Wrong Object Detection using hef, with rpi5 example
Hello Everyone.
By using DFC version 3.27 I’m able to convert onnx file hef for object detection.
I integrated same hef in rpi5-exapmle program. But model is not detecting properly.
expected results are
1 coin it should detect as white
25 coin it should detect as blue
5 it should detect as red
model : trained using yolov8n
Dataset size : 5176 images
command used to convert onnx to hef : hailomz compile --ckpt /local/shared_with_docker/5k_chips.onnx --calib-path /local/shared_with_docker/5k_chips/images/ --yaml /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov8n.yaml --classes 4 --hw-arch hailo8l
above command I executed in the hailo sw suit container.
When I validated the trained model got good metrics
Please help me here to detect the objects properly.
Anything wrong I’m doing?
Thanks in Advance
When a model is quantized there will be a degradation in accuracy. The amount depends on the model and the optimization algorithm used.
I would recommend you have a look at the Layer Noise Analysis Tutorial in the Hailo AI Software Suite. When inside the docker, run the following command:
hailo tutorial
This will start a Jupyter Notebook server with tutorials for each step of the conversion.
For the more advances optimization algorithms you will need a GPU and more calibration images.
You can find further information in the Hailo Dataflow Compiler User Guide section Model Optimization.
@Klaus_Koschinsky,
I’ve installed DFC in Ubuntu 24.04 and it is having Nvidia GeForce GTX 1650. Is that fine? If yes, How to use it.
Also, these are logs I got when I executed via command cli:
hailo@DT-SGH649TZYF:/local/workspace$ hailomz compile --ckpt /local/workspace/chip_v2.onnx --calib-path /local/workspace/images/ --yaml /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov8n.yaml --classes 4
Start run for network yolov8n …
[info] Restored ONNX model yolov8n (completion time: 00:00:00.05)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.30)
[info] Start nodes mapped from original model: ‘images’: ‘yolov8n/input_layer1’.
[info] Translation completed on ONNX model yolov8n (completion time: 00:00:00.98)
[info] Saved HAR to: /local/workspace/yolov8n.har
Preparing calibration data…
[info] Loading model script commands to yolov8n from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8n.alls
[info] Loading model script commands to yolov8n from string
[warning] Reducing optimization level to 0 (the accuracy won’t be optimized and compression won’t be used) because there’s less data than the recommended amount (1024), and there’s no available GPU
[info] Mixed Precision is done (completion time is 00:00:00.74)
[info] Layer Norm Decomposition skipped
Calibration: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:27<00:00, 2.36entries/s]
[info] Stats Collector is done (completion time is 00:00:28.66)
[warning] The force_range command has been used, notice that its behavior was changed on this version. The old behavior forced the range on the collected calibration set statistics, but allowed the range to change during the optimization algorithms.
The new behavior forces the range throughout all optimization stages.
The old method could be restored by adding the flag weak_force_range_out=enabled to the force_range command on the following layers [‘yolov8n/conv42’, ‘yolov8n/conv53’, ‘yolov8n/conv63’]
[info] matmul_equalization skipped
[info] Adaround skipped
[info] Fine Tune skipped
[info] Adding an output layer after conv41
[info] Adding an output layer after conv42
[info] Adding an output layer after conv52
[info] Adding an output layer after conv53
[info] Adding an output layer after conv62
[info] Adding an output layer after conv63
[warning] Output order different size
[info] Resources optimization guidelines: Strategy → GREEDY Objective → MAX_FPS
[info] Resources optimization params: max_control_utilization=75%, max_compute_utilization=75%, max_compute_16bit_utilization=75%, max_memory_utilization (weights)=75%, max_input_aligner_utilization=75%, max_apu_utilization=75%
Validating context_0 layer by layer (100%)
● Finished
Context:0/0 Iteration 4: Trying parallel mapping…
cluster_0 cluster_1 cluster_2 cluster_3 cluster_4 cluster_5 cluster_6 cluster_7 prepost
worker0 V V V V V V V V V
worker1 V V V V V V V V V
worker2 V V V V V V V V V
worker3 V V V V V V V V V
00:04
Reverts on cluster mapping: 0
Reverts on split failed: 0
[info] Iterations: 4
[info] ±----------±--------------------±--------------------±-------------------+
[info] | Cluster | Control Utilization | Compute Utilization | Memory Utilization |
[info] | cluster_0 | 43.8% | 12.5% | 11.7% |
[info] | cluster_1 | 31.3% | 12.5% | 6.3% |
[info] | cluster_2 | 75% | 53.1% | 17.2% |
[info] | cluster_3 | 87.5% | 60.9% | 44.5% |
[info] | cluster_4 | 75% | 42.2% | 22.7% |
[info] | cluster_5 | 100% | 65.6% | 32% |
[info] | cluster_6 | 87.5% | 31.3% | 30.5% |
[info] | cluster_7 | 100% | 67.2% | 20.3% |
[info] | Total | 75% | 43.2% | 23.1% |
[info] Successful Mapping (allocation time: 24s)
[info] Compiling context_0…
[info] Bandwidth of model inputs: 9.375 Mbps, outputs: 4.35791 Mbps (for a single frame)
[info] Bandwidth of inter context tensors: 0.0 Mbps (for a single frame)
[info] Building HEF…
[info] Successful Compilation (compilation time: 8s)
HEF file written to yolov8n.hef
Please clarify these question:
  1. even though I’m having GPU it is saying that no GPU.
  2. Why during optimization time some highlighted are skipped, Can’t we avoid that skipping in cli command?
  3. Required GPU is hailo accelerator or Nvidia is fine?
Your input is very much required.
Thanks
Ubuntu 24 is currently not supported. We will add it later in the year. Currently you can use Ubuntu 20 and 22.
Make sure you follow the installation instructions in the Hailo AI Software Suite User Guide. You will need the nvidia-docker2 support.
Have a look at the scripts that starts the docker. There are tests before GPU support is enabled. You can run them manually to see which one is failing. You will need to delete the container and create a new one. GPU support is only checked when a new container is created. You can keep the docker image.
They are skipped because you have no GPU support.
The Hailo device is not needed to convert a model. You need a NVIDIA GPU for the model optimization.
I’m able to resolve that GPU issue.
Also, I have doubt my object dataset is having white, blue, red and green as the class. When I won’t pass the labels.json it will detect like person, bicycle, motorbike etc…
during hef converion, I’ve only required class in coco_names.json.
My requirement is I shouldn’t pass any label.json for detection. It should be as above instead it should have my classes.
Any other places should I change other than coco_name.json?
please help here.
hey im facing the same problem do you have any solution to his?
