DFC_4_Inference_Tutorial error
Going through the tutorial (by using hailo tutorial in the terminal), I’ve been able to convert the models. However, when I copied all of the models + notebooks to my raspberry pi with the Hailo hat, it fails to run inference. Anyone had success running the DFC_4_Inference_Tutorial.ipynb?
Here’s the code from the notebook
# The result output tensor is infer_results[output_vstream_info.name]
print(f"Stream output shape is {infer_results[output_vstream_info.name].shape}")
and here’s the error
Solved by using a different numpy version, as mentioned in this post.
