Custom ONNX model optimization fails with Exception
I’m getting an exception error in the “optimization” phase of converting an ONNX model to HEF.
Specifically, the error is this one:
Call arguments received by layer 'lat_model' (type LATModel):
      • inputs=tf.Tensor(shape=(1, 768, 768, 3), dtype=float32)
Full traceback here:
Traceback
[info] Fine Tune is done (completion time is 03:53:06.54)
Full Quant Analysis:   0%|        | 0/16 [00:00<?, ?iterations/s]Traceback (most recent call last):
  File "/usr/local/bin/hailo", line 8, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/tools/cmd_utils/main.py", line 111, in main
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py", line 68, in run
    return self._run(argv)
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py", line 89, in _run
    return args.func(args)
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/tools/optimize_cli.py", line 120, in run
    self._runner.optimize(dataset, work_dir=args.work_dir)
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/runner/client_runner.py", line 2093, in optimize
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/runner/client_runner.py", line 1935, in _optimize
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1045, in full_quantization
  File "/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1229, in _full_acceleras_run
    optimization_flow.run()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/orchestator.py", line 306, in wrapper
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py", line 316, in run
    step_func()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/orchestator.py", line 250, in wrapped
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/subprocess_wrapper.py", line 111, in parent_wrapper
hailo_model_optimization.acceleras.utils.acceleras_exceptions.SubprocessTracebackFailure: Subprocess failed with traceback
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/subprocess_wrapper.py", line 73, in child_wrapper
    func(self, *args, **kwargs)
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py", line 347, in step3
    self.finalize_optimization()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py", line 405, in finalize_optimization
    self._noise_analysis()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py", line 585, in _noise_analysis
    algo.run()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/optimization_algorithm.py", line 50, in run
    return super().run()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/algorithm_base.py", line 151, in run
    self._run_int()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py", line 83, in _run_int
    self.analyze_full_quant_net()
  File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py", line 197, in analyze_full_quant_net
    lat_model.predict_on_batch(inputs)
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 2603, in predict_on_batch
    outputs = self.predict_function(iterator)
  File "/usr/local/lib/python3.8/dist-packages/tensorflow/python/util/traceback_utils.py", line 153, in error_handler
  File "/tmp/__autograph_generated_file2kyb_0w6.py", line 15, in tf__predict_function
    retval_ = ag__.converted_call(ag__.ld(step_function), (ag__.ld(self), ag__.ld(iterator)), None, fscope)
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 2155, in step_function
    outputs = model.distribute_strategy.run(run_step, args=(data,))
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 2143, in run_step
    outputs = model.predict_step(data)
  File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 2111, in predict_step
    return self(x, training=False)
  File "/usr/local/lib/python3.8/dist-packages/keras/utils/traceback_utils.py", line 70, in error_handler
