Hello !
I’m very (VERY) new to Hailo and I’ve been trying to use the mz to compile a simple damoyolo detection model to benchmark. I followed the user guide but I must be doing something wrong because it fails whatever the parameters/adjustments I’m trying to make.
I tried 2 different models (damoyolo_tinynasL25_S and damoyolo_tinynasL35_M), either by using the onnx’s reference in .hailomz/ directory (by not specifying an .onnx but only a model name), or by getting a .onnx and using --ckpt.
I tried directly with the model zoo (I’m sorry for the prints() everywhere in-between. I tried to debug it myself to see where exactly was the issue but I didn’t manage to find much apart from a version “unknown” during the metadata load) :
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ hailomz compile damoyolo_tinynasL25_S --calib-path ~/rendu/COCO/val2017_resized/
<Hailo Model Zoo INFO> Start run for network damoyolo_tinynasL25_S ...
<Hailo Model Zoo INFO> Initializing the hailo8 runner...
----------parse_model()------------
model_name : damoyolo_tinynasL25_S
input_framework : onnx
model_path : /home/p20c02/.hailomz/data/models_files/ObjectDetection/Detection-COCO/yolo/damoyolo_tinynasL25_S/pretrained/2022-12-19/damoyolo_tinynasL25_S.onnx
tensor_shapes : None
start_node_names : None
end_node_names : ['Mul_239', 'Sigmoid_259', 'Mul_279', 'Sigmoid_299', 'Mul_319', 'Sigmoid_339']
------NetParser.run()--------
------NetParser.run()----1----
Translating onnx model
model path : /home/p20c02/.hailomz/data/models_files/ObjectDetection/Detection-COCO/yolo/damoyolo_tinynasL25_S/pretrained/2022-12-19/damoyolo_tinynasL25_S.onnx
self._start_nodes : None
self._end_nodes : ['Mul_239', 'Sigmoid_259', 'Mul_279', 'Sigmoid_299', 'Mul_319', 'Sigmoid_339']
✅ Real Start Node Names : images
✅ Real End Node Names : ['output', '848']
✅ Real Net Input Shapes : {'images': [1, 3, 640, 640]}
[info] Translation started on ONNX model damoyolo_tinynasL25_S
[info] Restored ONNX model damoyolo_tinynasL25_S (completion time: 00:00:00.18)
/home/p20c02/.venv_hailo/lib/python3.10/site-packages/onnxsim/onnx_simplifier.py:73: FutureWarning: In the future `np.bool` will be defined as the corresponding NumPy scalar.
sizes = (None, np.float32, np.uint8, np.int8, np.uint16, np.int16, np.int32, np.int64, str, np.bool,
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.48)
[info] Start nodes mapped from original model: 'images': 'damoyolo_tinynasL25_S/input_layer1'.
[info] End nodes mapped from original model: 'Mul_239', 'Sigmoid_259', 'Mul_279', 'Sigmoid_299', 'Mul_319', 'Sigmoid_339'.
[info] Translation completed on ONNX model damoyolo_tinynasL25_S (completion time: 00:00:01.91)
Done translating model
[info] Saved HAR to: /home/p20c02/rendu/hailo_model_zoo/damoyolo_tinynasL25_S.har
[info] Loading model script commands to damoyolo_tinynasL25_S from /home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/cfg/alls/hailo8/base/damoyolo_tinynasL25_S.alls
[warning] Reducing compression ratio to 0 because the number of parameters in the network is not large enough (16M and need at least 20M). Can be enforced using model_optimization_config(compression_params, auto_4bit_weights_ratio=0.200)
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.51)
Calibration: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:20<00:00, 3.14entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:21.26)
[info] Output layer damoyolo_tinynasL25_S/conv60 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [4.871636974712601e-06, 0.7469313740730286]).
[info] Output layer damoyolo_tinynasL25_S/conv72 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [1.6503779534104979e-06, 0.8708891272544861]).
[info] Output layer damoyolo_tinynasL25_S/conv83 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [2.5452700356254354e-06, 0.935403048992157]).
[info] Adaround skipped
[info] Running Auto-Merger
[info] Auto-Merger is done
compiler: ../src/allocator/context_split.cpp:51: static std::shared_ptr<allocator::ContextSplit> allocator::ContextSplit::Create(std::shared_ptr<utils::GraphInterface<network_graph::NetworkNode, network_graph::NetworkEdge> >, const NodesByContextMap&, const allocator::ContextPlacements&): Assertion `validate_context_placements(*result)' failed.
I also tried to play with the .yaml files for both models, putting the (supposed) correct values for start_node and end_note, but it didn’t really change much. Just crashed later down the road.
