I finished installing the hailo model zoo。
use command :
hailomz compile --ckpt /root/model_onnx/yolov5s.onnx --calib-path /root/model_onnx/images --yaml /root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov5s.yaml --start-node-names ‘start-name1’ ‘name2’ --end-node-names ‘name1’ --classes 80
error info:
Start run for network yolov5s …
[info] Translation started on ONNX model yolov5s
[info] Restored ONNX model yolov5s (completion time: 00:00:00.09)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.50)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:01.22)
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 220, in translate_onnx_model
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 300, in _parse_onnx_model_to_hn
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 340, in parse_model_to_hn
converter = ONNXConverter(
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py”, line 170, in init
super().init(
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py”, line 27, in init
super().init(graph, start_node_names, end_node_names)
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/model_translator/translator.py”, line 51, in init
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/model_translator/translator.py”, line 388, in _calculate_valid_subgraph_scope
current_vertex.in_valid_subgraph = True
AttributeError: ‘NoneType’ object has no attribute ‘in_valid_subgraph’
File “/root/pyhailo/bin/hailomz”, line 33, in
File “/root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 250, in compile
File “/root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 73, in _ensure_optimized
File “/root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 108, in _ensure_parsed
File “/root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 97, in parse_model
model_name = translate_model(runner, network_info, ckpt_path, tensor_shapes=start_node_shapes)
File “/root/DFC_hailo/hailo_model_zoo/hailo_model_zoo/utils/parse_utils.py”, line 28, in translate_model
runner.translate_onnx_model(
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1158, in translate_onnx_model
parser.translate_onnx_model(
File “/root/pyhailo/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py”, line 260, in translate_onnx_model
super().init(
I have traced the relevant code according to the error, but it has not been solved, because it is a command line, and it cannot be debugged.
