I configured NMS when compiling using the following settings. The “w” and “h” values were copied from the anchor box widths and heights found here:
nms_layer_config = {
    "nms_scores_th": 0.001,
    "nms_iou_th": 0.5,
    "image_dims": [320, 320],
    "centers_scale_factor": 1,
    "bbox_dimensions_scale_factor": 1,
    "classes": 2,
    "background_removal": True,
    "bbox_decoders": [
            "w": [0.075, 0.10606602, 0.05303301, 0.09449408, 0.13363481,
                  0.06681741, 0.11905508, 0.1683693, 0.08418465],
            "h": [0.075, 0.05303301, 0.10606602, 0.09449408, 0.06681741,
                  0.13363481, 0.11905508, 0.08418465, 0.1683693],
            "reg_layer": "sprite_cola_model/conv65",
            "cls_layer": "sprite_cola_model/conv66"
            "w": [0.15, 0.21213203, 0.10606602, 0.18898816, 0.26726963,
                  0.13363481, 0.23811015, 0.3367386, 0.1683693],
            "h": [0.15, 0.10606602, 0.21213203, 0.18898816, 0.13363481,
                  0.26726963, 0.23811015, 0.1683693, 0.3367386],
            "reg_layer": "sprite_cola_model/conv74",
            "cls_layer": "sprite_cola_model/conv75"
        # More bbox decoders...
also modified my detection pipeline using GStreamer, as shown below:
    def __init__(self, app_callback, user_data):
        parser = get_default_parser()
        parser.add_argument(
            "--labels-json",
            default=None,
            help="Path to custom labels JSON file",
        args = parser.parse_args()
        super().__init__(args, user_data)
        # Set Hailo model parameters
        self.batch_size = 1
        self.network_width = 320
        self.network_height = 320
        self.network_format = "RGB"
        nms_score_threshold = 0.001
        nms_iou_threshold = 0.5
still not able to see bounding boxes in the output properly. I could see a bounding box very low accurately and not precisely.
Thanks