Here with “images” and [“output”, ‘1171’] as values in the hailo_model_zoo/cfg/networks/damoyolo_tinynasL35_M.yaml for start/end nodes :
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ hailomz compile damoyolo_tinynasL35_M --calib-path ~/rendu/COCO/val2017_resized/
<Hailo Model Zoo INFO> Start run for network damoyolo_tinynasL35_M ...
model_name : damoyolo_tinynasL35_M
model_path : /home/p20c02/.hailomz/data/models_files/ObjectDetection/Detection-COCO/yolo/damoyolo_tinynasL35_M/pretrained/2022-12-19/damoyolo_tinynasL35_M.onnx
start_node_names : images
end_node_names : ['output', '1171']
model path : /home/p20c02/.hailomz/data/models_files/ObjectDetection/Detection-COCO/yolo/damoyolo_tinynasL35_M/pretrained/2022-12-19/damoyolo_tinynasL35_M.onnx
self._start_nodes : images
self._end_nodes : ['output', '1171']
✅ Real End Node Names : ['output', '1171']
[info] Translation started on ONNX model damoyolo_tinynasL35_M
[info] Restored ONNX model damoyolo_tinynasL35_M (completion time: 00:00:00.34)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:02.67)
[info] Unable to simplify the model: Parsing failed. The errors found in the graph are:
UnsupportedShuffleLayerError in op Reshape_533: Failed to determine type of layer to create in node Reshape_533
UnsupportedShuffleLayerError in op Reshape_538: Failed to determine type of layer to create in node Reshape_538
Please try to parse the model again, using these end node names: Slice_520, Concat_521
[info] According to recommendations, retrying parsing with end node names: ['Slice_520', 'Concat_521'].
self._end_nodes : ['Slice_520', 'Concat_521']
[info] Restored ONNX model damoyolo_tinynasL35_M (completion time: 00:00:00.26)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:02.46)
[info] Start nodes mapped from original model: 'images': 'damoyolo_tinynasL35_M/input_layer1'.
[info] End nodes mapped from original model: 'Slice_520', 'Concat_521'.
[info] Translation completed on ONNX model damoyolo_tinynasL35_M (completion time: 00:00:03.40)
[info] Saved HAR to: /home/p20c02/rendu/hailo_model_zoo/damoyolo_tinynasL35_M.har
[info] Loading model script commands to damoyolo_tinynasL35_M from /home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/damoyolo_tinynasL35_M.alls
[warning] line 2: layers ['damoyolo_tinynasL35_M/output_layer3', 'damoyolo_tinynasL35_M/output_layer4', 'damoyolo_tinynasL35_M/output_layer5', 'damoyolo_tinynasL35_M/output_layer6'] could not be found in scope.
File "/home/p20c02/.venv_hailo/bin/hailomz", line 33, in <module>
File "/home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
run(args)
File "/home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
File "/home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 250, in compile
runner = _ensure_optimized(runner, logger, args, network_info)
File "/home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 91, in _ensure_optimized
optimize_model(
File "/home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 360, in optimize_model
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2130, in optimize
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1972, in _optimize
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1122, in full_quantization
self.setup_quantization(self.calibration_data, data_type, work_dir=work_dir)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1044, in setup_quantization
config = self.apply_quantization_script(data, data_type)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 991, in apply_quantization_script
return self._apply_quantization_script_with_flavor()
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1009, in _apply_quantization_script_with_flavor
config = verify_commands(self._model, mo_commands, flavor_config)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/model_optimization/configuration_verifier.py", line 65, in verify_commands
verifier = ModelConfigurationValidator(hn_model, commands, allocation_mode, pre_quantization_mode)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/model_optimization/configuration_verifier.py", line 120, in __init__
self._config = ModelOptimizationConfig(**commands)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/pydantic/v1/main.py", line 341, in __init__
raise validation_error
pydantic.v1.error_wrappers.ValidationError: 1 validation error for ModelOptimizationConfig
finetune -> __root__
; loss_factors length must match loss_layer_names length; policy from line 2, batch_size from line 2, loss_layer_names from line 2, loss_factors from line 2; command was post_quantization_optimization(finetune,policy=enabled,batch_size=4,loss_layer_names=[conv81,conv95,conv109,output_layer1,output_layer2,output_layer3,output_layer4,output_layer5,output_layer6],loss_factors=[1,1,1,2,2,2,2,2,2]) (type=value_error)
I also tried directly with the hailo commands (parser, optimize and quantify) but it’s giving mixed results :
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ hailo parser onnx damoyolo_tinynasL25_S.onnx
model path : damoyolo_tinynasL25_S.onnx
self._end_nodes : None
✅ Real Start Node Names : input
✅ Real End Node Names : ['boxes', 'scores', 'classes']
✅ Real Net Input Shapes : {'input': [0, 3, 640, 640]}
[info] Restored ONNX model damoyolo_tinynasL25_S (completion time: 00:00:00.19)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.93)
UnsupportedLogitsLayerError in op /1/ArgMax: ArgMax layer /1/ArgMax has unsupported axis 2.
