Moreover, I cannot find any BatchNormalization block in the .onnx downloadable from the model_zoo. But mainly ReduceMean blocks. So I guess some custom nn.Module was created that uses torch.mean() under the hood.
First ONNX layers in model_zoo’s model:
First ONNX layer in my custom model:
My Custom model:
# Copyright (c) 2021, NVIDIA Corporation. All rights reserved.
# This work is licensed under the NVIDIA Source Code License
import collections
import math
import warnings
from itertools import repeat
from typing import Optional, Tuple
import torch
import torch.nn as nn
import torch.nn.functional as F
def _trunc_normal_(tensor, mean, std, a, b):
# Cut & paste from PyTorch official master until it's in a few official releases - RW
# Method based on https://people.sc.fsu.edu/~jburkardt/presentations/truncated_normal.pdf
def norm_cdf(x):
# Computes standard normal cumulative distribution function
return (1.0 + math.erf(x / math.sqrt(2.0))) / 2.0
if (mean < a - 2 * std) or (mean > b + 2 * std):
warnings.warn(
"mean is more than 2 std from [a, b] in nn.init.trunc_normal_. "
"The distribution of values may be incorrect.",
stacklevel=2,
# Values are generated by using a truncated uniform distribution and
# then using the inverse CDF for the normal distribution.
# Get upper and lower cdf values
l = norm_cdf((a - mean) / std) # noqa
u = norm_cdf((b - mean) / std)
# Uniformly fill tensor with values from [l, u], then translate to
# [2l-1, 2u-1].
tensor.uniform_(2 * l - 1, 2 * u - 1)
# Use inverse cdf transform for normal distribution to get truncated
# standard normal
tensor.erfinv_()
# Transform to proper mean, std
tensor.mul_(std * math.sqrt(2.0))
tensor.add_(mean)
# Clamp to ensure it's in the proper range
tensor.clamp_(min=a, max=b)
return tensor
def trunc_normal_(tensor, mean=0.0, std=1.0, a=-2.0, b=2.0):
# type: (Tensor, float, float, float, float) -> Tensor
r"""Fills the input Tensor with values drawn from a truncated
normal distribution. The values are effectively drawn from the
normal distribution :math:`\mathcal{N}(\text{mean}, \text{std}^2)`
with values outside :math:`[a, b]` redrawn until they are within
the bounds. The method used for generating the random values works
best when :math:`a \leq \text{mean} \leq b`.
NOTE: this impl is similar to the PyTorch trunc_normal_, the bounds [a, b] are
applied while sampling the normal with mean/std applied, therefore a, b args
should be adjusted to match the range of mean, std args.
Args:
tensor: an n-dimensional `torch.Tensor`
mean: the mean of the normal distribution
std: the standard deviation of the normal distribution
a: the minimum cutoff value
b: the maximum cutoff value
Examples:
>>> w = torch.empty(3, 5)
>>> nn.init.trunc_normal_(w)
with torch.no_grad():
return _trunc_normal_(tensor, mean, std, a, b)
class Mlp(nn.Module):
def __init__(
self,
in_features,
hidden_features=None,
out_features=None,
act_layer=nn.GELU,
drop=0.0,
super().__init__()
out_features = out_features or in_features
hidden_features = hidden_features or in_features
self.fc1 = nn.Linear(in_features, hidden_features)
self.dwconv = DWConv(hidden_features)
self.act = act_layer()
self.fc2 = nn.Linear(hidden_features, out_features)
self.drop = nn.Dropout(drop)
self.apply(self._init_weights)
def _init_weights(self, m):
if isinstance(m, nn.Linear):
trunc_normal_(m.weight, std=0.02)
if isinstance(m, nn.Linear) and m.bias is not None:
nn.init.constant_(m.bias, 0)
elif isinstance(m, nn.LayerNorm):
nn.init.constant_(m.weight, 1.0)
elif isinstance(m, nn.Conv2d):
fan_out = m.kernel_size[0] * m.kernel_size[1] * m.out_channels
fan_out //= m.groups
m.weight.data.normal_(0, math.sqrt(2.0 / fan_out))
if m.bias is not None:
m.bias.data.zero_()
def forward(self, x, H, W):
x = self.fc1(x)
x = self.dwconv(x, H, W)
x = self.act(x)
x = self.drop(x)
x = self.fc2(x)
x = self.drop(x)
return x
class Attention(nn.Module):
def __init__(
self,
dim,
num_heads=8,
qkv_bias=False,
qk_scale=None,
attn_drop=0.0,
proj_drop=0.0,
sr_ratio=1,
norm_layer: str = "LayerNorm",
num_patches: Optional[int] = None
super().__init__()
assert (
dim % num_heads == 0
), f"dim {dim} should be divided by num_heads {num_heads}."
