17:39:52.779747: I tensorflow/core/common_runtime/executor.cc:1197] [/device:CPU:0] (DEBUG INFO) Executor start aborting (this does not indicate an error and you can ignore this message): INVALID_ARGUMENT: You must feed a value for placeholder tensor 'Placeholder/_0' with dtype float and shape [8,224,224,3]
Calibration: 100%|██████████| 64/64 [04:22<00:00,  4.11s/entries]
[info] Statistics Collector is done (completion time is 00:04:41.08)
The error traceback is as follows:
ValueError                                Traceback (most recent call last)
Cell In[9], line 11
      9 print([layer for layer in hn_layers if hn_layers[layer]["type"] == "input_layer"])  # See available input layer names
     10 calib_dataset_dict = {"dinov2/input_layer1": calib_dataset}  # In our case there is only one input layer
---> 11 runner.optimize(calib_dataset_dict)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_sdk_common/states/states.py:16, in allowed_states.<locals>.wrap.<locals>.wrapped_func(self, *args, **kwargs)
     13     raise InvalidStateException(
     14         f"The execution of {func.__name__} is not available under the state: {self._state.value}",
     15     )
---> 16 return func(self, *args, **kwargs)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:2093, in ClientRunner.optimize(self, calib_data, data_type, work_dir)
   2061 @allowed_states(States.HAILO_MODEL, States.FP_OPTIMIZED_MODEL)
   2062 def optimize(self, calib_data, data_type=CalibrationDataType.auto, work_dir=None):
   2063     """
   2064     Apply optimizations to the model:
   2065
   2091
   2092     """
-> 2093     self._optimize(calib_data, data_type=data_type, work_dir=work_dir)
     15     )
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:1935, in ClientRunner._optimize(self, calib_data, data_type, work_dir)
   1933 if self._state == States.HAILO_MODEL:
   1934     self._optimize_full_precision(calib_data=calib_data, data_type=data_type)
-> 1935 self._sdk_backend.full_quantization(calib_data, data_type=data_type, work_dir=work_dir)
   1936 self._state = States.QUANTIZED_MODEL
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1045, in SDKBackendQuantization.full_quantization(self, data, data_type, work_dir, force_results_by_layer)
   1043 self.pre_quantization_structural()
   1044 params_pre_quantization = copy.deepcopy(self.get_params_pre_quantization())
-> 1045 self._full_acceleras_run(self.calibration_data, data_type)
   1046 self._logger.verbose("Core and post Quantization is done with Acceleras")
   1047 self._finalize_quantization()
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1229, in SDKBackendQuantization._full_acceleras_run(self, data, data_type)
   1224     else:
   1225         # the compression level and the optimization level are not set to the recommended values
   1226         self._logger.info(
   1227             f"To obtain best performance for models with number of parameters larger than {self.hw_arch.HAILO15_LARGE_MODEL_PARAMS_TH}, it is recommended to use optimization level and compression level {RECOMMENDED_OPTM_LEVEL}."
