Hi there,
I am evaluating the Hailo as an option for an on-device inference accelerator. I have a model that was trained using Pytorch and compiled to ONNX. When attempting to convert the ONNX file to HAR using the Dataflow Compiler, it raises an error where it incorrectly tries to shape an array:
ValueError: cannot reshape array of size 12513 into shape (1,129,1)
The above should be (1, 129, 97). Previously, this model was successfully compiled using Intel’s OpenVINO (compiled for inference on their Neural Compute Stick 2).
I am happy to share the .onnx file if there is a way to do so. I’ve inspected the the onnx graph using Netron (https://netron.app/) but I haven’t been able to spot where the issue arises.
Any help or advice is much appreciated, thanks! The full verbose traceback is below:
ValueError Traceback (most recent call last)
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:239, in Parser.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
238 try:
--> 239 parsing_results = self._parse_onnx_model_to_hn(
240 onnx_model=onnx_model,
241 net_name=valid_net_name,
242 start_node_names=start_node_names,
243 end_node_names=end_node_names,
244 net_input_shapes=net_input_shapes,
245 disable_shape_inference=disable_shape_inference,
246 net_input_format=net_input_format,
247 )
249 except Exception as e:
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:320, in Parser._parse_onnx_model_to_hn(self, onnx_model, net_name, start_node_names, end_node_names, net_input_shapes, disable_shape_inference, net_input_format, **kwargs)
318 self._logger.warning(f"ONNX shape inference failed: {e!s}")
--> 320 return self.parse_model_to_hn(
321 onnx_model,
322 None,
323 net_name,
324 start_node_names,
325 end_node_names,
326 nn_framework=NNFramework.ONNX,
327 output_shapes=output_shapes,
328 net_input_format=net_input_format,
329 **kwargs,
330 )
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:371, in Parser.parse_model_to_hn(self, model, values, net_name, start_node_names, end_node_names, nn_framework, output_shapes, net_input_format, rename_layers_by_blocks)
369 raise BackendRuntimeException(f"Unsupported NN framework {nn_framework}")
--> 371 fuser = HailoNNFuser(converter.convert_model(), net_name, converter.end_node_names)
372 hailo_nn = fuser.convert_model()
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py:83, in HailoNNConverter.convert_model(self)
82 self._validate_bn_ops_in_training()
---> 83 self._create_layers()
84 self._add_layers_connections()
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py:39, in EdgeNNConverter._create_layers(self)
38 self._update_vertices_info()
---> 39 self._add_direct_layers()
40 self._validate_processed_vertices()
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py:121, in EdgeNNConverter._add_direct_layers(self)
120 self._logger.debug(f"Processing vertex {vertex.name}")
--> 121 self._layer_callback_from_vertex(vertex)
122 self._visited_states[vertex] = VertexState.PROCESSED
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py:430, in ONNXConverter._layer_callback_from_vertex(self, vertex)
429 if vertex.is_ew_add():
--> 430 self._create_ew_add_layer(vertex)
431 elif vertex.is_mul_by_2_ew_add():
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py:1158, in ONNXConverter._create_ew_add_layer(self, vertex)
1157 def _create_ew_add_layer(self, vertex):
-> 1158 self._create_ew_layer(vertex, EWAddLayer)
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py:1181, in ONNXConverter._create_ew_layer(self, vertex, layer_cls)
1180 if is_ew_op_with_const_input:
-> 1181 const_layer, ew_op_input = self._create_ew_const_input_layer(vertex)
1183 layer = layer_cls.create(
1184 vertex.name,
1185 ew_op_input,
1186 output_shapes=vertex.get_output_shapes(validate_zero_dims=True),
1187 )
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py:1213, in ONNXConverter._create_ew_const_input_layer(self, vertex)
1212 const_output_shape = [-1, ew_op_output_shape[1], ew_op_output_shape[3], ew_op_output_shape[2]]
-> 1213 input_values = np.reshape(input_values, [1, *ew_op_output_shape[2:]])
1214 else:
File <__array_function__ internals>:180, in reshape(*args, **kwargs)
File ~/.local/lib/python3.10/site-packages/numpy/core/fromnumeric.py:298, in reshape(a, newshape, order)
200 """