assert norm_layer in ("LayerNorm", "BatchNorm1d")
if norm_layer == "BatchNorm1d":
assert num_patches is not None
self.dim = dim
self.num_heads = num_heads
head_dim = dim // num_heads
self.scale = qk_scale or head_dim**-0.5
self.q = nn.Linear(dim, dim, bias=qkv_bias)
self.kv = nn.Linear(dim, dim * 2, bias=qkv_bias)
self.attn_drop = nn.Dropout(attn_drop)
self.proj = nn.Linear(dim, dim)
self.proj_drop = nn.Dropout(proj_drop)
self.sr_ratio = sr_ratio
if sr_ratio > 1:
self.sr = nn.Conv2d(dim, dim, kernel_size=sr_ratio, stride=sr_ratio)
if norm_layer == "LayerNorm":
self.norm = nn.LayerNorm(normalized_shape=dim)
elif norm_layer == "BatchNorm1d":
assert (num_patches % sr_ratio ** 2) == 0
self.norm = nn.BatchNorm1d(num_features=num_patches // sr_ratio**2)
m.bias.data.zero_()
B, N, C = x.shape
q = (
self.q(x)
.reshape(B, N, self.num_heads, C // self.num_heads)
.permute(0, 2, 1, 3)
if self.sr_ratio > 1:
x_ = x.permute(0, 2, 1).reshape(B, C, H, W)
x_ = self.sr(x_).reshape(B, C, -1).permute(0, 2, 1)
x_ = self.norm(x_)
kv = (
self.kv(x_)
.reshape(B, -1, 2, self.num_heads, C // self.num_heads)
.permute(2, 0, 3, 1, 4)
else:
kv = (
self.kv(x)
k, v = kv[0], kv[1]
attn = (q @ k.transpose(-2, -1)) * self.scale
attn = attn.softmax(dim=-1)
attn = self.attn_drop(attn)
x = (attn @ v).transpose(1, 2).reshape(B, N, C)
x = self.proj(x)
x = self.proj_drop(x)
return x
def drop_path(
x, drop_prob: float = 0.0, training: bool = False, scale_by_keep: bool = True
if drop_prob == 0.0 or not training:
return x
keep_prob = 1 - drop_prob
shape = (x.shape[0],) + (1,) * (
x.ndim - 1
) # work with diff dim tensors, not just 2D ConvNets
random_tensor = x.new_empty(shape).bernoulli_(keep_prob)
if keep_prob > 0.0 and scale_by_keep:
random_tensor.div_(keep_prob)
return x * random_tensor
class DropPath(nn.Module):
"""Drop paths (Stochastic Depth) per sample (when applied in main path of residual blocks)."""
