Error Using Inference on an Image
Hello! I am new user. I need help determining why inference on an image fails. I’m certain I’m missing something simple. I apologize if this question is redundant, but I can’t seem to pin this down.
I have success using “HailoRT User Guide: Section 5.5: Python inference Tutorial - Single Model” & success using the randomly generated data. I cannot determine why, after resizing / altering the image, that the inference cannot handle the difference of data expectations. The change in data is just an image from a cannonical dataset.
Error is located within “infer_pipeline.infer(input_data).”
Hailort.log error lines:
[2025-01-17 18:15:23.916] [5379] [HailoRT] [error] [inference_pipeline.cpp:274] [verify_memory_view_size] CHECK failed - Memory size of vstream yv82/input_layer1 does not match the frame count! (Expected 3145728000, got 4915200)
[2025-01-17 18:15:23.916] [5379] [HailoRT] [error] [inference_pipeline.cpp:201] [infer] CHECK_SUCCESS failed with status=HAILO_INVALID_ARGUMENT(2)
Software Development Kit via Manual Installation on a Raspberry Pi 5. Runtime environment is the following:
Hailortcli -fw-control identity:
Identifying board
Control Protocol Version: 2
Firmware Version: 4.19.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8L
Serial Number: HLDDLBB243301363
Part Number: HM21LB1C2LAE
Thank you for any help!
Hey @tim.j.n17 ,
When you encounter this error with yv82/input_layer1, it typically indicates a mismatch between your input data and what the model expects. Let’s walk through how to resolve this.
First, let’s check your model’s requirements:
hailortcli parse-hef {hef}
This will show you the exact specifications your model needs for inference.
To fix this issue, here’s what you need to do:
  1. Image Preprocessing
from PIL import Image
# Load and resize your image
image = Image.open("image.jpg").resize((224, 224))  # Adjust size as per your model
input_data = np.array(image).astype("float32")
input_data = input_data / 255.0  # Normalize if required
  1. Batch Dimension
# Add batch dimension if needed
input_data = np.expand_dims(input_data, axis=0)
  1. Data Layout If your model expects NCHW format instead of NHWC:
input_data = np.transpose(input_data, (0, 3, 1, 2))
If you’re still experiencing issues, please share:
  1. The output of hailortcli parse-hef {hef}
  2. Your input data shape and type
  3. Any additional error messages from HailoRT
Hope this helps! Let us know if you need any clarification.
Best Regrads,
Omria
