Hi everyone,
I’m using Hailo AI Software Suite Version 2025-04 with a Raspberry Pi 5 and Raspberry Pi AI HAT. I trained a custom YOLOv8n model (only 1 class) using Ultralytics and exported it to ONNX using the following code:
model.export(format="onnx", imgsz=640, dynamic=False, simplify=True, opset=11)
Then I followed the standard Hailo Model Zoo steps to convert the ONNX model into a HEF file:
hailomz parse --hw-arch hailo8l --ckpt /mnt/workspace/customYolov8nbest.onnx yolov8n
hailomz optimize --hw-arch hailo8l --calib-path /mnt/workspace/calibration_images yolov8n
hailomz compile \
--hw-arch hailo8l \
yolov8n
The HEF file is successfully generated.
However, when I run the model on my target device (Raspberry Pi 5 + Hailo AI HAT), it does not detect any objects at all. The debug output from my inference code looks like this:
------------------- DEBUG -------------------
Raw output tensor: []
Max coordinate value: 0
Max score (col 4): 0
Shape: (0, 5)
Frame shape: (272, 480, 3)
Preprocessed shape: (3, 640, 640)
Input name: yolov8n/input_layer1
Output name: yolov8n/yolov8_nms_postprocess
Output tensor dtype: float64
Preprocessed dtype: float32
So the output tensor has shape (0, 5), meaning no detections. Even though the image preprocessing works and the pipeline runs without crashing, the model returns empty outputs.
My questions:
- Could the issue be caused by an incorrect postprocessing or NMS layer during the export or compilation?
- Is there a specific configuration required for single-class YOLOv8 models?
- Could the
output_shapeor layer names be mismatched duringparse/optimize/compilesteps? - Should I explicitly set quantization parameters or data types (e.g., float32 vs uint8)?
- Has anyone encountered this issue with single-class models compiled for Hailo?
Any help would be appreciated
I can also share the ONNX model or python file if needed.
Thanks!
