I am having issues using the hailo ai kit board on rpi, I have the 26 TFLOPS one.
I tried to install the hailo drivers on different Pi5 and always had the same error.
I have followed the official Hailo guide but this is what happens after “sudo modprobe hailo_pci”
What is wrong here?
[ 123.230214] hailo: Init module. driver version 4.20.0
[ 123.230306] hailo 0000:01:00.0: Probing on: 1e60:2864...
[ 123.230309] hailo 0000:01:00.0: Probing: Allocate memory for device extension, 13184
[ 123.230319] hailo 0000:01:00.0: Probing: Device enabled
[ 123.230336] hailo 0000:01:00.0: Probing: mapped bar 0 - 000000002f436a73 16384
[ 123.230340] hailo 0000:01:00.0: Probing: mapped bar 2 - 000000002b921c0a 4096
[ 123.230343] hailo 0000:01:00.0: Probing: mapped bar 4 - 000000005ef1b002 16384
[ 123.230346] hailo 0000:01:00.0: Probing: Force setting max_desc_page_size to 128 (recommended value is 16384)
[ 123.230355] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[ 123.230357] hailo 0000:01:00.0: Probing: Using userspace allocated vdma buffers
[ 123.230360] hailo 0000:01:00.0: Disabling ASPM L0s
[ 123.230363] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[ 123.230424] hailo 0000:01:00.0: Writing file hailo/hailo8_fw.bin
[ 123.230741] hailo 0000:01:00.0: File hailo/hailo8_fw.bin written successfully
[ 123.230745] hailo 0000:01:00.0: Writing file hailo/hailo8_board_cfg.bin
[ 123.230752] Failed to write file hailo/hailo8_board_cfg.bin
[ 123.230753] hailo 0000:01:00.0: File hailo/hailo8_board_cfg.bin written successfully
[ 123.230754] hailo 0000:01:00.0: Writing file hailo/hailo8_fw_cfg.bin
[ 123.230760] Failed to write file hailo/hailo8_fw_cfg.bin
[ 123.230761] hailo 0000:01:00.0: File hailo/hailo8_fw_cfg.bin written successfully
[ 128.475067] hailo 0000:01:00.0: Timeout waiting for NNC firmware file, boot status 4294967295
[ 128.475075] hailo 0000:01:00.0: FW loaded, took 5244 ms
[ 128.475133] hailo 0000:01:00.0: Firmware load failed
[ 128.475135] hailo 0000:01:00.0: Failed activating board -110
[ 128.475157] hailo: probe of 0000:01:00.0 failed with error -110
