Hi @omria ,
thanks for your fast reply!
I tested your steps but still receive an error when I start parsing with the now CRNN Lite Model. Hope it have no impact on the yaml config…
(hailo_virtualenv) hailo@test:/local/workspace/custo_models$ hailomz parse --ckpt test_crnn.onnx --yaml test_crnn.yaml
<Hailo Model Zoo INFO> Start run for network test_crnn ...
<Hailo Model Zoo INFO> Initializing the runner...
  File "/local/workspace/hailo_virtualenv/bin/hailomz", line 33, in <module>
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
    run(args)
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 201, in parse
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 126, in parse_model
    raise Exception(f"Encountered error during parsing: {err}") from None
Exception: Encountered error during parsing: Expecting value: line 1 column 1 (char 0)
Do you know this error and can help me to solve it?
By the optimize cmd I receive this error:
    run(args)
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 211, in optimize
    if args.calib_path is None and network_info.quantization.calib_set is None:
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py", line 355, in __getattr__
    self._format_and_raise(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/base.py", line 231, in _format_and_raise
    format_and_raise(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/_utils.py", line 899, in format_and_raise
    _raise(ex, cause)
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/_utils.py", line 797, in _raise
    raise ex.with_traceback(sys.exc_info()[2])  # set env var OC_CAUSE=1 for full trace
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py", line 351, in __getattr__
    return self._get_impl(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py", line 442, in _get_impl
    node = self._get_child(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/basecontainer.py", line 73, in _get_child
    child = self._get_node(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py", line 480, in _get_node
    raise ConfigKeyError(f"Missing key {key!s}")
omegaconf.errors.ConfigAttributeError: Missing key quantization
    full_key: quantization
    object_type=dict
And the compile returns still the url error…
<Hailo Model Zoo INFO> Start run for network uldnet_crnn ...
<Hailo Model Zoo INFO> Initializing the hailo8 runner...
    run(args)
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 248, in compile
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 73, in _ensure_optimized
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 108, in _ensure_parsed
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 99, in parse_model
    ckpt_path = download_model(network_info, logger)
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 86, in download_model
    url = network_info.paths.url
    format_and_raise(
    _raise(ex, cause)
omegaconf.errors.ConfigAttributeError: Missing key url
    full_key: paths.url
    object_type=dict
Can you help me to solve this issues? I have now two yolo5 and one CRNN lite model which I would like to compile and run on the hailo8. The models are well and it would be good to bring them on the Hailo so that the use case is working together with the TPU from Hailo
Best regards from Germany and thank you very much for your support!
Felix Rottmann
