Object Detection on an RTSP Stream
User Guide: Real-Time Object Detection on RTSP Streams with DeGirum PySDK
DeGirum PySDK enables seamless integration of AI models into real-time applications, including live video analysis from RTSP-enabled cameras. This guide walks you through processing and displaying AI inference results dynamically from an RTSP stream using the YOLOv8 object detection model.
Prerequisites
  1. DeGirum PySDK: Installed and configured on your system. See DeGirum/hailo_examples for instructions.
  2. RTSP Camera Stream: Obtain the RTSP URL of your camera. Replace username, password, ip, and port in the script with your camera’s credentials.
  3. Token: If using cloud inference, ensure you have a valid token. For local inference, leave the token empty.
Script Overview
This script:
  1. Loads the YOLOv8 object detection model.
  2. Processes the RTSP video stream to detect objects in real time.
  3. Displays the inference results dynamically in a dedicated window.
Code Example
# Choose inference host address
inference_host_address = "@cloud"
# inference_host_address = "@local"
# Choose zoo_url
zoo_url = "degirum/hailo"
# zoo_url = "../models"
# Set token
token = degirum_tools.get_token()
# token = '' # Leave empty for local inference
# Specify the AI model and video source
model_name = "yolov8n_coco--640x640_quant_hailort_hailo8l_1"
video_source = "rtsp://username:password@ip:port/cam/realmonitor?channel=1&subtype=0"  # Replace with your camera RTSP URL
# Load the AI model
model = dg.load_model(
    model_name=model_name,
    zoo_url=zoo_url,
    token=token,
# Run AI inference on the video stream and display the results
with degirum_tools.Display("AI Camera") as output_display:
    for inference_result in degirum_tools.predict_stream(model, video_source):
        output_display.show(inference_result)
Steps to Run the Script
  1. Set Up the RTSP Stream:
    • Replace the video_source string with the RTSP URL of your camera.
    • Example format: rtsp://username:password@ip:port/cam/realmonitor?channel=1&subtype=0.
  2. Configure Inference:
    • Use @cloud for cloud inference or @local for local device inference.
    • Specify the appropriate zoo_url for accessing your model zoo.
  3. Load the Model:
    • Replace model_name with your desired model if you want to detect objects other than the default YOLOv8 configuration.
  4. Run the Script:
    • Execute the script to process the RTSP feed in real time.
    • The detected objects will be displayed dynamically in the window labeled “AI Camera.”
  5. Stop the Display:
    • Press x or q to exit the display window.
  • Surveillance: Monitor live feeds for security and safety.
  • Traffic Analysis: Analyze vehicles and pedestrians in real time.
  • Industrial Monitoring: Detect objects in manufacturing or warehouse operations.
Additional Resources
For more examples and advanced use cases, visit our Hailo Examples Repository. This repository provides scripts and guidance for deploying AI models on various hardware configurations.
Feel free to post your questions or share your experiences with this setup in the comments below! :rocket:
Thx for sharing this DeGirum PySDK.
How can we detect just one category, for example “car”.
Can we use our own YOLOv8 model to work with DeGirum PySDK ?
Thx for your reply.
Hi @iulian_paul_NAIDIN
Welcome to the Hailo community.
There are two methods to detect just one category:
  1. Filter the results as below:
zoo_url = 'degirum/hailo'
token=''
device_type=['HAILORT/HAILO8L']
image_source = "<path to image>"
classes = {"car"}
# load model with set desired classes for output
    zoo_url=zoo_url,
    token=token,
    output_class_set = classes
# Run AI model on image
inference_result = model(image_source)
# print AI inference results
print(inference_result)
# AI prediction: show only desired classes
with degirum_tools.Display("All classes (press 'q' to exit)") as output_display:
    output_display.show_image(inference_result)
  1. Run a custom model that detects only that class.
Yes, you can use your own YOLOv8 model to work with DeGirum PySDK. See our user guide: User Guide 3: Simplifying Object Detection on a Hailo Device Using DeGirum PySDK. Please let us know if you need any help.
Thx for your response.
I guess this will work also with rtsp stream like source input ?
Try to test first example and get an error:
degirum_cli predict-image
–inference-host-address @local
–model-name yolov8n_relu6_coco–640x640_quant_hailort_hailo8_1
–model-zoo-url degirum/hailo
Running inference with the following parameters:
  Inference Host Address: @local
  Model Zoo URL: degirum/hailo
  Model Name: yolov8n_relu6_coco--640x640_quant_hailort_hailo8_1
  Image Source: https://raw.githubusercontent.com/DeGirum/PySDKExamples/main/images/ThreePersons.jpg
  Token: Loaded from environment
  Extra Args: {}
  File "/home/pi/degirum_env/bin/degirum_cli", line 8, in <module>
    sys.exit(cli())
  File "/home/pi/degirum_env/lib/python3.11/site-packages/click/core.py", line 1161, in __call__
    return self.main(*args, **kwargs)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/click/core.py", line 1082, in main
    rv = self.invoke(ctx)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/click/core.py", line 1697, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/home/pi/degirum_env/lib/python3.11/site-packages/click/core.py", line 1443, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/click/core.py", line 788, in invoke
    return __callback(*args, **kwargs)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/degirum_cli/cli.py", line 73, in predict_image
    predict_image_main(
  File "/home/pi/degirum_env/lib/python3.11/site-packages/degirum_cli/predict_image.py", line 37, in run_inference
    model = dg.load_model(**model_args)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/degirum/__init__.py", line 220, in load_model
    return zoo.load_model(model_name, **kwargs)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/degirum/log.py", line 59, in wrap
    return f(*args, **kwargs)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/degirum/zoo_manager.py", line 266, in load_model
    model = self._zoo.load_model(model_name)
  File "/home/pi/degirum_env/lib/python3.11/site-packages/degirum/_zoo_accessor.py", line 636, in load_model
    raise DegirumException(
degirum.exceptions.DegirumException: Cloud Model 'yolov8n_relu6_coco--640x640_quant_hailort_hailo8_1' does not have any supported runtime/device combinations that will work on this system.