  File "/tmp/__autograph_generated_file5np1nct9.py", line 188, in tf__call
    ag__.for_stmt(ag__.converted_call(ag__.ld(self)._model.flow.toposort, (), None, fscope), None, loop_body_5, get_state_9, set_state_9, (), {'iterate_names': 'lname'})
  File "/tmp/__autograph_generated_file5np1nct9.py", line 167, in loop_body_5
    ag__.if_stmt(ag__.not_(continue__1), if_body_3, else_body_3, get_state_8, set_state_8, (), 0)
  File "/tmp/__autograph_generated_file5np1nct9.py", line 94, in if_body_3
    n_ancestors = ag__.converted_call(ag__.ld(self)._native_model.flow.ancestors, (ag__.ld(lname),), None, fscope)
  File "/tmp/__autograph_generated_filevy4hyjj8.py", line 12, in tf__ancestors
    retval_ = ag__.converted_call(ag__.ld(nx).ancestors, (ag__.ld(self), ag__.ld(source)), None, fscope)
  File "/tmp/__autograph_generated_file_8xa5mvx.py", line 24, in tf__ancestors
    anc = {ag__.ld(n) for (n, d) in ag__.converted_call(ag__.converted_call(ag__.ld(nx).shortest_path_length, (ag__.ld(G),), dict(target=ag__.ld(source)), fscope).items, (), None, fscope)}
  File "/tmp/__autograph_generated_filendi24xs0.py", line 233, in tf__shortest_path_length
    ag__.if_stmt((ag__.ld(source) is None), if_body_12, else_body_12, get_state_12, set_state_12, ('paths', 'G'), 1)
  File "/tmp/__autograph_generated_filendi24xs0.py", line 137, in if_body_12
    ag__.if_stmt((ag__.ld(target) is None), if_body_6, else_body_6, get_state_6, set_state_6, ('paths', 'G'), 1)
  File "/tmp/__autograph_generated_filendi24xs0.py", line 96, in else_body_6
    ag__.if_stmt(ag__.converted_call(ag__.ld(G).is_directed, (), None, fscope), if_body_3, else_body_3, get_state_3, set_state_3, ('G',), 1)
  File "/tmp/__autograph_generated_filendi24xs0.py", line 91, in if_body_3
    G = ag__.converted_call(ag__.ld(G).reverse, (), dict(copy=False), fscope)
  File "/tmp/__autograph_generated_file07hvlrb6.py", line 41, in tf__reverse
    ag__.if_stmt(ag__.ld(copy), if_body, else_body, get_state, set_state, ('do_return', 'retval_'), 2)
  File "/tmp/__autograph_generated_file07hvlrb6.py", line 36, in else_body
    retval_ = ag__.converted_call(ag__.ld(nx).graphviews.reverse_view, (ag__.ld(self),), None, fscope)
TypeError: in user code:
    File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 2169, in predict_function  *
        return step_function(self, iterator)
    File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 2155, in step_function  **
    File "/usr/local/lib/python3.8/dist-packages/keras/engine/training.py", line 2143, in run_step  **
    TypeError: Exception encountered when calling layer 'lat_model' (type LATModel).
    in user code:
        File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/lat_utils/lat_model.py", line 340, in call  *
            n_ancestors = self._native_model.flow.ancestors(lname)
        File "/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/acceleras/model/hailo_model/model_flow.py", line 31, in ancestors  *
            return nx.ancestors(self, source)
        File "/usr/local/lib/python3.8/dist-packages/networkx/algorithms/dag.py", line 74, in ancestors  *
            anc = {n for n, d in nx.shortest_path_length(G, target=source).items()}
        File "/usr/local/lib/python3.8/dist-packages/networkx/algorithms/shortest_paths/generic.py", line 273, in shortest_path_length  *
            G = G.reverse(copy=False)
        File "/usr/local/lib/python3.8/dist-packages/networkx/classes/digraph.py", line 1221, in reverse  *
            return nx.graphviews.reverse_view(self)
        TypeError: tf__func() missing 1 required keyword-only argument: '__wrapper'
The model I’m trying to convert is a UNET model that is trained with pytorch and then converted to ONNX. I also use this model for inference directly or converted to TensorRT with no problem.
