I’ve been struggling to load a model on a Raspberry Pi 5 using Hailo’s SDK. I spent two hours trying to figure it out but still couldn’t get it to work. Here’s an example of the code I tried:
import hailo
hef_path = 'yolov11n_h8l.hef'
hef = hailo.Hef(hef_path) # ← This doesn’t work
Unfortunately, this simple approach didn’t work, and I couldn’t find clear documentation or examples.
What I Expect:
We should be able to load and run a model with minimal code. For example, something like this:
# Import libraries
from hailo_platform import HEFModel
import cv2
# Initialize Hailo device and load model
model = HEFModel("path_to_your_model.hef")
# Capture from camera (if using camera)
cap = cv2.VideoCapture(0)
while True:
# Get frame from camera
ret, frame = cap.read()
if not ret:
break
# Preprocess image (resize to model's input dimensions)
input_data = preprocess_image(frame)
# Run inference
results = model.infer(input_data)
# Process results (depends on model type)
processed_results = process_results(results)
# Display or use the results
display_results(frame, processed_results)
if cv2.waitKey(1) == ord('q'):
break
cap.release()
cv2.destroyAllWindows()
My Problem:
I can’t seem to find a straightforward way to load a model and run inference using Python on the Raspberry Pi 5. The documentation is unclear, and most examples are either incomplete or overly complex.
Can someone please explain in simple terms how to:
- Load a
.hefmodel file. - Run inference on an input (e.g., an image or video frame).
- Process and display the results.
Any help would be greatly appreciated!
