Inference worked fine when it was a .har file. I compiled it, following the DFC tutorials, and now I get this error regarding output when following the HRT_0_Async_Inference_Tutorial
Why is the output buffer 4 times smaller than the expected?
/tmp/ipykernel_5482/2010725074.py:23: RuntimeWarning: invalid value encountered in cast
buffer = np.empty(infer_model.output().shape).astype(np.uint8)
[HailoRT] [error] CHECK failed - Output buffer size 1002 is different than expected 4008 for output 'yolo11n_visdrone/yolov8_nms_postprocess'
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_INVALID_OPERATION(6)
HailoRTStatusException Traceback (most recent call last)
File /usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py:3286, in ConfiguredInferModel.run_async(self, bindings, callback)
3285 with ExceptionWrapper():
-> 3286 cpp_job = self._configured_infer_model.run_async(
3287 [b.get() for b in bindings], callback_wrapper
3288 )
3290 job = AsyncInferJob(cpp_job)
HailoRTStatusException: 6
HailoRTInvalidOperationException Traceback (most recent call last)
Cell In[2], line 27
24 bindings.output().set_buffer(buffer)
26 # Run synchronous inference and access the output buffers
---> 27 configured_infer_model.run([bindings], timeout_ms)
28 buffer = bindings.output().get_buffer()
30 # Run asynchronous inference
File /usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py:3236, in ConfiguredInferModel.run(self, bindings, timeout)
3223 def run(self, bindings, timeout):
3224 """
3225 Launches a synchronous inference operation with the provided bindings.
3226
(...) 3234 :class:`HailoRTTimeout` in case the job did not finish in the given timeout.
3235 """
-> 3236 with ExceptionWrapper():
3237 job = self.run_async(bindings)
3238 job.wait(timeout)
File /usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py:3237, in ConfiguredInferModel.run(self, bindings, timeout)
3224 """
3226
3235 """
-> 3237 job = self.run_async(bindings)
File /usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py:3285, in ConfiguredInferModel.run_async(self, bindings, callback)
3282 # remove the buffers - they are no longer needed
3283 self._buffer_guards.popleft()
-> 3285 with ExceptionWrapper():
3288 )
File /usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py:118, in ExceptionWrapper.__exit__(self, exception_type, value, traceback)
116 if value is not None:
117 if exception_type is _pyhailort.HailoRTStatusException:
--> 118 self._raise_indicative_status_exception(value)
119 else:
120 raise
File /usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py:166, in ExceptionWrapper._raise_indicative_status_exception(self, libhailort_exception)
164 def _raise_indicative_status_exception(self, libhailort_exception):
165 error_code = int(libhailort_exception.args[0])
--> 166 raise self.create_exception_from_status(error_code) from libhailort_exception
HailoRTInvalidOperationException: Invalid operation. See hailort.log for more information
I checked the Hailort.log file and there wasn’t a great deal in there that seems helpful beyond what was already in the error message, but this was a snippet from that:
[2025-03-20 09:56:39.446] [5482] [HailoRT] [info] [vdevice.cpp:523] [create] Creating vdevice with params: device_count: 1, scheduling_algorithm: ROUND_ROBIN, multi_process_service: false
[2025-03-20 09:56:39.457] [5482] [HailoRT] [info] [device.cpp:49] [Device] OS Version: Linux 6.6.74+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.74-1+rpt1 (2025-01-27) aarch64
[2025-03-20 09:56:39.458] [5482] [HailoRT] [info] [control.cpp:108] [control__parse_identify_results] firmware_version is: 4.20.0
[2025-03-20 09:56:39.458] [5482] [HailoRT] [info] [vdevice.cpp:651] [create] VDevice Infos: 0000:01:00.0
[2025-03-20 09:56:39.501] [5482] [HailoRT] [info] [hef.cpp:1929] [get_network_group_and_network_name] No name was given. Addressing all networks of default network_group: yolo11n_visdrone
[2025-03-20 09:56:39.507] [5482] [HailoRT] [info] [internal_buffer_manager.cpp:204] [print_execution_results] Planned internal buffer memory: CMA memory 0, user memory 1539584. memory to edge layer usage factor is 0.9087338
[2025-03-20 09:56:39.507] [5482] [HailoRT] [info] [internal_buffer_manager.cpp:212] [print_execution_results] Default Internal buffer planner executed successfully
[2025-03-20 09:56:39.520] [5482] [HailoRT] [info] [device_internal.cpp:57] [configure] Configuring HEF took 18.913141 milliseconds
