I have a tool to calculate mAP and I’m trying to reproduce the mAP results seen with the eval option :
(.venv_hailo) p20c02@p20c02:~/rendu/hef_storage$ hailomz eval --hef yolov8m.hef --target hardware yolov8m
<Hailo Model Zoo INFO> Start run for network yolov8m ...
Average Precision (AP) @[ IoU=0.50:0.95 | area= all | maxDets=100 ] = 0.491
Average Precision (AP) @[ IoU=0.50 | area= all | maxDets=100 ] = 0.659
Average Precision (AP) @[ IoU=0.75 | area= all | maxDets=100 ] = 0.536
Average Precision (AP) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = 0.301
Average Precision (AP) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = 0.541
Average Precision (AP) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.656
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets= 1 ] = 0.373
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets= 10 ] = 0.610
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets=100 ] = 0.646
Average Recall (AR) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = 0.442
Average Recall (AR) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = 0.706
Average Recall (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.802
<Hailo Model Zoo INFO> Done 5000 images AP=49.105 AP50=65.896
To do so, I compiled a yolov8m.hef using :
hailomz compile --hw-arch hailo8 yolov8m
With the default yolov8m.alls :
model_optimization_config(calibration, batch_size=2)
change_output_activation(conv58, sigmoid)
change_output_activation(conv71, sigmoid)
change_output_activation(conv83, sigmoid)
post_quantization_optimization(finetune, policy=enabled, learning_rate=0.000025)
nms_postprocess("../../postprocess_config/yolov8m_nms_config.json", meta_arch=yolov8, engine=cpu)
And I let everything in the .alls as is except the yolov8m_nms_config.json where I put the score to 0.001 because I want to calculate the Average/Precision myself and compare it to the eval results :
"nms_scores_th": 0.001,
"nms_iou_th": 0.7,
"image_dims": [
640,
640
"classes": 80,
"regression_length": 16,
"background_removal": false,
"bbox_decoders": [
"name": "bbox_decoder57",
"stride": 8,
"reg_layer": "conv57",
"cls_layer": "conv58"
"name": "bbox_decoder70",
"stride": 16,
"reg_layer": "conv70",
"cls_layer": "conv71"
"name": "bbox_decoder82",
"stride": 32,
"reg_layer": "conv82",
"cls_layer": "conv83"
However, while infering using the hailo code examples for object_detection - immediately getting the len of detected object per classes - I noticed that I was getting a lower number of detection (100 detections with nms_scores_th=0.001 and nms_iou_th=0.7).
Testing with the pytorch weights directly, for the same scores and iou threshold, I’m getting 65 more detections (165 detections post nms).
I tested on other images, and I’m getting around half the detections on the hailo compiled .hef VS .pt file or .onnx.
Do you know if there are other parameters I’m suppose to play with ? Maybe the score/iou threshold is also set somewhere else, that would explain why half the detections are missing ?
Here are the versions I’m working on :
(.venv_hailo) p20c02@p20c02:~/rendu/hailo_model_zoo$ pip list | grep hailo
hailo-dataflow-compiler 3.30.0
hailo-model-zoo 2.14.0 /home/p20c02/rendu/hailo_model_zoo
hailo-tappas-dot-visualizer 3.31.0 /home/p20c02/rendu/tappas/tools/trace_analyzer/dot_visualizer
hailo-tappas-run-apps 3.31.0 /home/p20c02/rendu/tappas/tools/run_app
hailort 4.20.0
Thank you for your help ! ![]()
Cordially,