def __init__(self, drop_prob: float = 0.0, scale_by_keep: bool = True):
super(DropPath, self).__init__()
self.drop_prob = drop_prob
self.scale_by_keep = scale_by_keep
def forward(self, x):
return drop_path(x, self.drop_prob, self.training, self.scale_by_keep)
def extra_repr(self):
return f"drop_prob={round(self.drop_prob,3):0.3f}"
class Block(nn.Module):
def __init__(
self,
dim,
num_heads,
mlp_ratio=4.0,
qkv_bias=False,
qk_scale=None,
drop=0.0,
attn_drop=0.0,
drop_path=0.0,
act_layer=nn.GELU,
num_features: Optional[int] = None,
sr_ratio=1,
super().__init__()
self.norm1 = nn.LayerNorm(normalized_shape=dim)
self.norm1 = nn.BatchNorm1d(num_features=num_features)
self.attn = Attention(
dim,
num_heads=num_heads,
qkv_bias=qkv_bias,
qk_scale=qk_scale,
attn_drop=attn_drop,
proj_drop=drop,
sr_ratio=sr_ratio,
norm_layer=norm_layer,
num_patches=num_features
# NOTE: drop path for stochastic depth, we shall see if this is better than dropout here
self.drop_path = DropPath(drop_path) if drop_path > 0.0 else nn.Identity()
self.norm2 = nn.LayerNorm(normalized_shape=dim)
self.norm2 = nn.BatchNorm1d(num_features=num_features)
mlp_hidden_dim = int(dim * mlp_ratio)
self.mlp = Mlp(
in_features=dim,
hidden_features=mlp_hidden_dim,
act_layer=act_layer,
drop=drop,
m.bias.data.zero_()
x = x + self.drop_path(self.attn(self.norm1(x), H, W))
x = x + self.drop_path(self.mlp(self.norm2(x), H, W))
return x
class OverlapPatchEmbed(nn.Module):
"""Image to Patch Embedding"""
def __init__(
self,
img_size=224,
patch_size=7,
stride=4,
in_chans=3,
embed_dim=768,
super().__init__()
img_size = to_2tuple(img_size)
patch_size = to_2tuple(patch_size)
self.img_size = img_size
self.patch_size = patch_size
padding_h, padding_w = patch_size[0] // 2, patch_size[1] // 2
self.H, self.W = (
(img_size[0] - patch_size[0] + 2 * padding_h) // stride + 1,
(img_size[1] - patch_size[1] + 2 * padding_w) // stride + 1,
) # changed it from original implementation mg_size[0] // patch_size, img_size[1] // patch_size
self.num_patches = (
self.H * self.W
) # computed but not used in original implementation.
self.proj = nn.Conv2d(
in_chans,
embed_dim,
kernel_size=patch_size,
stride=stride,
padding=(padding_h, padding_w),
self.norm = nn.LayerNorm(normalized_shape=embed_dim)
self.norm = nn.BatchNorm1d(num_features=self.num_patches)
m.bias.data.zero_()
x = self.proj(x)
_, _, H, W = x.shape
x = x.flatten(2).transpose(1, 2)
x = self.norm(x)
return x, H, W
def to_2tuple(x) -> Tuple[int, int]:
if isinstance(x, collections.abc.Iterable) and not isinstance(x, str):
return tuple(x)
if isinstance(x, np.ndarray) and len(x) == 2:
return tuple(x)
return tuple(repeat(x, 2))
class MixVisionTransformer(
nn.Module
): # https://github.com/NVlabs/SegFormer/blob/master/mmseg/models/backbones/mix_transformer.py
def __init__(
self,
img_size: np.ndarray = np.array([224, 224]).astype(np.uint32),
patch_size=16, # FIXME: unused. I will leave it here since this is the original implementation.