   1228         )
-> 1229 optimization_flow.run()
   1230 fp_after_optimization = optimization_flow.get_acceleras_params()
   1231 self.save_and_load_params_hailo_optimized(fp_after_optimization)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py:306, in flow_control_method.<locals>.wrapper(self, *args, **kwargs)
    302             setattr(self, attr_name, method_wrapper(method, sup))
    304 try:
    305     # Execute the original run function
--> 306     return func(self, *args, **kwargs)
    308 finally:
    309     # Restore original methods after run execution
    310     self._call_history = sup.export() if sup.current_checkpoint else None
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py:326, in OptimizationFlow.run(self, memento, run_until)
    324 for ind, step_func in enumerate(step_funcs):
    325     self._step_index = ind
--> 326     step_func()
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py:250, in flow_control_method.<locals>.wrapper.<locals>.method_wrapper.<locals>.wrapped(*args, **kwargs)
    248 if sup.state == SupervisorState.RUNNING:
    249     with sup.visit_node(method_name):
--> 250         result = method(*args, **kwargs)
    251         if method_name == run_until:
    252             sup.state = SupervisorState.DISABLED
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py:124, in subprocess_wrapper.<locals>.decorator.<locals>.parent_wrapper(self, *args, **kwargs)
    122 self.dist_info = dist_info
    123 self.build_model()
--> 124 func(self, *args, **kwargs)
    126 # This flag should be present in Develop
    127 if force_rebuild:
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py:345, in OptimizationFlow.step1(self)
    343 self._update_fp_data()
    344 self.pre_quantization_optimization()
--> 345 self.core_quantization()
    346 self._update_quantize_data()
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py:402, in OptimizationFlow.core_quantization(self)
    400 self._force_preact_stats()
    401 self._fix_zp_comp_encoding()
--> 402 self._matmul_equalization()
    403 self._create_hw_params()
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py:582, in OptimizationFlow._matmul_equalization(self)
    580 def _matmul_equalization(self):
    581     algo = MatmulEqualization(self.model, self._parsed_config, logging.INFO, self._logger)
--> 582     algo.run()
    583     self._finalize_algorithm(algo)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py:50, in OptimizationAlgorithm.run(self)
     48 def run(self):
     49     self.finalize_config()
---> 50     return super().run()
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py:150, in AlgorithmBase.run(self, memento)
    148         self.restore(memento)
    149     start_time = time.time()
--> 150     self._run_int()
    151     self._results.status = AlgorithmStatus.SUCCESSFULLY_DONE
    152 except KeyboardInterrupt:
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/matmul_equalization/matmul_equalization.py:123, in MatmulEqualization._run_int(self)
    117     self._logger.info(
    118         f"{self._name}: Could not be apply because it "
    119         f"has an unsuported layer {e.layer_name} on its inputs flow"
    120     )
    121     return
--> 123 self.equalize_input_paths(normal_subflow, transpose_subflow, layer)
    124 self.matmul_propagation(block)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/matmul_equalization/matmul_equalization.py:154, in MatmulEqualization.equalize_input_paths(self, normal_flow, transpose_flow, layer)
    151 factors = np.ones(layer.groups, dtype=np.float32)
    153 for _ in range(2):
--> 154     set_scales_forward(self._model, normal_flow, layer.groups, factors)
    155     set_scales_forward(self._model, transpose_flow, layer.groups, factors, transpose=True)
    157     fix_scales_reduce_sum(self._model, transpose_flow, layer.groups, layer, self._logger)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/matmul_equalization/matmul_equalization.py:332, in set_scales_forward(model, flow, groups, factors, transpose)
    330 in_node = flow.get_sources()[0]
    331 in_layer = model.layers[in_node]
--> 332 scales, zp_points = get_scales_output(in_layer, groups, factors, transpose)
    333 in_layer.set_output_scale(scales, 0)
    334 in_layer.set_output_zero_point(zp_points, 0)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/matmul_equalization/matmul_equalization.py:359, in get_scales_output(layer, groups, factors, transpose)
    357     else:
    358         candidate_zp, candidate_scale, _ = limvals_to_zp_scale(layer.get_output_limvals()[0], lossy_element)
--> 359         scales, zp = find_the_best_zp(
    360             xmin=min_vals,
