I am trying to use hailo8l on my amd64 system.
I can see the device via lspci:
02:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
when I run dmesg | grep hailo I get
[ 3.898811] hailo_pci: loading out-of-tree module taints kernel.
[ 3.898861] hailo_pci: module verification failed: signature and/or required key missing - tainting kernel
[ 3.901957] hailo: Init module. driver version 4.18.0
[ 3.902280] hailo 0000:02:00.0: Probing on: 1e60:2864...
[ 3.902282] hailo 0000:02:00.0: Probing: Allocate memory for device extension, 11632
[ 3.902289] hailo 0000:02:00.0: enabling device (0000 -> 0002)
[ 3.902623] hailo 0000:02:00.0: Probing: Device enabled
[ 3.902642] hailo 0000:02:00.0: Probing: mapped bar 0 - 000000009c44258f 16384
[ 3.902646] hailo 0000:02:00.0: Probing: mapped bar 2 - 0000000079907a13 4096
[ 3.902650] hailo 0000:02:00.0: Probing: mapped bar 4 - 000000002c27c7e4 16384
[ 3.902653] hailo 0000:02:00.0: Probing: Setting max_desc_page_size to 4096, (page_size=4096)
[ 3.902691] hailo 0000:02:00.0: Probing: Enabled 64 bit dma
[ 3.902692] hailo 0000:02:00.0: Probing: Using specialized dma_ops=iommu_dma_ops
[ 3.902697] hailo 0000:02:00.0: Probing: Using userspace allocated vdma buffers
[ 3.902699] hailo 0000:02:00.0: Disabling ASPM L0s
[ 3.902701] hailo 0000:02:00.0: Successfully disabled ASPM L0s
[ 3.904087] hailo 0000:02:00.0: firmware: failed to load hailo/hailo8_board_cfg.bin (-2)
[ 3.904102] hailo 0000:02:00.0: firmware: failed to load hailo/hailo8_board_cfg.bin (-2)
[ 3.904112] hailo 0000:02:00.0: firmware: failed to load hailo/hailo8_fw_cfg.bin (-2)
[ 3.904118] hailo 0000:02:00.0: firmware: failed to load hailo/hailo8_fw_cfg.bin (-2)
[ 3.904935] hailo 0000:02:00.0: firmware: direct-loading firmware hailo/hailo8_fw.bin
[ 4.032284] hailo 0000:02:00.0: Firmware was loaded successfully
[ 4.047985] hailo 0000:02:00.0: Probing: Added board 1e60-2864, /dev/hailo0
[ 113.951565] hailo 0000:02:00.0: Invalid general ioctl code 0x400c6705 (nr: 5)
[ 148.404594] hailo 0000:02:00.0: Invalid general ioctl code 0x400c6705 (nr: 5)
[ 187.880718] hailo 0000:02:00.0: Invalid general ioctl code 0x400c6705 (nr: 5)
[ 221.368616] hailo 0000:02:00.0: Invalid general ioctl code 0x400c6705 (nr: 5)
[ 254.911028] hailo 0000:02:00.0: Invalid general ioctl code 0x400c6705 (nr: 5)
[ 288.909124] hailo 0000:02:00.0: Invalid general ioctl code 0x400c6705 (nr: 5)
let me know what other information will be helpful
