Installign Hailo 8 on a PI5
So I got a pi5 with Rapsbian Trixie:
PRETTY_NAME=“Debian GNU/Linux 13 (trixie)”
NAME=“Debian GNU/Linux”
VERSION_ID=“13”
VERSION=“13 (trixie)”
VERSION_CODENAME=trixie
DEBIAN_VERSION_FULL=13.2
ID=debian
HOME_URL=“``https://www.debian.org/”
SUPPORT_URL=“``https://www.debian.org/support”
BUG_REPORT_URL=“``https://bugs.debian.org/”
ii  hailo-all                                        4.23.0                                    all          Hailo support (metapackage)
ii  hailo-tappas-core                                5.1.0                                     arm64        Core components of the Hailo TAPPAS platform
ii  hailort                                          4.23.0                                    arm64        AI acceleration runtime library for Hailo hardware
ii  hailort-pcie-driver                              4.23.0                                    all          Hailo PCIe driver and firmware for AI hardware acceleration
ii  python3-hailo-tappas                             5.1.0                                     arm64        Python binding for tappas
ii  python3-hailort                                  4.23.0-1                                  arm64        HailoRT Python API, which wraps the runtime library
ii  rpicam-apps-hailo-postprocess                    1.10.1-1                                  arm64        Raspberry Pi AI HAT+ post-processing plugin for rpicam-apps
Try to install the driver via:
sudo apt update
sudo apt full-upgrade
sudo apt install -y dkms
sudo apt install -y hailo-all
However hailortcli fw-control identify returns:
[HailoRT] [error] CHECK failed - Driver version (4.20.0) is different from library version (4.23.0)
How can i fix this?
It looks like something went wrong during the installation. The Raspberry Pi OS contains the HailoRT PCIe driver version 4.20. It should be overwritten when you install hailo-all. You can test this by running:
modinfo hailo_pci
I could not replicate the behavior on my Raspberry Pi. I would recommend you ether uninstall/remove the hailo-all package and install it again or rewrite the SD card using the Raspberry Pi Imager and repeat the install using the commands you used before.
I cleaned the kernel modules and performed the instalaltion again.
Now it is all 4.23 :slight_smile:
After this I was trying to get Super resolution up and running: Hailo-Application-Code-Examples/runtime/python/super_resolution at main · hailo-ai/Hailo-Application-Code-Examples · GitHub
Since I run on a Pi5 with Trxi, which only has python 3.13 I cannot install HailoRT:
pip install hailort-4.23.0-cp313-cp313-linux_aarch64.whl
How can I solve this?
Hey @Eric_Staal,
The pyhailort is already included in the hailo-all package.
