The “Input buffer size 0 is different” error occurs because you’re passing a NumPy array with zero bytes to bindings.input().set_buffer(...), while the HailoRT expects a valid frame buffer. This typically happens when your array shape contains a zero dimension - usually the batch dimension.
When you create an InferModel, it starts with a batch size of 0 (HAILO_DEFAULT_BATCH_SIZE), which means it will auto-determine the batch size during configuration. If you configure the model without explicitly setting the batch size first, you’ll end up with this issue:
infer_model = vdevice.create_infer_model('inception_net.hef')
# batch size is still 0 at this point
# infer_model.input().shape is something like (0, H, W, C)
buffer = np.empty(infer_model.input().shape).astype(np.uint8)
bindings.input().set_buffer(buffer) # buffer has 0 bytes - causes the error
Solution:
Set your batch size explicitly before configuring the model. For single image inference:
infer_model.set_batch_size(1) # Set batch size before configuration
with infer_model.configure() as cfg:
bindings = cfg.create_bindings()
shape = infer_model.input().shape # Now (1, 224, 224, 3) for example
buffer = np.empty(shape, dtype=np.uint8)
bindings.input().set_buffer(buffer) # buffer now has the correct size
# proceed with inference...
This should resolve the buffer size mismatch error. Let me know if you have any other questions!
