Hi, i am trying to develop my own script for CV suing my hailo 8l. I already did several tutorials but i don’t want to copy paste all this code in to my own applications. Therefore, I am trying to make a script as simple as possible (where the highest performance is not necessary) and afterwards start trying more advance methodologies.
Following the hailort user guide for python inference (5.5. Python Inference Tutorial - Single Model). Which for me looks the easiest since you don’t need to control the scheduler.
My sctript looks as follows:
import cv2
from PIL import Image
from hailo_platform import (HEF, VDevice, HailoStreamInterface, InferVStreams,ConfigureParams, HailoSchedulingAlgorithm,
InputVStreamParams, OutputVStreamParams, InputVStreams, OutputVStreams,
FormatType)
# The target can be used as a context manager (”with” statement) to ensure it's released on time.
# Here it's avoided for the sake of simplicity
def preprocess_frame(frame,image_height, image_width, channels):
print(f"chanels: {channels}\nframe_shape: {frame.shape}")
input_data = cv2.resize(frame, (image_height, image_width))
input_data = input_data.astype(np.float32) / 255.0
#input_data = np.transpose(input_data, (2, 0, 1)) # Change to CHW format
input_data = np.expand_dims(input_data, axis=0) # Add batch dimension
return input_data
target = VDevice()
# Loading compiled HEFs to device:
model_name = 'yolov6n'
hef_path = '{}.hef'.format(model_name)
hef = HEF(hef_path)
# Configure network groups
configure_params = ConfigureParams.create_from_hef(hef=hef,interface=HailoStreamInterface.PCIe)
# Create input and output virtual streams params
input_vstreams_params = InputVStreamParams.make(network_group, format_type=FormatType.FLOAT32)
output_vstreams_params = OutputVStreamParams.make(network_group, format_type=FormatType.FLOAT32)
# Define dataset params
# Generate random dataset
image = cv2.imread("Input/im0.jpg")
input_frame = preprocess_frame(image,image_height, image_width, channels)
print(f"input stream shape: {input_vstream_info.shape}, frame shape{input_frame.shape}\n desired output shape {output_vstream_info.shape}")
#Infer
input_data = {input_vstream_info.name: input_frame}
print('Stream output is {}'.format(infer_results[output_vstream_info.name]))
Running this, I obtain the following result:
(custom_camera_cv_env) rpi@raspberrypi:~/Scripts/hailo_process_frame $ python3 test2.py
chanels: 3
frame_shape: (480, 640, 3)
input stream shape: (640, 640, 3), frame shape(1, 640, 640, 3)
desired output shape (80, 5, 100)
Stream output is [[array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64), array([], shape=(0, 5), dtype=float64)]]
Which obiously does not make much sense.
Inspecting the hailort.log i find:
[2024-10-12 12:44:20.306] [4278] [HailoRT] [info] [device.cpp:46] [Device] OS Version: Linux 6.6.51+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08) aarch64
[2024-10-12 12:44:20.306] [4278] [HailoRT] [info] [control.cpp:100] [control__parse_identify_results] firmware_version is: 4.18.0
[2024-10-12 12:44:20.306] [4278] [HailoRT] [info] [vdevice.cpp:652] [create] VDevice Infos: 0000:04:00.0
[2024-10-12 12:44:20.388] [4278] [HailoRT] [info] [internal_buffer_manager.cpp:202] [print_execution_results] Default Internal buffer planner failed to meet requirements
[2024-10-12 12:44:20.388] [4278] [HailoRT] [info] [internal_buffer_manager.cpp:212] [print_execution_results] Default Internal buffer planner executed successfully
[2024-10-12 12:44:20.399] [4278] [HailoRT] [info] [device_internal.cpp:57] [configure] Configuring HEF took 15.794048 milliseconds
[2024-10-12 12:44:20.399] [4278] [HailoRT] [info] [vdevice.cpp:751] [configure] Configuring HEF on VDevice took 16.244344 milliseconds
[2024-10-12 12:44:20.399] [4278] [HailoRT] [info] [hef.cpp:1844] [get_network_group_and_network_name] No name was given. Addressing all networks of default network_group: yolov6n
[2024-10-12 12:44:20.415] [4278] [HailoRT] [info] [edge_elements.cpp:52] [create] Created (HwWriteEl3yolov6n/input_layer1 | hw_frame_size: 1228800)
[2024-10-12 12:44:20.415] [4278] [HailoRT] [info] [queue_elements.cpp:255] [create] Created (PushQEl3yolov6n/input_layer1 | timeout: 10s)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [filter_elements.cpp:101] [create] Created (PreInferEl3yolov6n/input_layer1 | Quantization - src_type: FLOAT32, dst_type UINT8, limvals_min: 0, limvals_max: 255 | Reorder - src_order: NHWC, src_shape: (640, 640, 3), dst_order: NHCW, dst_shape: (640, 640, 3))
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [vstream.cpp:754] [InputVStreamImpl] Creating yolov6n/input_layer1...
