I’m running a finetuned yolov8n for detection/localization and was trying to run the evaluation on it. The model appears to work: when I run the evaluation with --visualize the generated bounding boxes are as expected.
However, just looking at the eval metrics they are all 0:
hailomz eval --har finetuned_yolov8n.har --target full_precision --hw-arch hailo8l --yaml ./cfg/finetuned_yolov8n.yaml --model-script cfg/finetuned_yolov8n.alls --data-path asdf.tfrecord --data-count 128 --classes 1
<Hailo Model Zoo INFO> Start run for network finetuned_yolov8n ...
<Hailo Model Zoo INFO> Initializing the runner...
<Hailo Model Zoo INFO> Chosen target is full_precision
checking in /mnt
[info] Loading model script commands to finetuned_yolov8n from cfg/finetuned_yolov8n.alls
[info] Loading model script commands to finetuned_yolov8n from string
<Hailo Model Zoo INFO> Initializing the dataset ...
checking in /mnt
<Hailo Model Zoo INFO> Running inference...
[info] Setting NMS score threshold to 0.001
Processed: 128images [00:53, 2.41images/s]
creating index...
index created!
Loading and preparing results...
Converting ndarray to lists...
(12800, 7)
0/12800
DONE (t=0.03s)
creating index...
index created!
Running per image evaluation...
Evaluate annotation type *bbox*
DONE (t=0.30s).
Accumulating evaluation results...
DONE (t=0.04s).
Average Precision (AP) @[ IoU=0.50:0.95 | area= all | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50 | area= all | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.75 | area= all | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = 0.000
Average Precision (AP) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets= 1 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets= 10 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= all | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = 0.000
Average Recall (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = 0.000
<Hailo Model Zoo INFO> Done 128 images AP=0.000 AP50=0.000
I checked my .tfrecord file with tfrecord-viewer1 and the labels in it seem to make sense.
Here’s my customized configs:
base:
- networks/yolov8n.yaml
network:
network_name: finetuned_yolov8n
paths:
alls_script: finetuned_yolov8n.alls
evaluation:
classes: 1
dataset: asdf.tfrecord
quantization:
calib_set:
- asdf.tfrecord
nms_postprocess("finetuned_yolov8n_nms_config.json", meta_arch=yolov8, engine=cpu)
allocator_param(width_splitter_defuse=disabled)
"nms_scores_th": 0.2,
"nms_iou_th": 0.7,
"image_dims": [
1920,
1920
"classes": 1,
"regression_length": 16,
"background_removal": false,
"bbox_decoders": [
"name": "finetuned_yolov8n/bbox_decoder41",
"stride": 8,
"reg_layer": "finetuned_yolov8n/conv41",
"cls_layer": "finetuned_yolov8n/conv42"
"name": "finetuned_yolov8n/bbox_decoder52",
"stride": 16,
"reg_layer": "finetuned_yolov8n/conv52",
"cls_layer": "finetuned_yolov8n/conv53"
"name": "finetuned_yolov8n/bbox_decoder62",
"stride": 32,
"reg_layer": "finetuned_yolov8n/conv62",
"cls_layer": "finetuned_yolov8n/conv63"
The finetuned_yolov8n.har is currently just an imported/“parsed” version converted from the onnx (using hailomz parse --ckpt=v8n_v3_1920_agdswi2m_best.onnx --hw-arch hailo8l --yaml cfg/finetuned_yolov8n.yaml).
Any thoughts as to what might be causing this issue?
Thanks!