    361             xmax=max_vals,
    362             bins=bins,
    363             start_scales=np.repeat(candidate_scale, max_vals.size),
    364             start_zp=candidate_zp,
    365         )
    367 else:
    368     scales = np.array(
    369         [
    370             scale
    374         ]
    375     )
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/hailo_model_optimization/algorithms/matmul_equalization/optimal_zp_finder.py:237, in find_the_best_zp(xmin, xmax, bins, start_scales, start_zp)
    229 cons = [
    230     {"type": "ineq", "fun": constraint1},
    231     {"type": "ineq", "fun": constraint2},
    232     {"type": "ineq", "fun": constraint3},
    233     {"type": "ineq", "fun": constraint4},
    234 ]
    236 # Call minimize
--> 237 result = minimize(objective, x0, method="SLSQP", constraints=cons)
    238 if result.success:
    239     zp = result.x[-1]  # Last element is zp
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/scipy/optimize/_minimize.py:722, in minimize(fun, x0, args, method, jac, hess, hessp, bounds, constraints, tol, callback, options)
    719     res = _minimize_cobyla(fun, x0, args, constraints, callback=callback,
    720                            bounds=bounds, **options)
    721 elif meth == 'slsqp':
--> 722     res = _minimize_slsqp(fun, x0, args, jac, bounds,
    723                           constraints, callback=callback, **options)
    724 elif meth == 'trust-constr':
    725     res = _minimize_trustregion_constr(fun, x0, args, jac, hess, hessp,
    726                                        bounds, constraints,
    727                                        callback=callback, **options)
File ~/Documents/PLAEX/code/Hailo/hailo_env/lib/python3.10/site-packages/scipy/optimize/_slsqp_py.py:431, in _minimize_slsqp(func, x0, args, jac, bounds, constraints, maxiter, ftol, iprint, disp, eps, callback, finite_diff_rel_step, **unknown_options)
    427 a = _eval_con_normals(x, cons, la, n, m, meq, mieq)
    429 while 1:
    430     # Call SLSQP
--> 431     slsqp(m, meq, x, xl, xu, fx, c, g, a, acc, majiter, mode, w, jw,
    432           alpha, f0, gs, h1, h2, h3, h4, t, t0, tol,
    433           iexact, incons, ireset, itermx, line,
    434           n1, n2, n3)
    436     if mode == 1:  # objective and constraint evaluation required
    437         fx = wrapped_fun(x)
ValueError: failed to initialize intent(inout) array -- expected elsize=8 but got 4
Speficially this line of error:
What I do so far is
  • Check my dataset if its uploaded and visualized correctly (Pass)
  • Change the batch of the dataset (different batches 1, 4 or 8 got the same error)
  • Change the data type of the dataset (Float32 to Float34 and vice versa, got the same error)
I know from this previous post that DinoV2 is not currently supported, but could you recommend me some advice to go on? Or should I wait until DinoV2 is officially supported?
Hi @daffer.queque,
We encountered a similar error in one of our Model Zoo models. The R&D are currently looking into this. I’ll update once I have an answer.
Regards,
Hi @Omer,
Thank you for the update. I’ll stay tuned for any further information from the R&D team.
Best,
Hi @Omer
are there any updates to solving this issue?
Hi @abdullayev1705,
Still no update. The R&D are still looking into it to see if there’s a quick workaround to fix this. If not, the fix will be available in the next release at January 2025. I’ll update once I have one.
Regards,
Hi @abdullayev1705,
We found a fix for our MZ model - if you downgrade the scipy version to 1.9.3 (pip install scipy==1.9.3) in your virtual env, it would solve this.
With that saying, since your model is not one that is in our MZ, I cannot grantee that the pipeline would work for you fully.
Regards,
Hi @Omer,
I am working on deploying the DepthAnythingV2 model on the Hailo-8 device using the Suite 2024_10 Docker environment. The container is running, but the system couldn’t find the cuDNN libraries. I manually installed all the necessary libraries, but I still face issues with the CUDA runtime.I decided to process with CPU and go on
Please verify at which stage we might encounter unsupported layers with the provided SDK APIs. The model was successfully parsed, and quantization was completed, but the compilation failed at the final stage with the following error:
BackendAllocatorException: Compilation failed: No valid partition found.
I would greatly appreciate your assistance. Could you provide more detailed explanations and suggestions for successfully compiling modern networks such as ViT and DINOV2 using the provided DFC?
I am looking forward to your prompt response. Thank you!
