Hi!
I am currently trying to convert a Superpoint algorithm to ONNX so that I can eventually convert it to an HEF format.
Now I converted the Superpoint model to ONNX format, which seems to work correctly as I compared the outputs of the ONNX and Pytorch models and they appeared to be the same. However, when I use the hailo parse function ( hailo parser onnx superpoint.onnx --hw-arch hailo8 --tensor-shapes [1,1,720,1280] I get the following error:
2025-02-25 17:09:05.101374238 [E:onnxruntime:, sequential_executor.cc:516 ExecuteKernel] Non-zero status code returned while running TopK node. Name:'/TopK' Status Message: k argument [500] should not be greater than specified axis dim value [0]
[warning] ONNX shape inference failed: [ONNXRuntimeError] : 1 : FAIL : Non-zero status code returned while running TopK node. Name:'/TopK' Status Message: k argument [500] should not be greater than specified axis dim value [0]
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:01.27)
2025-02-25 17:09:06.104015686 [E:onnxruntime:, sequential_executor.cc:516 ExecuteKernel] Non-zero status code returned while running TopK node. Name:'/TopK' Status Message: k argument [500] should not be greater than specified axis dim value [0]
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 239, in translate_onnx_model
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 320, in _parse_onnx_model_to_hn
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 371, in parse_model_to_hn
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py", line 83, in convert_model
self._create_layers()
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 38, in _create_layers
self._update_vertices_info()
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 316, in _update_vertices_info
node.update_output_format()
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 507, in update_output_format
or self.is_null_transpose()
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 6143, in is_null_transpose
if self.is_torch_tile_resize_nearest() or self.is_null_transpose_near_torch_tile():
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 4718, in is_null_transpose_near_torch_tile
input_shape = self.get_input_shapes(convert_to_nhwc=False)[0]
IndexError: list index out of range
File "/home/dylan/hailodfc/bin/hailo", line 8, in <module>
sys.exit(main())
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/main.py", line 111, in main
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py", line 68, in run
return self._run(argv)
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py", line 89, in _run
return args.func(args)
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 201, in run
runner = self._parse(net_name, args, tensor_shapes)
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 287, in _parse
runner.translate_onnx_model(
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1177, in translate_onnx_model
parser.translate_onnx_model(
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 280, in translate_onnx_model
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 500, in update_output_format
self.update_reshape_output_format(input_format)
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 332, in update_reshape_output_format
is_features_to_heads, f_to_g_format = self.is_features_to_groups_reshape(input_format)
File "/home/dylan/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 3491, in is_features_to_groups_reshape
default_out_format.insert(stack_idx, Dims.STACK)
TypeError: 'NoneType' object cannot be interpreted as an integer
This is my code for extracting the top k keypoints
def top_k_keypoints(keypoints, scores, k: int):
# Create a mask where scores are in top k
# This avoids Python if statements entirely
values, indices = torch.topk(scores, k=min(k, len(scores)), dim=0)
# Create a boolean mask for top k indices
mask = torch.zeros_like(scores, dtype=torch.bool)
mask[indices] = True
# Apply mask to both keypoints and scores
return keypoints[mask], scores[mask]
I have tried a lot of different ways for this method to be ONNX compatible, but I keep getting this error when trying to hailo parse.
Does anyone know what might be going wrong?
