Hailo Model Zoo YOLOv8 retraining environment
Hi, I trained yolov8 with custom dataset on local python environment(as conda…), not docker and I got 0.97 mAP50 score from my test dataset with my custom model (custom_yolov8n.onnx).
Then I compiled onnx to hef using hailo model zoo yolov8n config(input size and classes are modified) and got 0.55 mAP50 score with same test dataset in hailo8.
So, my questions are
  1. Is this score typical?
  2. If I retrain custom model in docker environment provided in hailo model zoo, then can I got higher score?
I want to know if there is a difference between local python env(with ultralytics) and hailo model zoo docker env for retraining
Welcome to the Hailo Community @anon17881598!
There seems to be a significant accuracy decrease. This means there’s noise resulting from the quantization.
It is unlikely that this would have an effect.
Here are a few things you can try:
  1. Make sure you are using as a base the ModelZoo model script for the quantization
  2. Add this solution to your model script.
  3. Add more images to your calibset
  4. Try using Adaround as a post-quant alg
  5. Set the output to 16-bit - please note that this negatively affects the FPS
Thank you for the answer :slight_smile:
I tried compile with optimization_level=4 for Adaround and use 8000 calibset for calibration/finetuning.
I got 0.65 mAP50 score with this methods.
But I’m still wondering if there’s a way to improve my score.
Hi, how did you test the accuracy of the HEF file ?
Are you applying any normalization to the input ? Normally you shouldn’t because the model zoo script automatically adds a normalization layer to the model. The input should be uint8 [0…255].
Of course, I understand that there is a normalization layer command in the .alls file. So I use uint8 images for hef model input.
Now, I’m trying compile without normalization layer in .alls file.
Could you show us your full final model script with all of the added recommended commands?
Actually, @victorc meant that the normalization shouldn’t be performed outside of the compiled model. The recommended approach is to leave the normalization command in the model script.
@nina-vilela
This is my scripts for compile custom retrained yolov8n model
(Input size=1280x1280, Classes=6, DFCversion=3.27.0)
# custom_yolov8n.yaml
base:
- base/yolov8.yaml
postprocessing:
  device_pre_post_layers:
    nms: true
  hpp: true
network:
  network_name: yolov8n
paths:
  alls_script: custom_yolov8n.alls
parser:
  nodes:
  - null
  - - /model.22/cv2.0/cv2.0.2/Conv
    - /model.22/cv3.2/cv3.2.2/Conv
quantization:
  calib_set:
  - models_files/my_dataset/adm_bbox_v2_calib_8000.tfrecord
preprocessing:
  network_type: detection
  input_shape:
  - 1280
  - 1280
  - 3
  meta_arch: yolo_v5
  padding_color: 114
# custom_yolov8n.alls
model_optimization_flavor(optimization_level=4)
nms_postprocess("../../postprocess_config/custom_yolov8n_nms_config_1280.json", meta_arch=yolov8, engine=cpu)
model_optimization_config(calibration, batch_size=16, calibset_size=8000)
post_quantization_optimization(finetune, policy=enabled, dataset_size=8000, epochs=8, learning_rate=0.0001)
# custom_yolov8n_nms_config_1280.json
	"nms_scores_th": 0.2,
	"nms_iou_th": 0.7,
	"image_dims": [
		1280,
		1280
	"classes": 6,
	"regression_length": 16,
	"background_removal": false,
	"bbox_decoders": [
			"name": "yolov8n/bbox_decoder41",
			"stride": 8,
			"reg_layer": "yolov8n/conv41",
			"cls_layer": "yolov8n/conv42"
			"name": "yolov8n/bbox_decoder52",
			"stride": 16,
			"reg_layer": "yolov8n/conv52",
			"cls_layer": "yolov8n/conv53"
			"name": "yolov8n/bbox_decoder62",
			"stride": 32,
			"reg_layer": "yolov8n/conv62",
			"cls_layer": "yolov8n/conv63"
So by compiling the above script, I was able to get a maximum mAP50 score of 0.65.
Now, I’m trying to optimize with full-16-bit and add this solutions as you recommanded.
@nina-vilela
Does the difference in onnx opset version affect the performance?
In the retraining example in docker of Hailo Model zoo, Onnx opset=11 is set, but in my case, onnx opset=17 is set.
As far as I know, my DFC version 3.27 supports onnx opset 17.
Is there a problem here?
Make sure to add to your model script the command below:
quantization_param([conv42, conv53, conv63], force_range_out=[0.0, 1.0])
As recommended in this solution
Short answer is no
sorry if this is unrelated but I am having a problem with compiling my custom model. when I run this command
hailomz eval yolov8s --calib-path /media/admin/New\ Volume2/PROJECTS/carnumberplate-main/freedomtech
I encounter this error
File “/home/adrian/anaconda3/envs/hailo/bin/hailomz”, line 8, in
sys.exit(main())
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_model_zoo/main_driver.py”, line 386, in evaluate
_ensure_runnable_state_tf2(args, logger, network_info, runner, target)
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_model_zoo/main_driver.py”, line 176, in _ensure_runnable_state_tf2
optimize_full_precision_model(
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_model_zoo/core/main_utils.py”, line 337, in optimize_full_precision_model
runner.optimize_full_precision(calib_data=calib_feed_callback)
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2090, in optimize_full_precision
self._optimize_full_precision(data_continer)
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2093, in _optimize_full_precision
self._sdk_backend.optimize_full_precision(data_continer)
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1722, in optimize_full_precision
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1610, in _apply_model_modification_commands
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 379, in apply
self._get_config_file_from_path()
File “/home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 536, in _get_config_file_from_path
raise AllocatorScriptParserException(
hailo_sdk_client.sdk_backend.sdk_backend_exceptions.AllocatorScriptParserException: Post-process config file isn’t found in /home/adrian/anaconda3/envs/hailo/lib/python3.9/site-packages/hailo_model_zoo/cfg/alls/generic/../../postprocess_config/yolov8s_nms_config.json. Please make sure the given path is relative to the .alls file location, or it is a global path.
Typically what this error says is that the file ‘yolov8s_nms_config_json’ is missing. Is this a file that I need to download or do I create this.
Also I need to ask why is the command failing when I put my model already trained ( with a different name) example best.pt but only accepts yolo?
I have encountered a similar problem too. May I ask if it has been solved? Thank.
