I want to excute 1-class model evaluation by using hailo model zoo SDK
Hi, I’ve just started learning to hailo model zoo.
Now, I stucked one problem.
I made a model based on yolov8s by retraining with docker, and tried to evaluate it.
I’ll show commands that I excuted below.
What I did is shown below.
  1. made tfrecord from my own datasets based on yolo format.
  2. excuted command hailomz eval --har --target emulator --data-path
  3. I got this logs
Processed: 536images [00:35, 15.09images/s]
creating index...
index created!
Loading and preparing results...
Converting ndarray to lists...
(53600, 7)
0/53600
DONE (t=0.07s)
creating index...
index created!
Running per image evaluation...
Evaluate annotation type *bbox*
DONE (t=0.02s).
Accumulating evaluation results...
Please run evaluate() first
DONE (t=0.00s).
 Average Precision  (AP) @[ IoU=0.50:0.95 | area=   all | maxDets=100 ] = -1.000
 Average Precision  (AP) @[ IoU=0.50      | area=   all | maxDets=100 ] = -1.000
 Average Precision  (AP) @[ IoU=0.75      | area=   all | maxDets=100 ] = -1.000
 Average Precision  (AP) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = -1.000
 Average Precision  (AP) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = -1.000
 Average Precision  (AP) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = -1.000
 Average Recall     (AR) @[ IoU=0.50:0.95 | area=   all | maxDets=  1 ] = -1.000
 Average Recall     (AR) @[ IoU=0.50:0.95 | area=   all | maxDets= 10 ] = -1.000
 Average Recall     (AR) @[ IoU=0.50:0.95 | area=   all | maxDets=100 ] = -1.000
 Average Recall     (AR) @[ IoU=0.50:0.95 | area= small | maxDets=100 ] = -1.000
 Average Recall     (AR) @[ IoU=0.50:0.95 | area=medium | maxDets=100 ] = -1.000
 Average Recall     (AR) @[ IoU=0.50:0.95 | area= large | maxDets=100 ] = -1.000
<Hailo Model Zoo INFO> Done 536 images AP=-100.000 AP50=-100.000
I think it cause parsing tfrecord or setting yaml.
parse tfrecord script
yolo to coco
#!/usr/bin/env python
import argparse
import json
import os
from pathlib import Path
from PIL import Image
def yolo_to_coco(img_dir, label_dir, output_json, class_names):
    image_id = 0
    annotation_id = 0
    images = []
    annotations = []
    categories = []
    # カテゴリ定義
    for i, name in enumerate(class_names):
        categories.append({
            "id": i,
            "name": name,
            "supercategory": "object"
    for img_file in sorted(Path(img_dir).glob("*.[jp][pn]g")):
        label_file = Path(label_dir) / (img_file.stem + ".txt")
        if not label_file.exists():
            continue
        with Image.open(img_file) as img:
            width, height = img.size
        images.append({
            "id": image_id,
            "file_name": img_file.name,
            "width": width,
            "height": height
        with open(label_file, "r") as f:
            for line in f:
                parts = line.strip().split()
                if len(parts) != 5:
                    continue
                class_id, x_center, y_center, w, h = map(float, parts)
                bbox_width = w * width
                bbox_height = h * height
                x = (x_center * width) - bbox_width / 2
                y = (y_center * height) - bbox_height / 2
                annotations.append({
                    "id": annotation_id,
                    "image_id": image_id,
                    "category_id": int(class_id),
                    "bbox": [x, y, bbox_width, bbox_height],
                    "area": bbox_width * bbox_height,
                    "iscrowd": 0
                annotation_id += 1
        image_id += 1
    coco_format = {
        "images": images,
        "annotations": annotations,
        "categories": categories
    with open(output_json, "w") as f:
        json.dump(coco_format, f, indent=2)
    print(f"Converted {image_id} images and {annotation_id} annotations to COCO format.")
    print(f"Output saved to: {output_json}")
if __name__ == "__main__":
    parser = argparse.ArgumentParser(description="Convert YOLO annotations to COCO format.")