This is the ‘unet.dot’ created by hailo visualizer after the conversion:
strict digraph "" {
	input_layer1 -> "conv1 (3x3/1) (3->64) +Relu"	[label="[-1, 768, 768, 3]"];
	"conv1 (3x3/1) (3->64) +Relu" -> "conv2 (3x3/1) (64->64) +Relu"	[label="[-1, 768, 768, 64]"];
	"conv2 (3x3/1) (64->64) +Relu" -> "maxpool1 (2x2/2)"	[label="[-1, 768, 768, 64]"];
	"conv2 (3x3/1) (64->64) +Relu" -> concat4	[label="[-1, 768, 768, 64]"];
	"maxpool1 (2x2/2)" -> "conv3 (3x3/1) (64->128) +Relu"	[label="[-1, 384, 384, 64]"];
	"conv3 (3x3/1) (64->128) +Relu" -> "conv4 (3x3/1) (128->128) +Relu"	[label="[-1, 384, 384, 128]"];
	"conv4 (3x3/1) (128->128) +Relu" -> "maxpool2 (2x2/2)"	[label="[-1, 384, 384, 128]"];
	"conv4 (3x3/1) (128->128) +Relu" -> concat3	[label="[-1, 384, 384, 128]"];
	"maxpool2 (2x2/2)" -> "conv5 (3x3/1) (128->256) +Relu"	[label="[-1, 192, 192, 128]"];
	"conv5 (3x3/1) (128->256) +Relu" -> "conv6 (3x3/1) (256->256) +Relu"	[label="[-1, 192, 192, 256]"];
	"conv6 (3x3/1) (256->256) +Relu" -> "maxpool3 (2x2/2)"	[label="[-1, 192, 192, 256]"];
	"conv6 (3x3/1) (256->256) +Relu" -> concat2	[label="[-1, 192, 192, 256]"];
	"maxpool3 (2x2/2)" -> "conv7 (3x3/1) (256->512) +Relu"	[label="[-1, 96, 96, 256]"];
	"conv7 (3x3/1) (256->512) +Relu" -> "conv8 (3x3/1) (512->512) +Relu"	[label="[-1, 96, 96, 512]"];
	"conv8 (3x3/1) (512->512) +Relu" -> "maxpool4 (2x2/2)"	[label="[-1, 96, 96, 512]"];
	"conv8 (3x3/1) (512->512) +Relu" -> concat1	[label="[-1, 96, 96, 512]"];
	"maxpool4 (2x2/2)" -> "conv9 (3x3/1) (512->1024) +Relu"	[label="[-1, 48, 48, 512]"];
	"conv9 (3x3/1) (512->1024) +Relu" -> "conv10 (3x3/1) (1024->1024) +Relu"	[label="[-1, 48, 48, 1024]"];
	"conv10 (3x3/1) (1024->1024) +Relu" -> "deconv1 (2x2/2) (1024->512)"	[label="[-1, 48, 48, 1024]"];
	"deconv1 (2x2/2) (1024->512)" -> concat1	[label="[-1, 96, 96, 512]"];
	concat1 -> "conv11 (3x3/1) (1024->512) +Relu"	[label="[-1, 96, 96, 1024]"];
	"conv11 (3x3/1) (1024->512) +Relu" -> "conv12 (3x3/1) (512->512) +Relu"	[label="[-1, 96, 96, 512]"];
	"conv12 (3x3/1) (512->512) +Relu" -> "deconv2 (2x2/2) (512->256)"	[label="[-1, 96, 96, 512]"];
	"deconv2 (2x2/2) (512->256)" -> concat2	[label="[-1, 192, 192, 256]"];
	concat2 -> "conv13 (3x3/1) (512->256) +Relu"	[label="[-1, 192, 192, 512]"];
	"conv13 (3x3/1) (512->256) +Relu" -> "conv14 (3x3/1) (256->256) +Relu"	[label="[-1, 192, 192, 256]"];
	"conv14 (3x3/1) (256->256) +Relu" -> "deconv3 (2x2/2) (256->128)"	[label="[-1, 192, 192, 256]"];
	"deconv3 (2x2/2) (256->128)" -> concat3	[label="[-1, 384, 384, 128]"];
	concat3 -> "conv15 (3x3/1) (256->128) +Relu"	[label="[-1, 384, 384, 256]"];
	"conv15 (3x3/1) (256->128) +Relu" -> "conv16 (3x3/1) (128->128) +Relu"	[label="[-1, 384, 384, 128]"];
	"conv16 (3x3/1) (128->128) +Relu" -> "deconv4 (2x2/2) (128->64)"	[label="[-1, 384, 384, 128]"];
	"deconv4 (2x2/2) (128->64)" -> concat4	[label="[-1, 768, 768, 64]"];
	concat4 -> "conv17 (3x3/1) (128->64) +Relu"	[label="[-1, 768, 768, 128]"];
