Does the Raspberry Pi AI Kit HAT with Hailo-8L chip provide power through GPIO or only PCIe?
I’m using the Raspberry Pi(https://www.raspberrypi.com/documentation/accessories/ai-kit.html) AI Kit with the Hailo-8L chip, and I want to confirm the power requirements for this setup. Does the Hailo-8L HAT receive power solely through the PCIe/M.2 interface, or does it also require power from the GPIO pins? My goal is to power the HAT only through the PCIe connection if possible.
Yes, you can run the Hailo-8L without needing additional power from the GPIOs. The power supplied through the PCIe connector is sufficient for its operation.
How about the Raspberry Pi AI HAT+ 26 TOPS and 40 TOPS model? Does it require additional power through the GPIO header?
@Sivam_Natesan The Raspberry Pi AI HAT+ can operate without additional power in many cases. However, if you plan to run heavier AI workloads, connecting the GPIO header is recommended to ensure a stable power supply and avoid power-related issues.