    parser.add_argument("--img", required=True, help="Path to directory with images")
    parser.add_argument("--label", required=True, help="Path to directory with YOLO .txt annotations")
    parser.add_argument("--output", default="output.json", help="Output COCO JSON file")
    parser.add_argument("--names", required=True, help="Path to .names file (one class per line)")
    args = parser.parse_args()
    with open(args.names, "r") as f:
        class_names = [line.strip() for line in f if line.strip()]
    yolo_to_coco(args.img, args.label, args.output, class_names)
coco to tfrecord
import argparse
import collections
import json
import os
import random
import tensorflow as tf
from tqdm import tqdm
# TFRecord feature helpers
def _int64_feature(values):
    if not isinstance(values, (tuple, list)):
        values = [values]
    return tf.train.Feature(int64_list=tf.train.Int64List(value=values))
def _bytes_feature(value):
    return tf.train.Feature(bytes_list=tf.train.BytesList(value=[value]))
def _float_list_feature(value):
    return tf.train.Feature(float_list=tf.train.FloatList(value=value))
def _create_tfrecord(img_label_pairs, imgs_name2id, tfrecord_path, name):
    with tf.io.TFRecordWriter(str(tfrecord_path)) as writer:
        progress_bar = tqdm(img_label_pairs, desc=f"Creating {name}")
        for i, (img_path, annotations) in enumerate(progress_bar):
            progress_bar.set_description(f"{name} #{i+1}: {img_path}")
            # Load image
            with open(img_path, "rb") as f:
                img_jpeg = f.read()
            img = np.array(Image.open(img_path))
            height, width = img.shape[:2]
            # Bounding box info
            xmin, xmax, ymin, ymax = [], [], [], []
            category_id, is_crowd, area = [], [], []
            for ann in annotations:
                x, y, w, h = ann["bbox"]
                if w <= 0 or h <= 0 or x + w > width or y + h > height:
                    continue
                xmin.append(x / width)
                xmax.append((x + w) / width)
                ymin.append(y / height)
                ymax.append((y + h) / height)
                category_id.append(int(ann["category_id"]))
                is_crowd.append(ann["iscrowd"])
                area.append(ann["area"])
            img_id = ann["image_id"] if annotations else imgs_name2id[os.path.basename(img_path)]
            example = tf.train.Example(features=tf.train.Features(feature={
                "height": _int64_feature(height),
                "width": _int64_feature(width),
                "num_boxes": _int64_feature(len(annotations)),
                "image_id": _int64_feature(img_id),
                "xmin": _float_list_feature(xmin),
                "xmax": _float_list_feature(xmax),
                "ymin": _float_list_feature(ymin),
                "ymax": _float_list_feature(ymax),
                "area": _float_list_feature(area),
                "category_id": _int64_feature(category_id),
                "is_crowd": _int64_feature(is_crowd),
                "image_name": _bytes_feature(os.path.basename(img_path).encode()),
                "image_jpeg": _bytes_feature(img_jpeg),
            writer.write(example.SerializeToString())
    return i + 1
def get_img_labels_list(dataset_dir, annotation_file):
    with tf.io.gfile.GFile(str(annotation_file), "r") as fid:
        annotations = json.load(fid)
    imgs_name2id = {img["file_name"]: img["id"] for img in annotations["images"]}
    img_to_annotations = collections.defaultdict(list)
    for ann in annotations["annotations"]:
        img_name = f'{ann["image_id"]:012d}.jpg'
        img_to_annotations[img_name].append(ann)
    no_anns_count = 0
    img_label_pairs = []
    for img_file in sorted(dataset_dir.iterdir()):
        img_name = img_file.name
        anns = img_to_annotations.get(img_name, [])
        if not anns:
            no_anns_count += 1
        img_label_pairs.append((str(img_file), anns))
    print(f"{no_anns_count} / {len(img_label_pairs)} images have no annotations")
    random.seed(0)
    random.shuffle(img_label_pairs)
    return img_label_pairs, imgs_name2id
def run(img_dir, annotation_path):
    if not img_dir or not annotation_path:
        if img_dir or annotation_path:
            raise ValueError("Both --img and --det must be specified together.")
        else:
            raise ValueError("Please specify --img and --det arguments.")
    dataset_dir = Path(img_dir)
    annotation_file = Path(annotation_path)
    img_label_pairs, imgs_name2id = get_img_labels_list(dataset_dir, annotation_file)
    tfrecord_output_path = dataset_dir.parent / "output.tfrecord"
    num_images = _create_tfrecord(img_label_pairs, imgs_name2id, tfrecord_output_path, "TFRecord")
    print(f"\nDone converting {num_images} images. Output saved to: {tfrecord_output_path}")
    parser = argparse.ArgumentParser(description="Convert image and annotation dataset to TFRecord.")
    parser.add_argument("--img", "-img", help="Path to image directory", type=str, required=True)
    parser.add_argument("--det", "-det", help="Path to COCO-format annotation JSON", type=str, required=True)
    run(args.img, args.det)
yaml
base:
- base/yolov8.yaml
postprocessing:
  device_pre_post_layers:
    nms: true
  hpp: true
network:
  network_name: yolov8s
paths:
  network_path:
    - /local/workspace/hailo/2025-04/shared_with_docker/20250428_yolov8s/weights/20250428_yolov8s.onnx
  alls_script: yolov8s.alls
