I know that you don’t have support yet but the Hailort driver did work when I initially installed it and then broke during one of the updates.
Error 1: “[HailoRT] [error] CHECK failed - Driver version (4.22.0) is different from library version (5.0.0)” Q1: How can I manually set the libraries to v4.22? Where can I get the hailo module to import or is it only available via API?
Error 2: Is 10h a new AI hat or will HailortRT v5.0.0 be backward compatible with 8L?
