Okay. so I decided to just try a non custom yolov8s_pose.onnx model for my own sanity. I downloaded this from the model_zoo github page: https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/PoseEstimation/yolov8/yolov8s/pretrained/2023-06-11/yolov8s_pose.zip
Here is the complete output of my attempt:
(hailo_virtualenv) hailo@ross1:/local/workspace$ hailo parser onnx /local/shared_with_docker/yolov8s_pose.onnx
[info] Current Time: 13:12:45, 01/21/25
[info] CPU: Architecture: x86_64, Model: Intel(R) Xeon(R) Platinum 8272CL CPU @ 2.60GHz, Number Of Cores: 16, Utilization: 0.1%
[info] Memory: Total: 125GB, Available: 123GB
[info] System info: OS: Linux, Kernel: 5.15.0-1073-azure
[info] HailoRT Version: 4.20.0
[info] Running `hailo parser onnx /local/shared_with_docker/yolov8s_pose.onnx`
[info] Translation started on ONNX model yolov8s_pose
[info] Restored ONNX model yolov8s_pose (completion time: 00:00:00.21)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.82)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:01.95)
Parsing failed with recommendations for end node names: ['/model.22/Concat_4', '/model.22/Sigmoid_1', '/model.22/Mul_3'].
Would you like to parse again with the recommendation? (y/n)
y
[info] According to recommendations, retrying parsing with end node names: ['/model.22/Concat_4', '/model.22/Sigmoid_1', '/model.22/Mul_3'].
[info] Restored ONNX model yolov8s_pose (completion time: 00:00:00.15)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.76)
[info] Start nodes mapped from original model: 'images': 'yolov8s_pose/input_layer1'.
[info] End nodes mapped from original model: '/model.22/Concat_4', '/model.22/Sigmoid_1', '/model.22/Mul_3'.
[info] Translation completed on ONNX model yolov8s_pose (completion time: 00:00:01.52)
[warning] hw_arch parameter not given, using the default hw_arch hailo8.
If another device is the target, please run again using one of hailo8, hailo8r, hailo8l, hailo15h, hailo15m, hailo15l, hailo10h
[info] Saved HAR to: /local/workspace/yolov8s_pose.har
(hailo_virtualenv) hailo@ross1:/local/workspace$ hailo optimize yolov8s_pose.har --calib-set-path calib_set.npy
[info] Current Time: 13:13:58, 01/21/25
[info] Running `hailo optimize yolov8s_pose.har --calib-set-path calib_set.npy`
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.78)
Calibration: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:47<00:00, 1.34entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:50.24)
[info] Output layer yolov8s_pose/activation1 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [1.0335516265058686e-07, 0.9999998807907104]).
[info] Adaround skipped
[info] Saved HAR to: /local/workspace/yolov8s_pose_optimized.har
(hailo_virtualenv) hailo@ross1:/local/workspace$ hailo compile -h
[info] Current Time: 13:15:59, 01/21/25
[info] CPU: Architecture: x86_64, Model: Intel(R) Xeon(R) Platinum 8272CL CPU @ 2.60GHz, Number Of Cores: 16, Utilization: 0.2%
[info] Running `hailo compile -h`
usage: hailo [-h] [--version]
{fw-update,ssb-update,fw-config,udp-rate-limiter,fw-control,fw-logger,scan,sensor-config,run,benchmark,monitor,parse-hef,measure-power,tutorial,analyze-noise,compiler,params-csv,parser,profiler,optimize,tb,visualizer,har,join,har-onnx-rt,runtime-profiler,dfc-studio,help}
hailo: error: argument {fw-update,ssb-update,fw-config,udp-rate-limiter,fw-control,fw-logger,scan,sensor-config,run,benchmark,monitor,parse-hef,measure-power,tutorial,analyze-noise,compiler,params-csv,parser,profiler,optimize,tb,visualizer,har,join,har-onnx-rt,runtime-profiler,dfc-studio,help}: invalid choice: 'compile' (choose from 'fw-update', 'ssb-update', 'fw-config', 'udp-rate-limiter', 'fw-control', 'fw-logger', 'scan', 'sensor-config', 'run', 'benchmark', 'monitor', 'parse-hef', 'measure-power', 'tutorial', 'analyze-noise', 'compiler', 'params-csv', 'parser', 'profiler', 'optimize', 'tb', 'visualizer', 'har', 'join', 'har-onnx-rt', 'runtime-profiler', 'dfc-studio', 'help')
(hailo_virtualenv) hailo@ross1:/local/workspace$ hailo compiler yolov8s_pose_optimized.har
[info] Current Time: 13:16:33, 01/21/25
[info] Running `hailo compiler yolov8s_pose_optimized.har`
[info] Compiling network
[error] Mapping Failed (allocation time: 12s)
No successful assignments: concat18 errors:
Agent infeasible
concat17 errors:
Agent infeasible
feature_splitter9 errors:
Agent infeasible
[error] BackendAllocatorException: Compilation failed: No successful assignments: concat18 errors:
Agent infeasible
concat17 errors:
Agent infeasible
Agent infeasible
Even the standard yolo gives me issues. If you could please provide a working example for the yolov8s_pose.onnx model the would go a long way to showing me where I’m going wrong.
I assume as there is a compiled version available in the zoo then it should be known.
I think it would be a good idea for you guys to document precisely how to compile all of the standard models in the zoo as a starting point for people. You could put these examples in the zoo linked from the model pages: hailo_model_zoo/docs/public_models/HAILO8/HAILO8_pose_estimation.rst at master · hailo-ai/hailo_model_zoo · GitHub
In fact, maybe even put the instructions here: Hailo Dataflow Compiler - Profiler Report