# (will be removed once Hailo will support all the layers we need)
in_chans=3,
num_classes=1000,
embed_dims=[64, 128, 256, 512],
num_heads=[1, 2, 4, 8],
mlp_ratios=[4, 4, 4, 4],
qkv_bias=False,
qk_scale=None,
drop_rate=0.0,
attn_drop_rate=0.0,
drop_path_rate=0.0,
depths=[3, 4, 6, 3],
sr_ratios=[8, 4, 2, 1],
super().__init__()
self.num_classes = num_classes
self.depths = depths
# patch_embed
self.patch_embed1 = OverlapPatchEmbed(
img_size=img_size,
patch_size=7,
stride=4,
in_chans=in_chans,
embed_dim=embed_dims[0],
self.patch_embed2 = OverlapPatchEmbed(
img_size=img_size // 4,
patch_size=3,
stride=2,
in_chans=embed_dims[0],
embed_dim=embed_dims[1],
self.patch_embed3 = OverlapPatchEmbed(
img_size=img_size // 8,
patch_size=3,
stride=2,
in_chans=embed_dims[1],
embed_dim=embed_dims[2],
self.patch_embed4 = OverlapPatchEmbed(
img_size=img_size // 16,
patch_size=3,
stride=2,
in_chans=embed_dims[2],
embed_dim=embed_dims[3],
# transformer encoder
dpr = [
x.item() for x in torch.linspace(0, drop_path_rate, sum(depths))
] # stochastic depth decay rule
cur = 0
self.block1 = nn.ModuleList(
Block(
dim=embed_dims[0],
num_heads=num_heads[0],
mlp_ratio=mlp_ratios[0],
qkv_bias=qkv_bias,
qk_scale=qk_scale,
drop=drop_rate,
attn_drop=attn_drop_rate,
drop_path=dpr[cur + i],
sr_ratio=sr_ratios[0],
num_features=(
np.prod(img_size // 4) if norm_layer == "BatchNorm1d" else None
for i in range(depths[0])
self.norm1 = nn.LayerNorm(normalized_shape=embed_dims[0])
self.norm1 = nn.BatchNorm1d(num_features=np.prod(img_size // 4))
cur += depths[0]
self.block2 = nn.ModuleList(
Block(
dim=embed_dims[1],
num_heads=num_heads[1],
mlp_ratio=mlp_ratios[1],
qkv_bias=qkv_bias,
qk_scale=qk_scale,
drop=drop_rate,
sr_ratio=sr_ratios[1],
num_features=(
np.prod(img_size // 8) if norm_layer == "BatchNorm1d" else None
for i in range(depths[1])
self.norm2 = nn.LayerNorm(normalized_shape=embed_dims[1])
self.norm2 = nn.BatchNorm1d(num_features=np.prod(img_size // 8))
cur += depths[1]
self.block3 = nn.ModuleList(
Block(
dim=embed_dims[2],
num_heads=num_heads[2],
mlp_ratio=mlp_ratios[2],
qkv_bias=qkv_bias,
qk_scale=qk_scale,
drop=drop_rate,
sr_ratio=sr_ratios[2],
num_features=(
np.prod(img_size // 16) if norm_layer == "BatchNorm1d" else None
for i in range(depths[2])
self.norm3 = nn.LayerNorm(normalized_shape=embed_dims[2])
self.norm3 = nn.BatchNorm1d(num_features=np.prod(img_size // 16))
cur += depths[2]
self.block4 = nn.ModuleList(
Block(
dim=embed_dims[3],
num_heads=num_heads[3],
mlp_ratio=mlp_ratios[3],
qkv_bias=qkv_bias,
qk_scale=qk_scale,
drop=drop_rate,
sr_ratio=sr_ratios[3],
num_features=(
np.prod(img_size // 32) if norm_layer == "BatchNorm1d" else None
for i in range(depths[3])
self.norm4 = nn.LayerNorm(normalized_shape=embed_dims[3])
self.norm4 = nn.BatchNorm1d(num_features=np.prod(img_size // 32))
