Error: Pipeline after conversion using DFC Cli
I tried this to convert to hef using these commands
STEP 1 : Parsing
(.venv) taruna@taruna-desktop:~/Hailo/models
$ hailomz parse --yaml=/home/taruna/Hailo/hailo_model_zoo/hailo_model_zoo/cfg/networks/ssd_mobilenet_v1.yaml --hw-arch="hailo8l"
<Hailo Model Zoo INFO> Start run for network ssd_mobilenet_v1 ...
<Hailo Model Zoo INFO> Initializing the runner...
[info] Translation started on Tensorflow model ssd_mobilenet_v1
[info] Start nodes mapped from original model: 'Preprocessor/sub': 'ssd_mobilenet_v1/input_layer1'.
[info] End nodes mapped from original model: 'BoxPredictor_0/BoxEncodingPredictor/BiasAdd', 'BoxPredictor_0/ClassPredictor/BiasAdd', 'BoxPredictor_1/BoxEncodingPredictor/BiasAdd', 'BoxPredictor_1/ClassPredictor/BiasAdd', 'BoxPredictor_2/BoxEncodingPredictor/BiasAdd', 'BoxPredictor_2/ClassPredictor/BiasAdd', 'BoxPredictor_3/BoxEncodingPredictor/BiasAdd', 'BoxPredictor_3/ClassPredictor/BiasAdd', 'BoxPredictor_4/BoxEncodingPredictor/BiasAdd', 'BoxPredictor_4/ClassPredictor/BiasAdd', 'BoxPredictor_5/BoxEncodingPredictor/BiasAdd', 'BoxPredictor_5/ClassPredictor/BiasAdd'.
[info] Translation completed on Tensorflow model ssd_mobilenet_v1 (completion time: 00:00:00.18)
[info] Saved HAR to: /home/taruna/Hailo/models/ssd_mobilenet_v1.har
STEP 2 : Optimizing
$ hailo optimize /home/taruna/Hailo/models/ssd_mobilenet_v1.har --calib-set-path calib_set.npy
[info] Current Time: 18:35:51, 11/22/24
[info] CPU: Architecture: x86_64, Model: 12th Gen Intel(R) Core(TM) i7-12700, Number Of Cores: 20, Utilization: 0.1%
[info] Memory: Total: 23GB, Available: 18GB
[info] System info: OS: Linux, Kernel: 6.8.0-40-generic
[info] Running `hailo optimize /home/taruna/Hailo/models/ssd_mobilenet_v1.har --calib-set-path calib_set.npy`
[info] Mixed Precision is done (completion time is 00:00:00.16)
Calibration: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:07<00:00,  8.34entries/s]
[info] Statistics Collector is done (completion time is 00:00:08.10)
[info] Adaround skipped
[info] Saved HAR to: /home/taruna/Hailo/models/ssd_mobilenet_v1_optimized.har
STEP 3: Compile
$ hailo compiler /home/taruna/Hailo/models/ssd_mobilenet_v1_optimized.har
[info] Current Time: 18:37:17, 11/22/24
[info] Running `hailo compiler /home/taruna/Hailo/models/ssd_mobilenet_v1_optimized.har`
[info] Compiling network
[info] Resources optimization guidelines: Strategy -> GREEDY Objective -> MAX_FPS
[info] Resources optimization params: max_control_utilization=75%, max_compute_utilization=75%, max_compute_16bit_utilization=75%, max_memory_utilization (weights)=75%, max_input_aligner_utilization=75%, max_apu_utilization=75%
Validating context_0 layer by layer (100%)
● Finished
Context:0/0 Iteration 4: Trying parallel mapping...
