Hello everyone,
I am a newcomer exploring the HAILO AI KIT, and I am trying to run the Object Detection example with ByteTracker and Supervision on Raspberry Pi 5 according to the guide from Hailo’s GitHub project. However, I am encountering some issues during the execution of the code.
When I run the following command:
./detection_with_tracker.py -i input_video.mp4 -o output_video.mp4 -l coco.txt -s 0.5
I receive the following error messages:
[HailoRT] [error] HEF format is not compatible with device. Device arch: HAILO8L, HEF arch: HAILO8
Exception in thread Thread-1 (run):
File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 2835, in configure
configured_infer_model_cpp_obj = self._infer_model.configure()
hailo_platform.pyhailort._pyhailort.HailoRTStatusException: 26
File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 2834, in configure
with ExceptionWrapper():
File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 110, in __exit__
File "/usr/lib/python3/dist-packages/hailo_platform/pyhailort/pyhailort.py", line 155, in _raise_indicative_status_exception
hailo_platform.pyhailort.pyhailort.HailoRTInvalidHEFException: Invalid HEF. See hailort.log for more information