# classification head
# self.head = nn.Linear(embed_dims[3], num_classes) if num_classes > 0 else nn.Identity()
m.bias.data.zero_()
def reset_drop_path(self, drop_path_rate):
dpr = [x.item() for x in torch.linspace(0, drop_path_rate, sum(self.depths))]
cur = 0
for i in range(self.depths[0]):
self.block1[i].drop_path.drop_prob = dpr[cur + i]
cur += self.depths[0]
for i in range(self.depths[1]):
self.block2[i].drop_path.drop_prob = dpr[cur + i]
cur += self.depths[1]
for i in range(self.depths[2]):
self.block3[i].drop_path.drop_prob = dpr[cur + i]
cur += self.depths[2]
for i in range(self.depths[3]):
self.block4[i].drop_path.drop_prob = dpr[cur + i]
def freeze_patch_emb(self):
self.patch_embed1.requires_grad = False
@torch.jit.ignore
def no_weight_decay(self):
return {
"pos_embed1",
"pos_embed2",
"pos_embed3",
"pos_embed4",
"cls_token",
} # has pos_embed may be better
def get_classifier(self):
return self.head
def reset_classifier(self, num_classes, global_pool=""):
self.head = (
nn.Linear(self.embed_dim, num_classes) if num_classes > 0 else nn.Identity()
def forward_features(self, x):
B = x.shape[0]
outs = []
# stage 1
x, H, W = self.patch_embed1(x)
for i, blk in enumerate(self.block1):
x = blk(x, H, W)
x = self.norm1(x)
x = x.reshape(B, H, W, -1).permute(0, 3, 1, 2).contiguous()
outs.append(x)
# stage 2
x, H, W = self.patch_embed2(x)
for i, blk in enumerate(self.block2):
x = blk(x, H, W)
x = self.norm2(x)
outs.append(x)
# stage 3
x, H, W = self.patch_embed3(x)
for i, blk in enumerate(self.block3):
x = blk(x, H, W)
x = self.norm3(x)
outs.append(x)
# stage 4
x, H, W = self.patch_embed4(x)
for i, blk in enumerate(self.block4):
x = blk(x, H, W)
x = self.norm4(x)
outs.append(x)
return outs
x = self.forward_features(x)
# x = self.head(x)
return x
class DWConv(nn.Module):
def __init__(self, dim=768):
super(DWConv, self).__init__()
self.dwconv = nn.Conv2d(dim, dim, 3, 1, 1, bias=True, groups=dim)
B, N, C = x.shape
x = x.transpose(1, 2).view(B, C, H, W)
x = self.dwconv(x)
return x
class MiTB0(MixVisionTransformer):
def __init__(self, in_channels: int, img_size: np.ndarray, norm_layer: str):
super().__init__(
in_chans=in_channels,
img_size=img_size,
patch_size=4,
embed_dims=[32, 64, 160, 256],
num_heads=[1, 2, 5, 8],
qkv_bias=True,
depths=[2, 2, 2, 2],
drop_rate=0.0,
drop_path_rate=0.1,
class MLPDecoder(nn.Module):
def __init__(
self,
embed_dims: List[int],
decoder_embed_dim: int,
num_classes: int,
dropout_prob: float = 0.0,
super().__init__()
self.linear_layers = nn.ModuleList(
[MLP(embedding_dim, decoder_embed_dim) for embedding_dim in embed_dims]
self.relu = nn.ReLU()
n_stages = len(embed_dims)
self.linear_fuse = nn.Conv2d(
in_channels=decoder_embed_dim * n_stages,
out_channels=decoder_embed_dim,
kernel_size=1,
self.dropout = nn.Dropout(dropout_prob)
self.linear_pred = nn.Conv2d(decoder_embed_dim, num_classes, kernel_size=1)
def forward(self, features: List[torch.Tensor]):
new_features = []
