Inference images using Hailo
I’m using RPI with Hailo AI kit (version 4.20.0)
I’m trying to inference an image and getting the following error:
[HailoRT] [error] CHECK failed - Memory size of vstream yolov8n/input_layer1 does not match the frame count! (Expected 25165824000, got 19660800)
this is my code:
 imageDetections = []
        file = request.files['image']
        image = Image.open(file)
        image_height = image.height
        image_width = image.width
        devices = Device.scan()
        with VDevice(device_ids=devices) as target:
            hef = HEF(f'resources/{model}.hef')
            utils = ObjectDetectionUtils(f"resources/{model}.txt")
            # Convert the image to a numpy array
            image = image.resize((1280, 1280))
            image = np.array(image)
            network_group = configure_and_get_network_group(hef, target)
            input_vstreams_params, output_vstreams_params = create_input_output_vstream_params(network_group)
            # print info of input & output
            input_vstream_info, output_vstream_info = print_input_output_vstream_info(hef)
            start_time = time.time()
                total_inference_time = 0
                    np_array = np.array(image, dtype=np.float32) / 255.0
                    input_data = {input_vstream_info[0].name: np_array}
                    raw_image = infer_pipeline.infer(input_data)
                    detections = utils.extract_detections(raw_image[next(iter(output_vstream_info)).name][0], range)
                    #print(detections)
                    for detection in detections:
                        imageDetections.append(detection)
                    end_time = time.time()
                    total_inference_time = (end_time - start_time)
                    logger.info("Total inference time: {} sec", total_inference_time)
        #im = Image.open(BytesIO(base64.b64decode(data['image'])))
        return jsonify(imageDetections)
this is my hef file:
Network group name: yolov8n, Single Context
    Network name: yolov8n/yolov8n
        VStream infos:
            Input  yolov8n/input_layer1 UINT8, NHWC(1280x1280x3)
            Output yolov8n/yolov8_nms_postprocess FLOAT32, HAILO NMS BY CLASS(number of classes: 2, maximum bounding boxes per class: 100, maximum frame size: 4008)
            Operation:
                Op YOLOV8
                Score threshold: 0.200
                IoU threshold: 0.70
                Classes: 2
                Cross classes: false
                NMS results order: BY_CLASS
                Max bboxes per class: 100
                Image height: 1280
                Image width: 1280
Any idea what can be the problem? I tried to look for previous messages but i’m not ablt to find useful information
BTW → Using the same hef file with Gstreamer is working fine.
Found a similar concern here with assistance
I set numpy to version 1.23.3 but I’ve the same issue.
