Hi
I am trying to generate a .HEF file of a yolov8n_seg model trained on a custom dataset with 4 classes.
I modified the yaml and the .alls files as follows
yaml file
base:
- base/wro_yolov8_seg.yaml
network:
network_name: wro_yolov8n_seg
paths:
alls_script: wro_yolov8n_seg.alls
network_path:
- models_files/InstanceSegmentation/coco/yolov8/yolov8n/pretrained/2023-03-06/yolov8n-seg.onnx
url: https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/InstanceSegmentation/coco/yolov8/yolov8n/pretrained/2023-03-06/yolov8n-seg.zip
parser:
nodes:
- null
- - /model.22/Concat_6
- /model.22/proto/cv3/act/Mul
info:
task: instance segmentation
input_shape: 640x640x3
output_shape: 8400x40x1 160x160x32x1
operations: 12.04G
parameters: 3.4M
framework: pytorch
training_data: coco instances train2017
validation_data: coco instances val2017
eval_metric: mAP
full_precision_result: 30.32
source: https://github.com/ultralytics/ultralytics
license_url: https://github.com/ultralytics/ultralytics/blob/main/LICENSE
license_name: GPL-3.0
The .alls file is
I removed the
change_output_activation(conv45, sigmoid)
change_output_activation(conv61, sigmoid)
change_output_activation(conv74, sigmoid)
as I didn’t if they are needed for my model.
Then I ran the pars and optimize commands inside the docker AI Suite image
parse
hailomz parse --yaml /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/networks/wro_yolov8n_seg.yaml --ckpt best.onnx --start-node-names /model.0/conv/Conv --end-node-names /model.22/Concat /model.22/proto/cv3/act/Mul /model.22/Concat_4 --hw-arch hailo8
Initially, i set the end node names as output0 and output as I saw them in Netron, but the parser gave an error and suggested the names in the above command. It worked and produced the .har file
Then I executed the optimize step
hailomz optimize --har wro_yolov8n_seg.har --hw-arch hailo8 --yaml /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/networks/wro_yolov8n_seg.yaml --ckpt best.onnx --calib-path images/ --end-node-names /model.22/Concat /model.22/proto/cv3/act/Mul /model.22/Concat_4 --classes 4 --performance
Initially it gave an error, then I executed it again and it produced the .har file
Then I executed the compile command
hailomz compile --yaml /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/networks/wro_yolov8n_seg.yaml --ckpt best.onnx --hw-arch hailo8 --end-node-names /model.22/Concat /model.22/proto/cv3/act/Mul /model.22/Concat_4 --har wro_yolov8n_seg.har --calib-path images/ --performance --classes 4
But this time it consistently gave the following error.
[info] Loading model script commands to wro_yolov8n_seg from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/wro_yolov8n_seg.alls
[info] Appending model script commands to wro_yolov8n_seg from string
[error] Mapping Failed (allocation time: 3s)
No valid partition found
[error] BackendAllocatorException: Compilation failed: No valid partition found
I have no cluse why it fails.
Any help is highly appreciated.
