Technical Inquiry: M.2 Slot Requirements for HAILO AI Chip on New AI PC Build (Linux Ubuntu & Windows Compatibility)
Dear HAILO Support Team,
We are planning to build a new AI PC to serve as a reference system for AI testing using the HAILO AI Chip. This PC will need to run the HAILO AI M.2 card under both Linux Ubuntu and Windows 10/11.
As we intend to utilize M.2 slots for flexibility and expandability, we have some important questions regarding the technical compatibility of the motherboard’s M.2 slots with the HAILO AI Chip.
Specifically, we would appreciate information on the following aspects:
- What technical specifications of the M.2 slots are mandatory for the HAILO AI Chip to be correctly recognized and utilized by the operating system (Linux Ubuntu and Windows 10/11) when installed in the motherboard’s M.2 slot?
- Does the number of PCIe lanes play a critical role? If so, what is the minimum required number?
- Is support for a specific PCIe generation (e.g., PCIe 4.0 or PCIe 5.0) necessary or recommended for optimal performance of the HAILO AI Chip?
- Are there any other technical details of the M.2 slots (e.g., keying, size) that need to be considered?
- Are there any specific recommendations for motherboard manufacturers or chipsets (Intel or AMD) that are known to work well with HAILO AI M.2 cards? Or are the technical specifications mentioned above the only crucial factors, making the choice of motherboard manufacturer less important?
- We have seen examples for the Raspberry Pi 5 with Dual M.2. Do you potentially have reference configurations or tested motherboards with Dual M.2 slots for Intel or AMD platforms that you could recommend for our use cases (AI testing under Linux and Windows)? Information on successfully deployed motherboards would be very helpful for our selection process.
Our goal is to procure the correct hardware from the outset to avoid compatibility issues and establish a reliable testing environment. Your expertise and guidance during this planning phase would be greatly appreciated.
Thank you in advance for your support!
Sincerely,
Chris089
