Hi @max
I am trying to do something similar to what you did.
I trained a yolov8n-seg model on my custom dataset with 4 classes. And I downloaded the AI suite docker image inside my Windows WSL2. I exported the .pt file to onnx and I use the hailomz compile as follows
hailomz compile --ckpt ../shared_with_docker/best.onnx --calib-path ../shared_with_docker/images/ --yaml hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov8n_seg.yaml --performance --classes 4
[info] First time Hailo Dataflow Compiler is being used. Checking system requirements... (this might take a few seconds)
[Warning] CUDNN version should be 8.9 or higher, found ..
Component Requirement Found
OS Ubuntu Ubuntu Required
Release 20.04 22.04 Required
Package python3-tk V Required
Package graphviz V Required
Package libgraphviz-dev V Required
Package python3.10-dev V Required
RAM(GB) 16 78 Required
RAM(GB) 32 78 Recommended
CPU-Arch x86_64 x86_64 Required
CPU-flag avx V Required
GPU-Driver 525 566 Recommended
CUDA 11.8 11.8 Recommended
CUDNN 8.9 . Recommended
Var:CC unset unset Required
Var:CXX unset unset Required
Var:LD unset unset Required
Var:AS unset unset Required
Var:AR unset unset Required
Var:LN unset unset Required
Var:DUMP unset unset Required
Var:CPY unset unset Required
In file included from /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/ndarraytypes.h:1948,
from /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/ndarrayobject.h:12,
from /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/arrayobject.h:5,
from /home/hailo/.pyxbld/temp.linux-x86_64-cpython-310/local/workspace/hailo_model_zoo/hailo_model_zoo/core/postprocessing/cython_utils/cython_nms.c:1246:
/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/numpy/core/include/numpy/npy_1_7_deprecated_api.h:17:2: warning: #warning "Using deprecated NumPy API, disable it with " "#define NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION" [-Wcpp]
17 | #warning "Using deprecated NumPy API, disable it with " \
<Hailo Model Zoo INFO> Start run for network yolov8n_seg ...
<Hailo Model Zoo INFO> Initializing the hailo8 runner...
[info] Translation started on ONNX model yolov8n_seg
[info] Restored ONNX model yolov8n_seg (completion time: 00:00:00.04)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.23)
[info] Start nodes mapped from original model: 'images': 'yolov8n_seg/input_layer1'.
[info] End nodes mapped from original model: '/model.22/cv2.2/cv2.2.2/Conv', '/model.22/cv3.2/cv3.2.2/Conv', '/model.22/cv4.2/cv4.2.2/Conv', '/model.22/cv2.1/cv2.1.2/Conv', '/model.22/cv3.1/cv3.1.2/Conv', '/model.22/cv4.1/cv4.1.2/Conv', '/model.22/cv2.0/cv2.0.2/Conv', '/model.22/cv3.0/cv3.0.2/Conv', '/model.22/cv4.0/cv4.0.2/Conv', '/model.22/proto/cv3/act/Mul'.
[info] Translation completed on ONNX model yolov8n_seg (completion time: 00:00:00.77)
[info] Saved HAR to: /local/workspace/yolov8n_seg.har
<Hailo Model Zoo INFO> Using generic alls script found in /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8n_seg.alls because there is no specific hardware alls
[info] Loading model script commands to yolov8n_seg from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8n_seg.alls
<Hailo Model Zoo WARNING> Ignoring classes parameter since the model has no NMS post-process.
[info] Mixed Precision is done (completion time is 00:00:00.52)
Calibration: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:19<00:00, 3.29entries/s]
[info] Statistics Collector is done (completion time is 00:00:21.10)
[info] Output layer yolov8n_seg/conv45 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [9.31174976773056e-16, 0.9431573152542114]).
[info] Output layer yolov8n_seg/conv61 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [1.7576537254026084e-23, 0.9824845194816589]).
[info] Output layer yolov8n_seg/conv74 with sigmoid activation was detected. Forcing its output range to be [0, 1] (original range was [4.132465093344215e-20, 0.9821887612342834]).
[info] Adaround skipped
[info] Quantization-Aware Fine-Tuning is done (completion time is 00:04:42.97)
Full Quant Analysis: 0%| | 0/2 [00:00<?, ?iterations/s]Traceback (most recent call last):
File "/local/workspace/hailo_virtualenv/bin/hailomz", line 33, in <module>
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
run(args)
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 250, in compile
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 91, in _ensure_optimized
optimize_model(
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 326, in optimize_model
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2093, in optimize
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1935, in _optimize
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1045, in full_quantization
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1229, in _full_acceleras_run
optimization_flow.run()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py", line 306, in wrapper
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 326, in run
step_func()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py", line 250, in wrapped
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py", line 113, in parent_wrapper
raise SubprocessUnexpectedFailure(
hailo_model_optimization.acceleras.utils.acceleras_exceptions.SubprocessUnexpectedFailure: Subprocess step3 failed with unexpected error. exitcode -4
So I am not able to get the .hef file.
@Nadav any hint what could be the issue here?
Thanks
