Check failed - Driver version =
Hi, i am experimenting with Hailo on a RPI5. I have tried to run some of the examples but was getting an error saying I needed HailoRT driver version 4.19.0, so i installed that. Now i keep getting the following error;
sirdezzy@raspberrypi:~ $ hailortcli fw-control identify
[HailoRT] [error] CHECK failed - Driver version (4.18.0) is different from library version (4.19.0)
Uninstalling and reinstalling wont fix the error and there is no download for version 4.18.0 to install.
Any help would be appreciated.
Thanks.
Hi. I also had the same problem. In the end i got every thing to work using the commands from this site " hailo-rpi5-examples/doc/install-raspberry-pi5.md at main · hailo-ai/hailo-rpi5-examples · GitHub" under Upgrade or Downgrade Hailo software.
Hope you can fix it with this to!
Thanks. I couldnt fix the error so have taken the drastic approach to start with a fresh install of Raspbian.
I am looking at the license plate recognition example in the Tappas git respository, it says it wants HailoRT version 4.19 but when I upgrade to that nothing else works.
Just as a side note … after you clone the git repo you can checkout the taged version your driver is at (usually the driver is behind the git repo) so simply do a git checkout v18.0.0 or any other version your driver is at.