	"conv17 (3x3/1) (128->64) +Relu" -> "conv18 (3x3/1) (64->64) +Relu"	[label="[-1, 768, 768, 64]"];
	"conv18 (3x3/1) (64->64) +Relu" -> "conv19 (1x1/1) (64->2)"	[label="[-1, 768, 768, 64]"];
	"conv19 (1x1/1) (64->2)" -> output_layer1	[label="[-1, 768, 768, 2]"];
The code executed for the ONNX Conversion was:
    runner = ClientRunner(hw_arch="hailo8")
        'unet_best.onnx',
        'unet,
        start_node_names =["input_image"],
        end_node_names   =["mask"],
        net_input_shapes ={"input_image": [1, 3, 768, 768]},
    # Save HAR to disk
I then create a ‘calib_dataset’ using 1024 images with shape 768x768x3 :
images_path = './dataset'
images_list = [img_name for img_name in os.listdir(images_path) if os.path.splitext(img_name)[1] == ".png"]
calib_dataset = np.stack([np.array(Image.open(os.path.join(images_path, img_name))) for img_name in images_list])
np.save("calib_set.npy", calib_dataset)
And I prepare the ‘Optimization’ phase with:
alls_model_script = [
    "normalization1 = normalization([0, 0, 0], [255, 255, 255])\n",
    "performance_param(compiler_optimization_level=max)\n",
    "model_optimization_config(calibration, batch_size=1)\n",
    "post_quantization_optimization(finetune, policy=enabled, learning_rate=1e-5, epochs=1, batch_size=2)\n",
runner.load_model_script("".join(alls_model_script))
The ‘post_quantization_optimization’ line with epochs=1 was to try debug the problem faster.
Every time I run this code or try to execute the optimization using the command line, I have the same error.
hailo optimize  --hw-arch hailo8 --calib-set-path ./calib_set.npy --work-dir ./workdir --model-script unet_optimizer_script.alls --output-har-path unet_quantized.har unet_converted_model.har
This is the specs Hailo command says of my machine with a 4060 TI GPU installed:
[info] CPU: Architecture: x86_64, Model: Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz, Number Of Cores: 6, Utilization: 18.2%
[info] Memory: Total: 15GB, Available: 9GB
[info] System info: OS: Linux, Kernel: 6.1.0-21-amd64
[info] Hailo DFC Version: 3.28.0
Can someone help me on how to solve this error.
Thank you,
Hi @pedrosantos,
It seems like one of two things - either a bug or a missing feature in the Parser\Optimize step, or some incompatibility issues with the model given the input resolution you provided.
Does the error occurs if you don’t give it the finetune command? if so, can you please provide the ONNX so we can test it?
You can send it to me email omerw@hailo.ai if you prefer.
Regards,
Hi @Omer
Yes, even without the finetune command and with just the normalization command in the alls the same the error occurs.
I sent the onnx by e-mail.
Thank you for your assistance.
Hi @pedrosantos,
I think the problem is that your ONNX was not simplified. Please try simplifying it using the onnx-simplifier Python package and try to run it through the DFC pipeline.
Regards,
Hi Omer,
I still have the same error, even after running ONNX Simplifer.
