I have rk3568. After installing driver and rebooting graphic interface of the system stops working, but the system in general has no problems, I can still do anything with via ssh. Here dmesg | grep hailo:
[ 14.374563] hailo_pci: loading out-of-tree module taints kernel.
[ 14.377580] hailo: Init module. driver version 4.20.1
[ 14.377923] hailo 0001:11:00.0: Probing on: 1e60:2864…
[ 14.377949] hailo 0001:11:00.0: Probing: Allocate memory for device extension, 13376
[ 14.378003] hailo 0001:11:00.0: enabling device (0000 → 0002)
[ 14.378028] hailo 0001:11:00.0: Probing: Device enabled
[ 14.378109] hailo 0001:11:00.0: Probing: mapped bar 0 - 00000000425938b0 16384
[ 14.378132] hailo 0001:11:00.0: Probing: mapped bar 2 - 00000000256510d3 4096
[ 14.378147] hailo 0001:11:00.0: Probing: mapped bar 4 - 00000000a5a966fb 16384
[ 14.378158] hailo 0001:11:00.0: Probing: Force setting max_desc_page_size to 128 (recommended value is 4096)
[ 14.378196] hailo 0001:11:00.0: Probing: Enabled 64 bit dma
[ 14.378204] hailo 0001:11:00.0: Probing: Using driver allocated vdma buffers
[ 14.378219] hailo 0001:11:00.0: Disabling ASPM L0s
[ 14.378231] hailo 0001:11:00.0: Successfully disabled ASPM L0s
[ 14.378644] hailo 0001:11:00.0: Writing file hailo/hailo8_fw.bin
[ 14.471345] hailo 0001:11:00.0: File hailo/hailo8_fw.bin written successfully
[ 14.471380] hailo 0001:11:00.0: Writing file hailo/hailo8_board_cfg.bin
[ 14.471519] Failed to write file hailo/hailo8_board_cfg.bin
[ 14.471527] hailo 0001:11:00.0: File hailo/hailo8_board_cfg.bin written successfully
[ 14.471535] hailo 0001:11:00.0: Writing file hailo/hailo8_fw_cfg.bin
[ 14.471583] Failed to write file hailo/hailo8_fw_cfg.bin
[ 14.471590] hailo 0001:11:00.0: File hailo/hailo8_fw_cfg.bin written successfully
[ 14.577276] hailo 0001:11:00.0: NNC Firmware loaded successfully
[ 14.577312] hailo 0001:11:00.0: FW loaded, took 198 ms
[ 14.589436] hailo 0001:11:00.0: Probing: Added board 1e60-2864, /dev/hailo0
I was experimenting with the version of driver and max_desc_page_size parameter, but nothing changes. Are there any additional hardware requirements, which my board might not provide? Because with rk3588 everything was working
