Memory size frame count mismatch
Hello there
I recently received the Raspberry Pi PCIe Accelerator Module with the Hailo-8L and was able to run the examples from the rpi5-examples and the Hailo Application Code Examples (GitHub - hailo-ai/Hailo-Application-Code-Examples). However, suddenly I get the an error when running any of the examples from Hailo Application Code Examples. This specific error happens when running the object detection example. I downloaded the correct hef for the Hailo-8L from the model zoo repository.
[HailoRT] [error] CHECK failed - Memory size of vstream yolov7/input_layer1 does not match the frame count! (Expected 1228800, got 0)
I can successfully run the hef using hailort-cli run. Does anybody have any pointers to what I am doing wrong?
Hey @funs
Welcome to Hailo Community.
is this the python or CPP examples ?
Please add the exact application you are running and make sure that the repo is updated , if you are using python on the rpi5 ( hailo_platform) it is not yet supported , will be enabled soon.
Regards
Hello Omri
Thank you for your response. Yes, I was indeed trying to run the python examples. I was able to build and run the C++ examples, which are working fine.
I look forward to Python support on the Pi 5 and will be using the C++ API for my stuff.
Thanks, kind regards
Stefan
I am also facing the same problem. Earlier the example code from GitHub - hailo-ai/Hailo-Application-Code-Examples was working for object-detection python but now suddenly giving the same error, I am also using Hailo-8L
[HailoRT] [error] CHECK failed - Memory size of vstream ssd_mobilenet_v1/input_layer1 does not match the frame count! (Expected 270000, got 0)
can any one help?
Hi @jamesbonr123,
Which hailort version are you using?
Hi @nina-vilela
I am using v4.18.0 version of hailort
Hi @jamesbonr123,
We believe that the issue was fixed. Could you give it a try with the updated code?
I have this error too. I work on raspberry Pi 5 and installed hailort, pcie driver and python API package for python 3.11 with version 4.18 manuallly.
On raspberry both hailortcli benchmark ~/yolov8n.hef and running the model from python API works (on tracker hailo code example).
The problem occurs when I run the code inside docker container (I installed hailort==4.18 and python API package for python 3.10 there).
user@docker:~$ hailortcli benchmark hailo/yolov8n.hef works but running the model through the python API does not. Is there anything I can do to fix this?
The problem was that I used incorrect version of numpy (above > 2.0) whereas it is required to run it with numpy==1.23.3
Thanks for letting us know the solution. We will consider adding a numpy version requirement.
thank you for providing solution!
I’m also strugging the same problm, but after I reinstalled numpy==1.23.3, I managed to solve this!
I set numpy to version 1.23.3 but I’ve the same issue.
I had the same issue with numpy 1.26.4 on my raspberry pi 5
Control Protocol Version: 2
Logger Version: 0
Board Name: Hailo-8
the model scdepthv3.hef expected a batch size with sending the frames:
    # adding batch dimension: (H, W, C) -> (1, H, W, C) for NHWC format
    frame = np.expand_dims(frame, axis=0)
Hey @Ralph_Muthreich,
Could you try using numpy version 1.23.3? That should help for now. This issue will get fixed once the trixiy package is updated to work with numpy 2!
