Hi to All,
I cannot measure power consumption on Hailo8L RP 5 (AI KIT). The driver and the runtime are all 4.19. I have checked similar posts with the same problem but none of them suggested a solution.
When I use command (hailortcli measure-power) proposed in the following post:
I observe the following output:
[HailoRT] [error] Firmware control has failed. Major status: 0x400300b4, Minor status: 0x400300b4
[HailoRT] [error] Firmware major status: CONTROL_PROTOCOL_STATUS_UNSUPPORTED_DEVICE
[HailoRT] [error] Firmware minor status: CONTROL_PROTOCOL_STATUS_UNSUPPORTED_DEVICE
[HailoRT] [error] Opcode HAILO_CONTROL_OPCODE_SET_POWER_MEASUEMENT is not supported on the current board.
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_UNSUPPORTED_OPCODE(48)
Failed to set power measurement parameters, status HAILO_UNSUPPORTED_OPCODE(48)
Failed power measurement, status HAILO_UNSUPPORTED_OPCODE(48)
Failed to execute on device: 0000:01:00.0. status= HAILO_UNSUPPORTED_OPCODE(48)
When I use code proposed in the following post
File "/home/.local/lib/python3.11/site-packages/hailo_platform/pyhailort/pyhailort.py", line 2026, in set_power_measurement
return self._device.set_power_measurement(buffer_index, dvm, measurement_type)
hailo_platform.pyhailort._pyhailort.HailoRTStatusException: 48
File "/home/hailo/examples/power.py", line 25, in <module>
_run_periodic()
File "/home/hailo/examples/power.py", line 9, in _run_periodic
target.control.set_power_measurement()
File "/home/.local/lib/python3.11/site-packages/hailo_platform/pyhailort/pyhailort.py", line 2025, in set_power_measurement
with ExceptionWrapper():
File "/home/.local/lib/python3.11/site-packages/hailo_platform/pyhailort/pyhailort.py", line 111, in __exit__
File "/home/.local/lib/python3.11/site-packages/hailo_platform/pyhailort/pyhailort.py", line 156, in _raise_indicative_status_exception
hailo_platform.pyhailort.pyhailort.HailoRTUnsupportedOpcodeException: HailoRT has failed because an unsupported opcode was sent to device
When I use the following code proposed in the same post
from hailo_platform import Device
dev = Device()
dev.control.get_extended_device_information()
My output includes:
Current monitoring: Disabled
The output of the following command:
find /usr/ | grep libhailort
is:
/usr/lib/libhailort.so
/usr/lib/libhailort.so.4.19.0
Any help will the issue will be appreciated!
Thank you and best regards!
