Early Access to DeGirum Cloud Compiler
Over the last few months, we noticed a number of developers reaching out for help compiling YOLO models for Hailo. We provided one-off support, but it wasn’t scalable. So, we built something better.
It’s called the DeGirum Cloud Compiler, and it’s now in early access. It is a browser-based tool that lets you compile YOLO models for Hailo in just a few clicks. No setup, no toolchains, no guesswork. Just upload your PyTorch checkpoint and get back a Hailo-optimized format (.hef), often in under 10 minutes.
Note: You’ll need a free DeGirum AI Hub account to use it and test your models in the browser.
What it supports
  • YOLOv8 and YOLO11
  • All model sizes: n, s, m, l, x
  • Tasks like:
    • Object detection
    • Classification
    • Semantic segmentation
    • Oriented bounding box detection
    • Keypoint estimation
  • Different input resolution during compilation
  • Optimized C++ postprocessing integrated via DeGirum PySDK
  • Instant testing in the browser, no download or setup needed
  • Fast compiles (usually under 10 mins)
Who this is for:
This might be for you if you’re working with YOLO models and want to:
  • Skip the toolchain wrangling
  • Go straight from PyTorch checkpoint to Hailo HEF file
  • Try out different model sizes and resolutions in minutes
  • See if your model works before deploying, right in the browser
Why early access?
The tool is new, and we want your feedback. If something is confusing or broken, we want to hear about it. If something works well, we want to build on it.
Note: The early access period is free of charge, but may conclude at any time. After this period, access to the Cloud Compiler may transition to a paid subscription model. Participants will be notified in advance of any changes to access terms.
How to get access
Fill out this short form: Request Access to Cloud Compiler
We’re letting users in gradually, so keep an eye on your inbox.
Very exciting feature, actually
This compiler works really fast and available online. Lifesaver for Raspberry Pi without server.
Online models are compiling fast, thanks DeGirum and Shashi
That sounds fantastic. I’ll use it if I get the chance. Just one question. Will the servers retain the files? Or do they just process the conversion and return it to the user? Will the Cloud Compiler work like Degirum’s AI Hub, where the converted files will be available or made public? I compare it to RoboFlow, where the free account makes datasets available to the public. In some cases, I prefer my files or models not to be made public.
@Luiz_Mageste
The compiled models are saved to a model zoo which is private to the workspace of the user. User can delete the model from the model zoo after they download. Only models maintained by DeGirum in degirum workspace are made public. Hope this clarifies your question.
Hello, could you also operate local LLMs with Hailo and would it also be possible to use LLMs for comfyui or other image ai generators? What simple online or local image training programs are available for your own image series that can be used with hailo. I am stuck with the car which autonomously recognizes between bad and good.
if anyone has any ideas or suggestions please let me know.
Hi @TM_TMK
Welcome to the Hailo community. Current compiler is for Hailo8/Hailo8L which are focused on computer vision models. LLMs will be supported in Hailo10 which will be available in the future.
Thanks for this tool, I have requested access… I will be happy to test various yolov8 and yolo11 conversions.
David.
Hi @david1
Received your request. We will keep you posted.
Hi @david1
You should now be able to use our cloud compiler. Please see your email inbox for instructions.
Hey! I have tried it with a YOLOv8S model. It feels like magic, you guys have done a great job!! I think I got the results in less than 5 minutes, with the quantization performed on 100 images. I’ll have a look into the other functionalities of the cloud platform, but this conversion tool alone would justify a subscription on my side. Or a pay-per-conversion token.
Best,
David.
Hi @david1
Happy to hear that you were able to compile without any issues. And thanks for the kind words.
I have submitted my application and am very much looking forward to experiencing this function as soon as possible.
Update: Please note that the original request form URL in this post is now outdated.
:white_check_mark: Apply for early access to the Cloud Compiler using the updated form: Request Early Access to DeGirum's Cloud Compiler
I am excited i found this platform, i currently have mt .pt file converted to .onnx; but the transition to the .hef file has been a hurdle. Hoping to get accepted so i can put to test my Hailo8
Hi @Emmanuel_Laryea
We are processing your request. You should hear from us shortly with the next steps. We hope to see you compile your first model shortly.
So an update, i successfully converted to the .hef file using the Hailo AI software suite with my original training dataset without hiccups on my cpu. I cant wait to test Degirum Compiler also.
@Emmanuel_Laryea
your access request has been approved. You should now be able to use our cloud compiler.
Hi @shashi i am also extremely excited to check out this tool. Have unfortunately been stuck at converting onnx to hef for a long time. I have filled out the form.
Hi @Nityam_Patel
We just received your request and are working on its approval. Once approved, you will get an email from us with instructions.