I used the following ALLS:
"model_optimization_config(calibration, batch_size=1, calibset_size=128)\n"
This is the error tracelog when executing the “Optimizer”:
Tracelog
Converting model /workspace/code/hailo_dataflow_compiler/unet_best.sim.onnx to unet_converted_model.har
​Loading model /workspace/code/hailo_dataflow_compiler/unet_converted_model.har
Loading calib_set.npy
[info] Loading model script commands to unet from string
[info] Using default compression level of 1
[info] Assigning 4bit weights to layer unet/conv10 with 9437.18k parameters
[info] Ratio of weights in 4bit is 0.33
[info] Mixed Precision is done (completion time is 00:00:00.18)
[info] Layer Norm Decomposition skipped
[info] Using dataset with 128 entries for calibration
Calibration: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 128/128 [00:39<00:00, 3.24entries/s]
[info] Stats Collector is done (completion time is 00:00:40.17)
[info] matmul_equalization skipped
[info] No shifts available for layer unet/conv4/conv_op, using max shift instead. delta=1.0463
[info] No shifts available for layer unet/conv4/conv_op, using max shift instead. delta=0.5232
[info] No shifts available for layer unet/deconv3/conv_op, using max shift instead. delta=0.3632
[info] No shifts available for layer unet/conv14/conv_op, using max shift instead. delta=1.3856
[info] No shifts available for layer unet/conv14/conv_op, using max shift instead. delta=0.6928
[info] No shifts available for layer unet/deconv3/conv_op, using max shift instead. delta=0.1816
[info] No shifts available for layer unet/conv5/conv_op, using max shift instead. delta=0.0195
[info] No shifts available for layer unet/conv5/conv_op, using max shift instead. delta=0.0097
[info] No shifts available for layer unet/conv6/conv_op, using max shift instead. delta=2.2743
[info] No shifts available for layer unet/conv6/conv_op, using max shift instead. delta=1.1372
[info] No shifts available for layer unet/deconv2/conv_op, using max shift instead. delta=1.6209
[info] No shifts available for layer unet/conv12/conv_op, using max shift instead. delta=2.4363
[info] No shifts available for layer unet/conv12/conv_op, using max shift instead. delta=1.2181
[info] No shifts available for layer unet/conv11/conv_op, using max shift instead. delta=0.2415
[info] No shifts available for layer unet/conv11/conv_op, using max shift instead. delta=0.1207
[info] No shifts available for layer unet/conv9/conv_op, using max shift instead. delta=2.1301
[info] No shifts available for layer unet/conv9/conv_op, using max shift instead. delta=1.0651
[info] No shifts available for layer unet/conv8/conv_op, using max shift instead. delta=2.9340
[info] No shifts available for layer unet/conv8/conv_op, using max shift instead. delta=1.4670
[info] No shifts available for layer unet/deconv1/conv_op, using max shift instead. delta=2.0715
[info] No shifts available for layer unet/conv10/conv_op, using max shift instead. delta=2.5096
[info] No shifts available for layer unet/deconv1/conv_op, using max shift instead. delta=1.0358
[info] No shifts available for layer unet/conv7/conv_op, using max shift instead. delta=1.1644
[info] No shifts available for layer unet/conv7/conv_op, using max shift instead. delta=0.5822
[info] No shifts available for layer unet/deconv2/conv_op, using max shift instead. delta=0.8104
[info] No shifts available for layer unet/conv16/conv_op, using max shift instead. delta=0.5869
[info] No shifts available for layer unet/conv16/conv_op, using max shift instead. delta=0.2934
[info] No shifts available for layer unet/conv18/conv_op, using max shift instead. delta=0.2597
[info] No shifts available for layer unet/conv18/conv_op, using max shift instead. delta=0.1299
[info] No shifts available for layer unet/conv19/conv_op, using max shift instead. delta=0.0014
[info] No shifts available for layer unet/conv19/conv_op, using max shift instead. delta=0.0007
[info] Adaround skipped
[info] Starting Fine Tune
Epoch 1/4
1024/1024 [==============================] - 1419s 1s/step - total_distill_loss: 0.0090 - _distill_loss_unet/conv19: 0.0090
Epoch 2/4
1024/1024 [==============================] - 1382s 1s/step - total_distill_loss: 0.0085 - _distill_loss_unet/conv19: 0.0085
Epoch 3/4
1024/1024 [==============================] - 1382s 1s/step - total_distill_loss: 0.0074 - _distill_loss_unet/conv19: 0.0074
Epoch 4/4
1024/1024 [==============================] - 1383s 1s/step - total_distill_loss: 0.0058 - _distill_loss_unet/conv19: 0.0058
[info] Fine Tune is done (completion time is 01:32:47.54)
File “convert_to_hailo_v1.py”, line 296, in
File “/usr/local/lib/python3.8/dist-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/runner/client_runner.py”, line 2093, in optimize
