Hello Hailo Community,
I’m a student from South Korea currently studying AI and embedded systems. As part of my project, I fine-tuned a YOLOv8n model for object detection and am now trying to convert it into the Hailo Executable Format (HEF) using the Hailo Model Zoo. My goal is to evaluate its performance on Hailo hardware.
Here’s what I have done so far:
- I fine-tuned the YOLOv8n model and exported it in ONNX format.
- I prepared a calibration dataset for quantization.
- I created a
model_config.yamlfile based on the official documentation, specifying the input and output shapes, quantization mode, and parser settings. - I attempted to compile the model using the
hailomz compilecommand with the following configuration:
hailomz compile yolov8n
–ckpt /workspace/yolov8n.onnx
–calib-path /workspace/calibration_data/data/images
–yaml /workspace/model_config.yaml
–hw-arch hailo8l
However, I encountered the following error:
omegaconf.errors.ConfigAttributeError: Missing key parser
full_key: parser
object_type: dict
Below is the model_config.yaml file I am currently using:
model:
framework: onnx
input_shapes:
- [1, 3, 640, 640]
input_names:
- images
output_shapes:
- [1, 5, 8400]
output_names:
- output0
quantization:
mode: int8
calib_data_path: /workspace/calibration_data/data/images
network:
network_name: yolov8n
parser:
start_node_shapes:
- [1, 3, 640, 640]
end_node_shapes:
- [1, 5, 8400]
nodes:
- images
- output0
My Questions:
- Am I missing any required keys or parameters in my
model_config.yamlfile? If so, could you point out the missing parts? - Could this issue be related to unsupported operations in my ONNX model, and if so, how can I identify and resolve them?
- Is there a specific way to debug this problem further, or should I take a different approach?
I am using:
- Hailo Dataflow Compiler v3.30.0
- HailoRT v4.20.0
- Hailo Model Zoo v2.14.0
Your guidance would be greatly appreciated. Thank you for your time and support!