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [vstream_builder.cpp:102] [create_inputs] Input pipeline 'yolov6n/input_layer1': (PreInferEl3yolov6n/input_layer1 | Quantization - src_type: FLOAT32, dst_type UINT8, limvals_min: 0, limvals_max: 255 | Reorder - src_order: NHWC, src_shape: (640, 640, 3), dst_order: NHCW, dst_shape: (640, 640, 3)) >> (PushQEl3yolov6n/input_layer1 | timeout: 10s) >> (HwWriteEl3yolov6n/input_layer1 | hw_frame_size: 1228800) >> HW
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [multi_io_elements.cpp:159] [create] Created (NmsPPMuxEl0YOLOX-Post-Process | Op YOLOX, Name: YOLOX-Post-Process, Score threshold: 0.200, IoU threshold: 0.65, Classes: 80, Cross classes: false, Max bboxes per class: 100, Image height: 640, Image width: 640)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl2yolov6n/conv36_70 | hw_frame_size: 512000)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms2yolov6n/conv36_70 | timeout: 10s)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl1yolov6n/conv37_70 | hw_frame_size: 25600)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms1yolov6n/conv37_70 | timeout: 10s)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl0yolov6n/conv38_70 | hw_frame_size: 6400)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms0yolov6n/conv38_70 | timeout: 10s)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl9yolov6n/conv47_70 | hw_frame_size: 128000)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms9yolov6n/conv47_70 | timeout: 10s)
[2024-10-12 12:44:20.418] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl6yolov6n/conv48_70 | hw_frame_size: 6400)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms6yolov6n/conv48_70 | timeout: 10s)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl7yolov6n/conv49_70 | hw_frame_size: 1600)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms7yolov6n/conv49_70 | timeout: 10s)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl4yolov6n/conv57_70 | hw_frame_size: 38400)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms4yolov6n/conv57_70 | timeout: 10s)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl8yolov6n/conv58_70 | hw_frame_size: 1920)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms8yolov6n/conv58_70 | timeout: 10s)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [edge_elements.cpp:287] [create] Created (HwReadEl5yolov6n/conv59_70 | hw_frame_size: 480)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [queue_elements.cpp:613] [create] Created (PullQEl_nms5yolov6n/conv59_70 | timeout: 10s)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [queue_elements.cpp:756] [create] Created (UserBufQEl_post_infer0yolov6n/yolox_nms_postprocess | timeout: 10s)
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [vstream.cpp:1107] [OutputVStreamImpl] Creating yolov6n/yolox_nms_postprocess...
[2024-10-12 12:44:20.419] [4278] [HailoRT] [info] [vstream_builder.cpp:627] [create_output_post_process_nms] Output pipeline 'yolov6n/yolox_nms_postprocess': HW >> (HwReadEl2yolov6n/conv36_70 | hw_frame_size: 512000) >> (PullQEl_nms2yolov6n/conv36_70) >> (HwReadEl1yolov6n/conv37_70 | hw_frame_size: 25600) >> (PullQEl_nms1yolov6n/conv37_70) >> (HwReadEl0yolov6n/conv38_70 | hw_frame_size: 6400) >> (PullQEl_nms0yolov6n/conv38_70) >> (HwReadEl9yolov6n/conv47_70 | hw_frame_size: 128000) >> (PullQEl_nms9yolov6n/conv47_70) >> (HwReadEl6yolov6n/conv48_70 | hw_frame_size: 6400) >> (PullQEl_nms6yolov6n/conv48_70) >> (HwReadEl7yolov6n/conv49_70 | hw_frame_size: 1600) >> (PullQEl_nms7yolov6n/conv49_70) >> (HwReadEl4yolov6n/conv57_70 | hw_frame_size: 38400) >> (PullQEl_nms4yolov6n/conv57_70) >> (HwReadEl8yolov6n/conv58_70 | hw_frame_size: 1920) >> (PullQEl_nms8yolov6n/conv58_70) >> (HwReadEl5yolov6n/conv59_70 | hw_frame_size: 480) >> (PullQEl_nms5yolov6n/conv59_70) >> (NmsPPMuxEl0YOLOX-Post-Process | Op YOLOX, Name: YOLOX-Post-Process, Score threshold: 0.200, IoU threshold: 0.65, Classes: 80, Cross classes: false, Max bboxes per class: 100, Image height: 640, Image width: 640) >> (UserBufQEl_post_infer0yolov6n/yolox_nms_postprocess | timeout: 10s)
[2024-10-12 12:44:20.420] [4278] [HailoRT] [info] [core_op.cpp:156] [activate] Activating yolov6n took 0.729222 milliseconds. Note that the function is asynchronous and thus the network is not fully activated yet.
