Got the following error:
hailo_platform.pyhailort.pyhailort.HailoRTPCIeDriverException: PCIe driver failure. run ‘dmesg | grep hailo’ for more information
This is the the dmesg content:
[ 2.575005] hailo: Init module. driver version 4.18.0
[ 2.583826] hailo 0000:01:00.0: Probing on: 1e60:2864…
[ 2.583836] hailo 0000:01:00.0: Probing: Allocate memory for device extension, 11632
[ 2.583856] hailo 0000:01:00.0: enabling device (0000 → 0002)
[ 2.583863] hailo 0000:01:00.0: Probing: Device enabled
[ 2.583888] hailo 0000:01:00.0: Probing: mapped bar 0 - 000000000adf7cc2 16384
[ 2.583896] hailo 0000:01:00.0: Probing: mapped bar 2 - 000000007cc172d9 4096
[ 2.583901] hailo 0000:01:00.0: Probing: mapped bar 4 - 0000000009d1b539 16384
[ 2.583905] hailo 0000:01:00.0: Probing: Force setting max_desc_page_size to 4096 (recommended value is 16384)
[ 2.583914] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[ 2.583919] hailo 0000:01:00.0: Probing: Using userspace allocated vdma buffers
[ 2.583927] hailo 0000:01:00.0: Disabling ASPM L0s
[ 2.583932] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[ 2.767743] hailo 0000:01:00.0: Firmware was loaded successfully
[ 2.791993] hailo 0000:01:00.0: Probing: Added board 1e60-2864, /dev/hailo0
[ 1722.674712] hailo 0000:01:00.0: hailo_pcie_driver_down, timeout waiting for shutdown response (timeout_ms=5)
[ 1722.674722] hailo 0000:01:00.0: Failed sending FW shutdown event
[ 2038.785292] hailo 0000:01:00.0: Device disconnected while opening device
Any idea what can be the issue? I’m using Hailo 8L