target_resolution = features[0].shape[2:] # In the original implementation
# this resolution corresponds to (H/4,W/4), where H and W are the height and width of the original image.
for i in range(len(features)):
encoder_output = features[i]
n, _, h, w = encoder_output.shape
out = self.linear_layers[i](encoder_output)
out = nlc_to_nchw(out, h, w)
up_sampled_out = F.interpolate(
out, size=target_resolution, mode="bilinear", align_corners=False
new_features.append(up_sampled_out)
x = torch.cat(new_features, 1)
x = self.relu(self.linear_fuse(x))
x = self.dropout(x)
x = self.linear_pred(x)
return x
class SegFormerOriginalWithBatchNorm(torch.nn.Module):
def __init__(self, in_channels: int, img_size_hw: Tuple[int, int], num_classes: int):
super().__init__()
if isinstance(img_size_hw, list):
img_size_hw = tuple(img_size_hw)
assert isinstance(img_size_hw, tuple) and len(img_size_hw) == 2
self.encoder = MiTB0(in_channels=in_channels, img_size=np.array(img_size_hw), norm_layer="BatchNorm1d")
self.decoder = MLPDecoder(
embed_dims=[32, 64, 160, 256], decoder_embed_dim=256, num_classes=num_classes
def forward(self, x: torch.Tensor):
features = self.encoder(x)
out = self.decoder(features)
logits_mask = F.interpolate(out, size=x.shape[2:], mode="bilinear", align_corners=False)
return logits_mask
How I export the model:
model = SegFormerOriginalWithBatchNorm(in_channels=3, num_classes=2, img_size_hw=(256, 128))
input_shape_bchw = (1, 3, 256, 128)
tmp_onnx_output_path = "SegFormerOriginalWithBatchNorm.onnx"
# Export .ONNX succesfully.
convert_pytorch_2_onnx(torch_model=model, input_shape_bchw=input_shape_bchw, output_path=tmp_onnx_output_path)
tmp_har_path = "SegFormerOriginalWithBatchNorm.har"
# Crashes here
convert_onnx_2_har(onnx_path=tmp_onnx_output_path, har_path=tmp_har_path, input_shape_bchw=input_shape_bchw)
convert_torch_module_2_hef(
torch_module=model,
hef_path="MyTest.hef",
npy_rgb_unnormalized_bhwc_calibration_dataset_path=npy_calibration_dataset_path,
apply_normalization=True
Conversion functions:
import os
import pathlib
from typing import Union, Tuple, Optional, List, Dict
import onnx # ==1.14.0
import torch # ==2.3.0
def convert_pytorch_2_onnx(torch_model: torch.nn.Module, input_shape_bchw: Tuple[int, int, int, int], output_path: Union[str, pathlib.Path]) -> None:
torch_input = torch.randn(input_shape_bchw)
torch_model.eval()
torch.onnx.export(
torch_model,
torch_input,
str(output_path),
verbose=False,
do_constant_folding=False,
opset_version=15, # Use the appropriate ONNX opset version
input_names=["input"],
output_names=['output']
onnx_model = onnx.load(str(output_path))
onnx.checker.check_model(onnx_model)
def convert_onnx_2_har(
onnx_path: Union[str, pathlib.Path],
har_path: Union[str, pathlib.Path],
hw_arch: str = "hailo8",
from hailo_sdk_client import ClientRunner, InferenceContext # noqa hailo_sdk_client==3.27.0
onnx_model_name = pathlib.Path(onnx_path).stem
onnx_model = onnx.load(onnx_path)
onnx_inputs = onnx_model.graph.input
onnx_outputs = onnx_model.graph.output
start_node_name = onnx_inputs[0].name
end_node_name = onnx_outputs[0].name
runner = ClientRunner(hw_arch=hw_arch)
_ = runner.translate_onnx_model(
str(onnx_path),
onnx_model_name,
start_node_names=[start_node_name],
end_node_names=[end_node_name],
net_input_shapes={start_node_name: input_shape_bchw}
runner.save_har(str(har_path))
test_images_bchw = np.random.randint(0, 255, size=input_shape_bchw)
b,c,h,w = input_shape_bchw
# test_images_bhwc = np.random.randint(0, 255, size=(b,h,w,c))
with runner.infer_context(InferenceContext.SDK_NATIVE) as ctx:
# CRASHES here.
native_res = runner.infer(ctx, test_images_bchw)