[2024-10-12 12:44:20.420] [4278] [HailoRT] [info] [core_op.cpp:156] [activate] Activating yolov6n took 0.740055 milliseconds. Note that the function is asynchronous and thus the network is not fully activated yet.
[2024-10-12 12:44:20.437] [4304] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4305] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4309] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4302] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4301] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4303] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4307] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4306] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4308] [HailoRT] [info] [vdevice_native_stream.cpp:331] [read_impl] Failed read from stream HAILO_STREAM_NOT_ACTIVATED(72) (device: 0000:04:00.0)
[2024-10-12 12:44:20.437] [4278] [HailoRT] [info] [core_op.cpp:186] [deactivate] Deactivating took 0.567851 ms
[2024-10-12 12:44:20.437] [4278] [HailoRT] [info] [core_op.cpp:186] [deactivate] Deactivating took 0.582555 ms
[2024-10-12 12:44:20.437] [4302] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms1yolov6n/conv37_70!
[2024-10-12 12:44:20.437] [4305] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms6yolov6n/conv48_70!
[2024-10-12 12:44:20.438] [4307] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms4yolov6n/conv57_70!
[2024-10-12 12:44:20.438] [4301] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms2yolov6n/conv36_70!
[2024-10-12 12:44:20.438] [4306] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms7yolov6n/conv49_70!
[2024-10-12 12:44:20.438] [4303] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms0yolov6n/conv38_70!
[2024-10-12 12:44:20.438] [4304] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms9yolov6n/conv47_70!
[2024-10-12 12:44:20.438] [4308] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms8yolov6n/conv58_70!
[2024-10-12 12:44:20.438] [4309] [HailoRT] [info] [queue_elements.cpp:690] [run_in_thread] Shutdown event was signaled in run_pull of queue element PullQEl_nms5yolov6n/conv59_70!
[2024-10-12 12:44:20.438] [4310] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element UserBufQEl_post_infer0yolov6n/yolox_nms_postprocess is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element UserBufQEl_post_infer0yolov6n/yolox_nms_postprocess has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4309] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms5yolov6n/conv59_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms5yolov6n/conv59_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4308] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms8yolov6n/conv58_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms8yolov6n/conv58_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4307] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms4yolov6n/conv57_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms4yolov6n/conv57_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4306] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms7yolov6n/conv49_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms7yolov6n/conv49_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4305] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms6yolov6n/conv48_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms6yolov6n/conv48_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4304] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms9yolov6n/conv47_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms9yolov6n/conv47_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4303] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms0yolov6n/conv38_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms0yolov6n/conv38_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4302] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms1yolov6n/conv37_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms1yolov6n/conv37_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4301] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PullQEl_nms2yolov6n/conv36_70 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PullQEl_nms2yolov6n/conv36_70 has 0 frames in his Queue on destruction
[2024-10-12 12:44:20.438] [4300] [HailoRT] [info] [queue_elements.cpp:54] [operator()] Thread in element PushQEl3yolov6n/input_layer1 is not running anymore, exiting..
[2024-10-12 12:44:20.438] [4278] [HailoRT] [info] [queue_elements.cpp:43] [~BaseQueueElement] Queue element PushQEl3yolov6n/input_layer1 has 0 frames in his Queue on destruction
Could someone help me address the issue. Not sure what is going on.
Regards,
Laurens