File “/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/runner/client_runner.py”, line 1935, in _optimize
File “/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1045, in full_quantization
File “/usr/local/lib/python3.8/dist-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1229, in _full_acceleras_run
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/orchestator.py”, line 306, in wrapper
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py”, line 316, in run
step_func()
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/orchestator.py”, line 250, in wrapped
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 111, in parent_wrapper
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 73, in child_wrapper
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py”, line 347, in step3
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py”, line 405, in finalize_optimization
self.noise_analysis()
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/flows/optimization_flow.py”, line 585, in noise_analysis
algo.run()
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/optimization_algorithm.py”, line 50, in run
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/algorithm_base.py”, line 151, in run
self.run_int()
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py”, line 83, in run_int
File “/usr/local/lib/python3.8/dist-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py”, line 197, in analyze_full_quant_net
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 2603, in predict_on_batch
File “/usr/local/lib/python3.8/dist-packages/tensorflow/python/util/traceback_utils.py”, line 153, in error_handler
File "/tmp/autograph_generated_filefi1kkwei.py", line 15, in tf__predict_function
retval
= ag
.converted_call(ag
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 2155, in step_function
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 2143, in run_step
File “/usr/local/lib/python3.8/dist-packages/keras/engine/training.py”, line 2111, in predict_step
File “/usr/local/lib/python3.8/dist-packages/keras/utils/traceback_utils.py”, line 70, in error_handler
File "/tmp/autograph_generated_filekttkxvqa.py", line 188, in tf__call
ag
.for_stmt(ag__.converted_call(ag__.ld(self).model.flow.toposort, (), None, fscope), None, loop_body_5, get_state_9, set_state_9, (), {‘iterate_names’: ‘lname’})
File "/tmp/autograph_generated_filekttkxvqa.py", line 167, in loop_body_5
ag
.if_stmt(ag
File "/tmp/autograph_generated_filekttkxvqa.py", line 94, in if_body_3
n_ancestors = ag
.converted_call(ag__.ld(self).native_model.flow.ancestors, (ag_.ld(lname),), None, fscope)
File "/tmp/autograph_generated_fileaui2fwz1.py", line 12, in tf__ancestors
retval
= ag
File "/tmp/autograph_generated_file0bcnunqf.py", line 24, in tf__ancestors
anc = {ag
File "/tmp/autograph_generated_filexc04k1yw.py", line 233, in tf__shortest_path_length
ag
.if_stmt((ag__.ld(source) is None), if_body_12, else_body_12, get_state_12, set_state_12, (‘paths’, ‘G’), 1)
File "/tmp/autograph_generated_filexc04k1yw.py", line 137, in if_body_12
ag
.if_stmt((ag__.ld(target) is None), if_body_6, else_body_6, get_state_6, set_state_6, (‘paths’, ‘G’), 1)
File "/tmp/autograph_generated_filexc04k1yw.py", line 96, in else_body_6
ag
.if_stmt(ag__.converted_call(ag__.ld(G).is_directed, (), None, fscope), if_body_3, else_body_3, get_state_3, set_state_3, (‘G’,), 1)
File "/tmp/autograph_generated_filexc04k1yw.py", line 91, in if_body_3
G = ag
File "/tmp/autograph_generated_filexjrxllzd.py", line 41, in tf__reverse
ag
.if_stmt(ag__.ld(copy), if_body, else_body, get_state, set_state, (‘do_return’, ‘retval_’), 2)
File "/tmp/autograph_generated_filexjrxllzd.py", line 36, in else_body
retval
= ag
File "/tmp/__autograph_generated_filekttkxvqa.py", line 188, in tf__call
File "/tmp/__autograph_generated_filekttkxvqa.py", line 167, in loop_body_5
File "/tmp/__autograph_generated_filekttkxvqa.py", line 94, in if_body_3
File "/tmp/__autograph_generated_fileaui2fwz1.py", line 12, in tf__ancestors
File "/tmp/__autograph_generated_file0bcnunqf.py", line 24, in tf__ancestors
File "/tmp/__autograph_generated_filexc04k1yw.py", line 233, in tf__shortest_path_length
File "/tmp/__autograph_generated_filexc04k1yw.py", line 137, in if_body_12
File "/tmp/__autograph_generated_filexc04k1yw.py", line 96, in else_body_6
File "/tmp/__autograph_generated_filexc04k1yw.py", line 91, in if_body_3
File "/tmp/__autograph_generated_filexjrxllzd.py", line 41, in tf__reverse
File "/tmp/__autograph_generated_filexjrxllzd.py", line 36, in else_body
in user code:
Hi @pedrosantos,
This is strange since I was able to compile a HEF with the ONNX you provided.
