Fresh Setup Having Issues With Failed Written .bin Files
Howdy y’all! I am in the process of setting of my Pi5 with the Hailo8 Hat, and I am running into an issue that is kind of answered in other forums and topics. My issue is just a tad wonkier.
I did a fresh update and install of both Pi and Hailo software. Everything was going smoothly with no issues until I started to play around with the Demos. Once I reached Segmentation and Pose Estimation, I couldn’t get it to work.
running dmesg | grep -i hailo provides this string of checks:
[ 2.338337] hailo: Init module. driver version 4.20.0
[ 2.338428] hailo 0000:01:00.0: Probing on: 1e60:2864…
[ 2.338432] hailo 0000:01:00.0: Probing: Allocate memory for device extension, 13184
[ 2.338450] hailo 0000:01:00.0: enabling device (0000 → 0002)
[ 2.338454] hailo 0000:01:00.0: Probing: Device enabled
[ 2.338470] hailo 0000:01:00.0: Probing: mapped bar 0 - 00000000fcbba926 16384
[ 2.338475] hailo 0000:01:00.0: Probing: mapped bar 2 - 00000000bfe2ff22 4096
[ 2.338478] hailo 0000:01:00.0: Probing: mapped bar 4 - 00000000fd109731 16384
[ 2.338481] hailo 0000:01:00.0: Probing: Force setting max_desc_page_size to 4096 (recommended value is 16384)
[ 2.338491] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[ 2.338493] hailo 0000:01:00.0: Probing: Using userspace allocated vdma buffers
[ 2.338496] hailo 0000:01:00.0: Disabling ASPM L0s
[ 2.338499] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[ 2.338584] hailo 0000:01:00.0: Writing file hailo/hailo8_fw.bin
[ 2.486196] hailo 0000:01:00.0: File hailo/hailo8_fw.bin written successfully
[ 2.486201] hailo 0000:01:00.0: Writing file hailo/hailo8_board_cfg.bin
[ 2.486226] Failed to write file hailo/hailo8_board_cfg.bin
[ 2.486227] hailo 0000:01:00.0: File hailo/hailo8_board_cfg.bin written successfully
[ 2.486228] hailo 0000:01:00.0: Writing file hailo/hailo8_fw_cfg.bin
[ 2.486235] Failed to write file hailo/hailo8_fw_cfg.bin
[ 2.486236] hailo 0000:01:00.0: File hailo/hailo8_fw_cfg.bin written successfully
[ 2.575516] hailo 0000:01:00.0: NNC Firmware loaded successfully
[ 2.575524] hailo 0000:01:00.0: FW loaded, took 236 ms
[ 2.588260] hailo 0000:01:00.0: Probing: Added board 1e60-2864, /dev/hailo0
(venv_hailo_rpi5_examples) pi@aipi:~/hailo-rpi5-examples $
I have tried finding these files in my Hailo folders without luck. I noticed on some other forum pages here on Hailo, that other users are needing to modify .json files. If that is the case, I appear to be missing certain files that would need editing or have the path updated.
I tried downgrading my Hailo Hat to 4.18 but that entirely broke everything, so I reverted back to 4.20. I have not tried downgrading to 4.19 to see if that solves my issue yet but that is next on my list. If anyone has any suggestions, I would be very grateful!
This is not an issue. It is the expected behavior.
Thank you for getting back to me! Seeing the couple failed files was bothering me. I’m glad to know this is something common. These two fails wouldn’t cause any issues with performance, would they? I’m very new and don’t quite know everything there is to know.
No, they do not. You can ignore these.
Perfect. Thank you very much for the assistance!