          cluster_0  cluster_1  cluster_2  cluster_3  cluster_4  cluster_5  cluster_6  cluster_7  prepost
 worker0  V          V          *          *          V          V          *          *          V
 worker1  V          V          *          *          V          V          *          *          V
 worker2  V          V          *          *          V          V          *          *          V
 worker3  V          V          *          *          V          V          *          *          V
  00:03
Reverts on cluster mapping: 0
Reverts on split failed: 0
[info] Iterations: 4
[info] +-----------+---------------------+---------------------+--------------------+
[info] | Cluster   | Control Utilization | Compute Utilization | Memory Utilization |
[info] | cluster_0 | 56.3%               | 35.9%               | 27.3%              |
[info] | cluster_1 | 100%                | 96.9%               | 82%                |
[info] | cluster_4 | 100%                | 79.7%               | 44.5%              |
[info] | cluster_5 | 43.8%               | 35.9%               | 51.6%              |
[info] | Total     | 75%                 | 62.1%               | 51.4%              |
[info] Successful Mapping (allocation time: 12s)
[info] Compiling context_0...
[info] Bandwidth of model inputs: 2.05994 Mbps, outputs: 1.38943 Mbps (for a single frame)
[info] Bandwidth of inter context tensors: 0.0 Mbps (for a single frame)
[info] Building HEF...
[info] Successful Compilation (compilation time: 2s)
[info] Compilation complete
[info] Saved HEF to: /home/taruna/Hailo/models/ssd_mobilenet_v1.hef
[info] Saved HAR to: /home/taruna/Hailo/models/ssd_mobilenet_v1_compiled.har
Question
  1. After running these steps when i run the pipeline with model it throws this error
gst-launch-1.0 filesrc location=$TAPPAS_WORKSPACE/apps/h8/gstreamer/resources/mp4/detection.mp4 name=src_0 ! decodebin ! videoscale ! video/x-raw, pixel-aspect-ratio=1/1 ! videoconvert ! queue ! hailonet hef-path=/home/vk/Downloads/ssd_mobilenet_v1.hef is-active=true ! queue leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! hailofilter so-path=$TAPPAS_WORKSPACE/apps/h8/gstreamer/libs/post_processes/libmobilenet_ssd_post.so qos=false ! queue ! hailooverlay ! videoconvert ! fakesink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Redistribute latency...
terminate called after throwing an instance of 'std::invalid_argument'
  what():  No tensor with name ssd_mobilenet_v1/nms1
Aborted
And if i directly download the HEF from the repo model zoo then it works fine , so is there something missing/wrong in the compilation step
gst-launch-1.0 filesrc location=$TAPPAS_WORKSPACE/apps/h8/gstreamer/resources/mp4/detection.mp4 name=src_0 ! decodebin ! videoscale ! video/x-raw, pixel-aspect-ratio=1/1 ! videoconvert ! queue ! hailonet hef-path=/home/vk/Desktop/ssd_mobilenet_v1.hef is-active=true ! queue leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! hailofilter so-path=$TAPPAS_WORKSPACE/apps/h8/gstreamer/libs/post_processes/libmobilenet_ssd_post.so qos=false ! queue ! hailooverlay ! videoconvert ! fakesink
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Last Question if i download random any onnx model from the repo onnx/models then sometimes i get the unsupported dynamic error and sometimes different so I’m not able to understood whats the exact way that by following that i get to convert any model to hef.
The Hailo-8 is a specialized hardware that is designed to run a subset of operations that can be described by frameworks like Pytorch and formats like ONNX. These are the compute intensive core operations of CNNs. Other operations that are often at the beginning and end of the network that are not supported on Hailo need to be implemented on the host.
The Hailo AI Software Suite comes with build in tutorials. Run:
hailo tutorial
This will start a Jupyter notebook server with notebooks describing all steps.
After that you can review the YAML and ALLS script files of the models in the Hailo Model Zoo to understand how we convert popular models.
GitHub - Hailo Model Zoo - yolov5m.yaml
GitHub - Hailo Model Zoo - yolov5m.alls
Use the following command to check whether your HEF file contains NMS postprocessing. Compare the output for your HEF file and the original HEF from the Model Zoo.
Check whether you added NMS using the ALLS script. See the Model Zoo alls file for SSD:
GitHub - Hailo Model Zoo - ssd_mobilenet_v1.alls