Please try to delete your virtual env, create a new clean one, install the DFC whl and re-run the DFC pipeline.
Regards,
Hi @Omer ,
I created a new clean environment using the docker image.
It seems is not failing anymore in that particular error but I still cannot finish the optimization stage.
The tracelog (more below) is not very informative.
It failed in the middle of the “Full Quant Analysis” with:
hailo_model_optimization.acceleras.utils.acceleras_exceptions.SubprocessUnexpectedFailure: Subprocess step3 failed with unexpected error. exitcode -9
If you have any ideia of what this error could mean I appreciate any information.
Meanwhile, I’ll continue to try using different configuration parameters.
Regards,
Tracelog
Epoch 1/4
1024/1024 [==============================] - 1422s 1s/step - total_distill_loss: 0.0088 - _distill_loss_unet/conv19: 0.0088
Epoch 2/4
1024/1024 [==============================] - 1385s 1s/step - total_distill_loss: 0.0089 - _distill_loss_unet/conv19: 0.0089
Epoch 3/4
1024/1024 [==============================] - 1386s 1s/step - total_distill_loss: 0.0074 - _distill_loss_unet/conv19: 0.0074
Epoch 4/4
1024/1024 [==============================] - 1386s 1s/step - total_distill_loss: 0.0062 - _distill_loss_unet/conv19: 0.0062
[info] Fine Tune is done (completion time is 01:32:59.89)
Full Quant Analysis: 31%|█████████████████████████████████████▏ | 5/16 [00:50<01:22, 7.53s/iterations]Traceback (most recent call last):
File “convert_to_hailo_v1.py”, line 297, in
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2093, in optimize
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1935, in _optimize
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1045, in full_quantization
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1229, in _full_acceleras_run
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_model_optimization/tools/orchestator.py”, line 306, in wrapper
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 316, in run
step_func()
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_model_optimization/tools/orchestator.py”, line 250, in wrapped
File “/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 113, in parent_wrapper
raise SubprocessUnexpectedFailure(
Hi @pedrosantos,
This can be caused from either resources exhaustion or a bug in the Layer Analysis Tool.
Can you please try to use this alls commands and see if works?
”model_optimization_flavor(optimization_level=1, compression_level=1, batch_size=1)\n”,
If that works, try the same only with optimization_level=2 instead of 1. That can give us a clue if it’s a bug or not.
Regards,
Hi @Omer
I did as you suggested but it didn’t work.
However the error appeared later in the “Full Quant Analysis” task.
I have 16 GB in this machine, I will try in another machine that has 32GB.
Thank you for your help.
Just to inform that I finally compiled the ONNX model successfully and created the HEF file.
It worked in a PC with 32 GB using docker environment of AI Suite 2024.04 (version 3.27).
@Omer thank you for your help.
Regards
Hi, I have the same issue:
Call arguments received by layer ‘lat_model’ (type LATModel):
• inputs=tf.Tensor(shape=(1, 640, 640, 3), dtype=float32).
May I know what you did to make the conversion success? It is just changing the environment?
Thanks
I’m not sure what is the issue you have…
The main problem I was getting with this model conversion was due to not simplifying the ONNX model with onnx-simplifier and because I was running the complier in a machine with only 16 GB Ram.
I think it is really recommended to use a 32 GB Ram for compiling to HEF.
Regards
Thanks for replying me. I will try to sort it out.
Regards
Hi @pedrosantos,
I hope you’re doing well.
After compiling U-Net into HEF, how do you run inference on Hailo? Do you have any relevant code or examples that you could share?
Thank you in advance for your help!
