I’m trying to export this onnx model in Har format using the following command:
hailo parser onnx models/superpoint_lightglue_pipeline_simpl.onnx\
--net-name superpoint_lightglue_pipeline_simpl\
--start-node-names images\
--end-node-names keypoints matches mscores\
--tensor-shapes images=[2,1,2560,2560]\
--hw-arch hailo8\
--input-format images=NCHW
but I get the following error:
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 235, in translate_onnx_model
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 316, in _parse_onnx_model_to_hn
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 367, in parse_model_to_hn
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py", line 83, in convert_model
self._create_layers()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 40, in _create_layers
self._add_direct_layers()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 122, in _add_direct_layers
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 443, in _layer_callback_from_vertex
self._create_ew_div_layer(vertex)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 1063, in _create_ew_div_layer
self._create_ew_layer(vertex, EWDivLayer)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 1077, in _create_ew_layer
const_layer, ew_op_input = self._create_ew_const_input_layer(vertex)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 1222, in _create_ew_const_input_layer
const_layer = ConstInputLayer.create(f"{vertex.name}_input", [const_output_shape], input_values)
UnboundLocalError: local variable 'const_output_shape' referenced before assignment
File "/local/workspace/hailo_virtualenv/bin/hailo", line 8, in <module>
sys.exit(main())
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/main.py", line 111, in main
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 64, in run
return self._run(argv)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_platform/tools/hailocli/main.py", line 104, in _run
return args.func(args)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 198, in run
runner = self._parse(net_name, args, tensor_shapes)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/parser_cli.py", line 282, in _parse
runner.translate_onnx_model(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1158, in translate_onnx_model
parser.translate_onnx_model(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 276, in translate_onnx_model
This is an already simplyfied version of the model using onnxsim, without optimization I get a different error:
sys.exit(main())
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 248, in translate_onnx_model
raise e from None
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 39, in _create_layers
self._update_vertices_info()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 217, in _update_vertices_info
node.update_output_format()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 532, in update_output_format
elif self.is_null_reshape()[0]:
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 5666, in is_null_reshape
if self.is_reshape_before_split_windowed_attention() and len(self.get_output_shapes()) == 1:
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 5708, in is_reshape_before_split_windowed_attention
input_shape[1] == output_shape[1] * output_shape[2]
IndexError: list index out of range
I’m running all inside the hailo_ai_sw_suite_2024-10 docker, so the Hailo DFC version is 3.29.0 and onnxsim is 0.4.36.
Thank you in advance
