I am trying to compile and optimize a custom YOLOv8n model for Hailo8L using hailomz. Here’s what I have attempted so far:
Compile directly from ONNX
Command:
hailomz compile --ckpt yolov8n.onnx --yaml yolov8n.yaml --hw-arch hailo8l -
Error: Parsing failed at
nms_postprocess_end_nodesin the.allsscript.
Optimize using HAR file
Command:
hailomz optimize --har yolov8n_custom.har --hw-arch hailo8l yolov8n -
Error:
HailoNNException: The layer named yolov8n/conv41 doesn't exist.
Using NMS config from Hailo examples
Tried using JSON from
postprocess_configfolder -
Error during calibration:
ValueError: None values not supported.
Reduced calibration dataset / CPU-only optimization
Dataset: 64 images, optimization level reduced to 0
Error: Post-processing layer fails, optimization incomplete.
I’m trying “https://community.hailo.ai/t/convert-to-hef-for-hailo8l-unable-to-compile-yolov8-onnx-model-with-hailomz-model-script-not-found/17613”. There have been many attempts. The task was to detect birds. The yolo network was trained. 1. Python script for train : “import torch
from ultralytics import YOLO
import os
def main():
Проверка доступных GPU
if torch.cuda.is_available():
gpus = list(range(torch.cuda.device_count()))
device = “,”.join(map(str, gpus)) # “0,1,2,3,4,5,6,7”
else:
device = “cpu”
gpus =
print(f" Используем устройство: {device}, GPU: {len(gpus)}")
# Путь к директории с предыдущими результатами обучения
checkpoint_dir = "runs/detect/train"
# Определение последней сохранённой модели для продолжения обучения
last_checkpoint = None
if os.path.exists(checkpoint_dir):
checkpoints = [f for f in os.listdir(checkpoint_dir) if f.endswith(".pt")]
if checkpoints:
last_checkpoint = os.path.join(checkpoint_dir, sorted(checkpoints)[-1])
print(f" Продолжаем обучение с модели: {last_checkpoint}")
else:
print("⚠️ Нет сохранённых моделей для продолжения обучения.")
else:
print("⚠️ Директория с результатами обучения не найдена.")
# Загрузка модели
model = YOLO("yolov8n.pt") # или путь к собственной модели
# Если есть сохранённая модель, продолжаем с неё
if last_checkpoint:
model.load(last_checkpoint)
# Обучение
model.train(
data="dataset_bird.yaml",
epochs=300,
imgsz=640,
batch=512,
workers=8,
device=device,
optimizer="AdamW",
lr0=0.0005,
patience=50,
cos_lr=True,
augment=True,
dropout=0.1
if name == “main”:
main()“.
2. dataset_bird.yaml: “path: .
train: train/
val: valid/
test: test/
names:
0: bird“.
- Result train: “Validating /mnt/ramdisk/Dataset_bird_2/Birds/runs/detect/train/weights/best.pt…
Ultralytics 8.3.195 Python-3.10.12 torch-2.1.0+cu118 CUDA:0 (NVIDIA A2, 14891MiB)
CUDA:1 (NVIDIA A2, 14891MiB)
CUDA:2 (NVIDIA A2, 14891MiB)
CUDA:3 (NVIDIA A2, 14891MiB)
CUDA:4 (NVIDIA A2, 14891MiB)
CUDA:5 (NVIDIA A2, 14891MiB)
CUDA:6 (NVIDIA A2, 14891MiB)
CUDA:7 (NVIDIA A2, 14891MiB)
Model summary (fused): 72 layers, 3,005,843 parameters, 0 gradients, 8.1 GFLOPs
Class Images Instances Box(P R mAP50 mAP50-95): 100% ━━━━━━━━━━━━ 4/4 0.7it/s 6.0s
all 469 486 0.892 0.934 0.964 0.666
Speed: 0.2ms preprocess, 7.5ms inference, 0.0ms loss, 0.8ms postprocess per image
Results saved to /mnt/ramdisk/Dataset_bird_2/Birds/runs/detect/train“. - download GitHub - hailo-ai/hailo_model_zoo at v2.16 for hailo8l.
Question:
I have a custom YOLOv8n model in .pt format and I want to run it on a Raspberry Pi 5 with a Hailo8L accelerator for bird detection.
What is the correct workflow to convert a .pt PyTorch model to a Hailo-compatible format (HEF/HAR) for Hailo8L?
How can I deploy and run the compiled model efficiently on Raspberry Pi 5?
I am a beginner in this field and do not understand how to use this hailo8l device in practice for scientific purposes.
