I’m looking forward to purchasing a few of the starter kits!
A couple of newbie questions:
-I’d like to know if and how I can reproduce the power benchmarks using the starter kit. I’m referring to the power benchmarks shown on this page - AI Benchmarks: Evaluating Hailo 8 Accelerator Performance. Are there are power benchmarks for the starter kits than are significantly different than the ones shown on that page?
-That page indicates that you acquired the benchmarks using an Intel i5 host- which suggests the power benchmarks are not the entire system+host but just the board itself. Is that correct? If so, how did you acquire the power consumption of just the board. Can I get that from the board itself or do I also need to purchase external measurement equipment?
You can add this to your own application using the HailoRT API. Have a look at the HailoRT User Guide and the Python Power Measurement Tutorial in the Hailo AI Software Suite.
Note that the INA is an optional component and is not available on all hardware platforms.
HailoRT CLI does have a second run command called run2. It allows you to set multiple networks and use parameters to configure each model. For example:
hailortcli run2 set-net model.hef --framerate 10
Use the --help parameter to get all options available.