UnsupportedShuffleLayerError in op /0/head/Transpose_1: Failed to determine type of layer to create in node /0/head/Transpose_1
UnsupportedShuffleLayerError in op /0/head/integral/Reshape: Failed to determine type of layer to create in node /0/head/integral/Reshape
UnsupportedShuffleLayerError in op /0/head/integral/Reshape_1: Failed to determine type of layer to create in node /0/head/integral/Reshape_1
UnsupportedShuffleLayerError in op /0/head/Transpose_5: Failed to determine type of layer to create in node /0/head/Transpose_5
UnsupportedShuffleLayerError in op /0/head/Transpose_9: Failed to determine type of layer to create in node /0/head/Transpose_9
Please try to parse the model again, using these end node names: /1/ReduceMax, /0/head/Concat_32, /0/head/Unsqueeze_54, /0/head/Concat_36, /0/head/Concat_40, /0/head/Gather_24, /0/head/Softmax_2, /0/head/Gather_22, /0/head/Slice_12, /0/head/Softmax_1, /0/head/Softmax
Parsing failed with recommendations for end node names: ['/1/ReduceMax', '/0/head/Concat_32', '/0/head/Unsqueeze_54', '/0/head/Concat_36', '/0/head/Concat_40', '/0/head/Gather_24', '/0/head/Softmax_2', '/0/head/Gather_22', '/0/head/Slice_12', '/0/head/Softmax_1', '/0/head/Softmax'].
Would you like to parse again with the recommendation? (y/n)
y
[info] According to recommendations, retrying parsing with end node names: ['/1/ReduceMax', '/0/head/Concat_32', '/0/head/Unsqueeze_54', '/0/head/Concat_36', '/0/head/Concat_40', '/0/head/Gather_24', '/0/head/Softmax_2', '/0/head/Gather_22', '/0/head/Slice_12', '/0/head/Softmax_1', '/0/head/Softmax'].
self._end_nodes : ['/1/ReduceMax', '/0/head/Concat_32', '/0/head/Unsqueeze_54', '/0/head/Concat_36', '/0/head/Concat_40', '/0/head/Gather_24', '/0/head/Softmax_2', '/0/head/Gather_22', '/0/head/Slice_12', '/0/head/Softmax_1', '/0/head/Softmax']
[info] Restored ONNX model damoyolo_tinynasL25_S (completion time: 00:00:00.14)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:02.10)
[info] Unable to simplify the model: The original node name /0/head/Concat_32 in end_node_names is missing in the HN.
File "/home/p20c02/.venv_hailo/bin/hailo", line 8, in <module>
sys.exit(main())
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 116, in main
return a.run()
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 64, in run
ret_val = self._run(argv)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 111, in _run
return args.func(args)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 229, in run
return self._handle_recommendation_exception(err, args, net_name, tensor_shapes, command, save_model)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 246, in _handle_recommendation_exception
runner = self._parse(net_name, args, tensor_shapes)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 317, in _parse
runner.translate_onnx_model(
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1177, in translate_onnx_model
parser.translate_onnx_model(
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 262, in translate_onnx_model
raise e from None
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 239, in translate_onnx_model
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 320, in _parse_onnx_model_to_hn
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 372, in parse_model_to_hn
hailo_nn = fuser.convert_model()
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/model_translator/fuser/fuser.py", line 112, in convert_model
self._finalize_fused_model()
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/model_translator/fuser/fuser.py", line 473, in _finalize_fused_model
self._output_graph.update_output_layers_order(self._end_node_names)
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hailo_nn.py", line 917, in update_output_layers_order
raise InvalidHNError(
hailo_sdk_common.hailo_nn.exceptions.InvalidHNError: The original node name /0/head/Concat_32 in end_node_names is missing in the HN.
And with the L35_M it clears the parser (but recommending some random end node names for some reason) but crashes at the optimize :
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ hailo parser onnx damoyolo_tinynasL35_M.onnx
model path : damoyolo_tinynasL35_M.onnx
Please try to parse the model again, using these end node names: Concat_521, Slice_520
Parsing failed with recommendations for end node names: ['Concat_521', 'Slice_520'].
y
[info] According to recommendations, retrying parsing with end node names: ['Concat_521', 'Slice_520'].
self._end_nodes : ['Concat_521', 'Slice_520']
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:02.48)
[info] End nodes mapped from original model: 'Concat_521', 'Slice_520'.
