Yolo evaluation
Hi, I’m new to Hailo,
Could someone advice on how to evaluate a custom yolo model?
I was looking at In-Depth-Optimization-Tutorial, but didn’t find a similar tutorial for yolo object detection.
Hey @vinimadu,
For measuring FPS, you can use: hailortcli run {model}
To evaluate accuracy:
The eval command will run inference on your validation TFRecord and give you detection metrics like mAP:
• Full-precision (no quantization):
hailomz eval custom_yolo
• Emulator (integer model):
hailomz eval custom_yolo --target emulator
• On-device (Hailo-8, Hailo-10, etc.):
hailomz eval custom_yolo --target hardware
You can also limit the number of images with --data-count N or visualize the outputs using --visualize.
Hope this helps!