(degirum_env) pi@raspberrypi:~ $
I don’t know why.
Have you an idea which is the error ?
Thx for help
From the error message, it seems like you do not have a Hailo8 device. Can you please run degirum sys-info and let me know the output. Also, can you add --token 'abcd' in the command?
(degirum_env) pi@raspberrypi:~ $ degirum sys-info
Devices:
  HAILORT/HAILO8L:
  - '@Index': 0
    Board Name: Hailo-8
    Device Architecture: HAILO8L
    Firmware Version: 4.20.0
    Part Number: HM21LB1C2LAE
    Serial Number: "HLDDLBB244601870\x10HM21LB1C2LAE"
  N2X/CPU:
  - '@Index': 0
  - '@Index': 1
  TFLITE/CPU:
  - '@Index': 0
  - '@Index': 1
Software Version: 0.15.0
here the result
Ok, so you have Hailo8L and not Hailo8. Please change as below:
--inference-host-address @local
--model-name yolov8n_relu6_coco–640x640_quant_hailort_hailo8l_1
--model-zoo-url degirum/hailo
--token 'abcd'
Model name changed to yolov8n_relu6_coco–640x640_quant_hailort_hailo8l_1 from yolov8n_relu6_coco–640x640_quant_hailort_hailo8l_1. Note the extra l in hailo8l
awsome, works like a charm thx for help …newbie problem!
Now I try to see if rtsp stream can work :wink:
Thx for your help!
Here is how you get rtsp stream to work:
degirum_cli predict-video
--token 'abcd'
--video-source '<rtsp url>'
Thx Shashi, this works :+1:
Tomorrow I will test to filter with category on rtsp stream.
How we can support this project ?
Have a nice day.
The code for filtering classes works on video streams as well. Please let me know if you encounter any difficulties.
Can you elaborate? Do you want to contribute to PySDK development?
Hi shashi ,
am working similar project where am analyzing traffic and am using rpi 5 8gb , and am having 3 rtsp stream so my cpu load may increase if i use yolo , if in case i want to use SSDmobile.hef how can i use it… am newbie in this , if am wrong some where please correct me. Thanks in advance
Hi @shreyas_H
Welcome to the Hailo community. The same code will work with SSDmobilenet models as well. We just need to make sure that the model is integrated to PySDK. Please see User Guide 2: Running Your First Object Detection Model on a Hailo Device Using DeGirum PySDK and User Guide 3: Simplifying Object Detection on a Hailo Device Using DeGirum PySDK for details. Please let us know if you need further help.
Thank you very much… I will go through it… and get back to you.
Getting the error:
Error fetching supported devices: ZooManager: incorrect local model zoo URL “:path” does not exist
Here is the code:
inference_host_address = “@local”
zoo_url = “degirum/hailo”
token = “abcd”
    # Set model name and image source
    model_name = "yolov8n_relu6_coco-640x640_quant_hailort_hailo8_1"
    image_source = "rtsp://user:pass@<IP>:554/profile1/media.smp"
    # Load AI model
    try:
            zoo_url=zoo_url,
            token=token,
            device_type=device_type,
    except Exception as e:
        print(f"Error loading model '{model_name}': {e}")
Here is the sys-info:
(degirum_env) pi@pi-ai:~/hailo_examples $ degirum sys-info
Devices:
HAILORT/HAILO8:
  • ‘@Index’: 0
    Board Name: Hailo-8
    Part Number: ‘’
    Product Name: ‘’
    Serial Number: ‘’
    N2X/CPU:
  • ‘@Index’: 0
    TFLITE/CPU:
  • ‘@Index’: 0
  • ‘@Index’: 1
    Software Version: 0.18.2
Hi @John_Johnny
Welcome to the Hailo community. That model is now deprectaed. Please use model_name=yolov8n_coco--640x640_quant_hailort_hailo8_1
Thank you for that quick reply. However, even with the updated model name I am still getting the same error.
Hi @John_Johnny ,
The bug is in our test.py code which calls dg.get_supported_devices without zoo_url parameter. We updated hailo_examples repo with the fix :
# Check supported devices
try:
    supported_devices = dg.get_supported_devices(
        inference_host_address="@local", "degirum/hailo"
    print(f"Error fetching supported devices: {e}")
    sys.exit(1)