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [vdevice.cpp:749] [configure] Configuring HEF on VDevice took 19.227162 milliseconds
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [infer_model.cpp:436] [configure] Configuring network group 'yolo11n_visdrone' with params: batch size: 0, power mode: PERFORMANCE, latency: NONE
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [multi_io_elements.cpp:756] [create] Created (AsyncHwEl)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [queue_elements.cpp:450] [create] Created (EntryPushQEl0yolo11n_visdrone/input_layer1 | timeout: 10s)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [filter_elements.cpp:101] [create] Created (PreInferEl1yolo11n_visdrone/input_layer1 | Reorder - src_order: NHWC, src_shape: (640, 640, 3), dst_order: NHCW, dst_shape: (640, 640, 3))
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [queue_elements.cpp:450] [create] Created (PushQEl1yolo11n_visdrone/input_layer1 | timeout: 10s)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [multi_io_elements.cpp:135] [create] Created (NmsPPMuxEl0YOLOV8-Post-Process | Op YOLOV8, Name: YOLOV8-Post-Process, Score threshold: 0.200, IoU threshold: 0.70, Classes: 2, Cross classes: false, NMS results order: BY_CLASS, Max bboxes per class: 100, Image height: 640, Image width: 640)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [queue_elements.cpp:942] [create] Created (MultiPushQEl0YOLOV8-Post-Process | timeout: 10s)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [edge_elements.cpp:187] [create] Created (LastAsyncEl0NmsPPMuxEl0YOLOV8-Post-Process)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [pipeline.cpp:891] [print_deep_description] EntryPushQEl0yolo11n_visdrone/input_layer1 | inputs: user | outputs: PreInferEl1yolo11n_visdrone/input_layer1(running in thread_id: 5684)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [pipeline.cpp:891] [print_deep_description] PreInferEl1yolo11n_visdrone/input_layer1 | inputs: EntryPushQEl0yolo11n_visdrone/input_layer1[0] | outputs: PushQEl1yolo11n_visdrone/input_layer1
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [pipeline.cpp:891] [print_deep_description] PushQEl1yolo11n_visdrone/input_layer1 | inputs: PreInferEl1yolo11n_visdrone/input_layer1[0] | outputs: AsyncHwEl(running in thread_id: 5685)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [pipeline.cpp:891] [print_deep_description] AsyncHwEl | inputs: PushQEl1yolo11n_visdrone/input_layer1[0] | outputs: MultiPushQEl0YOLOV8-Post-Process MultiPushQEl0YOLOV8-Post-Process MultiPushQEl0YOLOV8-Post-Process MultiPushQEl0YOLOV8-Post-Process MultiPushQEl0YOLOV8-Post-Process MultiPushQEl0YOLOV8-Post-Process
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [pipeline.cpp:891] [print_deep_description] MultiPushQEl0YOLOV8-Post-Process | inputs: AsyncHwEl[0] AsyncHwEl[1] AsyncHwEl[2] AsyncHwEl[3] AsyncHwEl[4] AsyncHwEl[5] | outputs: NmsPPMuxEl0YOLOV8-Post-Process(running in thread_id: 5686)
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [pipeline.cpp:891] [print_deep_description] NmsPPMuxEl0YOLOV8-Post-Process | inputs: MultiPushQEl0YOLOV8-Post-Process[0] | outputs: LastAsyncEl0NmsPPMuxEl0YOLOV8-Post-Process
[2025-03-20 09:56:39.521] [5482] [HailoRT] [info] [pipeline.cpp:891] [print_deep_description] LastAsyncEl0NmsPPMuxEl0YOLOV8-Post-Process | inputs: NmsPPMuxEl0YOLOV8-Post-Process[0] | outputs: user
[2025-03-20 09:56:39.566] [5482] [HailoRT] [info] [hef.cpp:1929] [get_network_group_and_network_name] No name was given. Addressing all networks of default network_group: yolo11n_visdrone
[2025-03-20 09:56:39.568] [5482] [HailoRT] [error] [infer_model.cpp:898] [validate_bindings] CHECK failed - Output buffer size 1002 is different than expected 4008 for output 'yolo11n_visdrone/yolov8_nms_postprocess'
any ideas what this is down to? The code from the tutorial is here:
from hailo_platform import VDevice, HailoSchedulingAlgorithm
print(np.__version__)
timeout_ms = 1000
# The vdevice is used as a context manager ("with" statement) to ensure it's released on time.
# Create an infer model from an HEF:
infer_model = vdevice.create_infer_model(model_hef)
# Configure the infer model and create bindings for it
# Set input and output buffers
buffer = np.empty(infer_model.input().shape).astype(np.uint8)
bindings.input().set_buffer(buffer)
job = configured_infer_model.run_async([bindings])
job.wait(timeout_ms)