201 Gives a new shape to an array without changing its data.
202
296 [5, 6]])
297 """
--> 298 return _wrapfunc(a, 'reshape', newshape, order=order)
File ~/.local/lib/python3.10/site-packages/numpy/core/fromnumeric.py:57, in _wrapfunc(obj, method, *args, **kwds)
56 try:
---> 57 return bound(*args, **kwds)
58 except TypeError:
59 # A TypeError occurs if the object does have such a method in its
60 # class, but its signature is not identical to that of NumPy's. This
64 # Call _wrapit from within the except clause to ensure a potential
65 # exception has a traceback chain.
Cell In[42], line 2
1 runner = ClientRunner(hw_arch=chosen_hw_arch)
----> 2 hn, npz = runner.translate_onnx_model(
3 onnx_path,
4 onnx_model_name,
5 # disable_shape_inference=True,
6 # start_node_names=["onnx::Cast_0"],
7 # end_node_names=["192"],
8 # net_input_shapes={"onnx::Cast_0": [1, 1, 193, 1032]},
9 )
File ~/.local/lib/python3.10/site-packages/hailo_sdk_common/states/states.py:16, in allowed_states.<locals>.wrap.<locals>.wrapped_func(self, *args, **kwargs)
13 raise InvalidStateException(
14 f"The execution of {func.__name__} is not available under the state: {self._state.value}",
15 )
---> 16 return func(self, *args, **kwargs)
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:1177, in ClientRunner.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
1134 """
1135 DFC API for parsing an ONNX model. This creates a runner with loaded HN (model) and
1136 parameters.
1174
1175 """
1176 parser = Parser()
-> 1177 parser.translate_onnx_model(
1178 model=model,
1179 net_name=net_name,
1180 start_node_names=start_node_names,
1181 end_node_names=end_node_names,
1182 net_input_shapes=net_input_shapes,
1183 augmented_path=augmented_path,
1184 disable_shape_inference=disable_shape_inference,
1185 disable_rt_metadata_extraction=disable_rt_metadata_extraction,
1186 net_input_format=net_input_format,
1187 **kwargs,
1188 )
1189 return self._finalize_parsing(parser.return_data)
File ~/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:280, in Parser.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
277 milestone = self._format_time_milestone(start_time)
278 self._logger.info(f"Simplified ONNX model for a parsing retry attempt (completion time: {milestone})")
--> 280 parsing_results = self._parse_onnx_model_to_hn(
281 onnx_model=simplified_model,
282 net_name=valid_net_name,
283 start_node_names=start_node_names,
284 end_node_names=end_node_names,
285 net_input_shapes=net_input_shapes,
286 disable_shape_inference=disable_shape_inference,
287 net_input_format=net_input_format,
288 **kwargs,
289 )
291 milestone = self._format_time_milestone(start_time)
292 self._logger.info(f"Translation completed on ONNX model {valid_net_name} (completion time: {milestone})")
317 except Exception as e:
321 onnx_model,
322 None,
323 net_name,
325 end_node_names,
329 **kwargs,
330 )
368 else:
373 hailo_nn.validate_stage(HnStage.HN)
81 self._validate_model_params()
85 self._layers_graph.set_names_and_indices()
37 self._add_input_layers()
119 elif vertex not in self._visited_states:
124 for node in sorted(self._graph.successors(vertex), key=attrgetter("name")):
428 elif vertex.op in ADD_OPS:
432 self._create_normalization_layer(vertex)
1179 const_layer = None
1184 vertex.name,
1185 ew_op_input,
1187 )
1188 self._add_layer(layer)
1211 else:
1214 else:
1215 const_output_shape = [-1, *ew_op_output_shape[1:4]]
198 @array_function_dispatch(_reshape_dispatcher)
199 def reshape(a, newshape, order='C'):
200 """
202
296 [5, 6]])
297 """
54 return _wrapit(obj, method, *args, **kwds)
56 try:
66 return _wrapit(obj, method, *args, **kwds)