[warning] hw_arch parameter not given, using the default hw_arch hailo8.
If another device is the target, please run again using one of hailo8, hailo8r, hailo8l, hailo15h, hailo15m, hailo15l, hailo10h
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ hailo optimize --calib-set-path ~/rendu/COCO/val2017_resized/ --model-script /home/p20c02/rendu/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/damoyolo_tinynasL35_M.alls damoyolo_tinynasL35_M.har
------ClientRunner.load_har()-------
---------HailoArchiveLoader._init()-----------
path : damoyolo_tinynasL35_M.har
_set_metadata()
['damoyolo_tinynasL35_M.hn', 'damoyolo_tinynasL35_M.npz', 'damoyolo_tinynasL35_M.original_model_meta.json', 'damoyolo_tinynasL35_M.postprocess.onnx', 'damoyolo_tinynasL35_M.metadata.json']
filename : ['damoyolo_tinynasL35_M.metadata.json']
------metadata----------
{'state': 'hailo_model', 'force_weightless_model': False, 'model_name': 'damoyolo_tinynasL35_M', 'sdk_version': '3.30.0', 'hw_arch': 'hailo8', 'hn': 'damoyolo_tinynasL35_M.hn', 'params': 'damoyolo_tinynasL35_M.npz', 'original_model_meta': 'damoyolo_tinynasL35_M.original_model_meta.json', 'postprocess': 'damoyolo_tinynasL35_M.postprocess.onnx'}
----HailoArchive.load()-----
har_path : damoyolo_tinynasL35_M.har
temp_dir : /tmp/tmpvz7g0d6g
-------------HailoArchiveLoader.load()--------------
State : hailo_model
original_model_path : None
get_sdk_version()
--------3.30.0-------------
native_hn : None
sys.exit(main())
return a.run()
File "/home/p20c02/.venv_hailo/lib/python3.10/site-packages/hailo_sdk_client/tools/optimize_cli.py", line 120, in run
self._runner.optimize(dataset, work_dir=args.work_dir)
At some point (I don’t really know how or why), by doing hailomz compile damoyolo_tinynasL35_M --calib-path ~/rendu/COCO/val2017/, I manage to generate a .hef file (when I’d like to have both S and M to compare) but it must have been a fluke because it was basically doing nothing, sitting at 0 everywhere :
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ hailomz eval --hef damoyolo_tinynasL35_M.hef --target hardware --calib-path ~/rendu/COCO/val2017/ damoyolo_tinynasL35_M
<Hailo Model Zoo INFO> Initializing the runner...
<Hailo Model Zoo INFO> Chosen target is hardware
[info] Restored ONNX model damoyolo_tinynasL35_M (completion time: 00:00:00.33)
/home/p20c02/.venv_hailo/lib/python3.10/site-packages/onnxsim/onnx_simplifier.py:73: FutureWarning: In the future `np.bool` will be defined as the corresponding NumPy scalar. (This may have returned Python scalars in past versions.
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:02.62)
[info] End nodes mapped from original model: 'Mul_396', 'Sigmoid_416', 'Mul_436', 'Sigmoid_456', 'Mul_476', 'Sigmoid_496'.
[info] Translation completed on ONNX model damoyolo_tinynasL35_M (completion time: 00:00:03.43)
<Hailo Model Zoo INFO> Initializing the dataset ...
<Hailo Model Zoo INFO> Running inference...
Processed: 5000images [01:44, 47.94images/s]
creating index...
index created!
Loading and preparing results...
Converting ndarray to lists...
(355411, 7)
0/355411
DONE (t=1.25s)
creating index...
index created!
Running per image evaluation...
Evaluate annotation type *bbox*
DONE (t=4.29s).
Accumulating evaluation results...
DONE (t=0.78s).
Average Precision (AP) @[ IoU=0.50:0.95 | area= all | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50 | area= all | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.75 | area= all | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets= 1 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets= 10 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.000
<Hailo Model Zoo INFO> Done 5000 images AP=0.000 AP50=0.000
Sorry for the long paragraph. Thank you for your help and have a great day !
Here are the versions I’m working with :
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ pip list | grep hailo
hailo-dataflow-compiler 3.30.0
hailo-model-zoo 2.14.0 /home/p20c02/rendu/hailo_model_zoo
hailo-tappas-dot-visualizer 3.31.0 /home/p20c02/rendu/tappas/tools/trace_analyzer/dot_visualizer
hailo-tappas-run-apps 3.31.0 /home/p20c02/rendu/tappas/tools/run_app
hailort 4.20.0
Cordially,
