After Running hailomz parse.
I have received the following error. Although it was working just a week ago.
It’s a simple script the same one I was using all the type just to convert .pt model to onnx and then to .hef
#!/bin/bash
Check if correct number of arguments are passed
if [ “$#” -ne 3 ]; then
echo “Usage: $0 <path_to_pt_file> <path_to_calib_folder> <output_onnx_filename>”
exit 1
fi
Set arguments
PT_FILE=$1
CALIB_PATH=$2
ONNX_FILE=$3
Define working directory
WORKING_DIR=“./”
HAR_FILE=“${WORKING_DIR}/yolov8s.har”
HAILO_MODEL_ZOO=“${WORKING_DIR}/hailo_model_zoo”
MODEL_SCRIPT=“${HAILO_MODEL_ZOO}/hailo_model_zoo/cfg/alls/generic/yolov8s.alls”
Step 1: Convert YOLO model to ONNX
echo “Exporting YOLO model to ONNX…”
yolo export model=${PT_FILE} format=onnx
Step 2: Parse the ONNX model using Hailo
echo “Parsing ONNX model for Hailo hardware…”
hailomz parse --hw-arch hailo8l --ckpt ${WORKING_DIR}/${ONNX_FILE} yolov8s
Step 3: Optimize the parsed model
echo “Optimizing the model…”
hailomz optimize --hw-arch hailo8l --calib-path ${WORKING_DIR}/${CALIB_PATH} --har ${HAR_FILE} --classes 1 yolov8s
Step 4: Compile the model for Hailo
echo “Compiling the model…”
hailomz compile --hw-arch hailo8l --model-script ${MODEL_SCRIPT} --calib-path ${WORKING_DIR}/${CALIB_PATH} --har ${HAR_FILE} --classes 1 yolov8s
echo “Process complete. Output saved as yolov8n.har”
oman@MSI:/mnt/c/Users/Roman/Desktop/Hailo_working$ hailomz compile --ckpt yolov8s.onnx --calib-path /mnt/c/Users/Roman/Desktop/Hailo_working/calib_plane --yaml /mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/cfg/networks/yolov8s.yaml --start-node-names ‘images’ --end-node-names ‘/model.22/cv2.0/cv2.0.2/Conv’ ‘/model.22/cv3.0/cv3.0.2/Conv’ ‘/model.22/cv2.1/cv2.1.2/Conv’ ‘/model.22/cv3.1/cv3.1.2/Conv’ ‘/model.22/cv2.2/cv2.2.2/Conv’ ‘/model.22/cv3.2/cv3.2.2/Conv’ --classes 1
Start run for network yolov8s …
[info] Restored ONNX model yolov8s (completion time: 00:00:00.68)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.78)
[info] Start nodes mapped from original model: ‘images’: ‘yolov8s/input_layer1’.
[info] Translation completed on ONNX model yolov8s (completion time: 00:00:01.20)
[info] Saved HAR to: /mnt/c/Users/Roman/Desktop/Hailo_working/yolov8s.har
Preparing calibration data…
[info] Loading model script commands to yolov8s from /mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8s.alls
[info] Loading model script commands to yolov8s from string
File “/home/roman/.local/bin/hailomz”, line 33, in
File “/mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 250, in compile
File “/mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 91, in _ensure_optimized
optimize_model(
File “/mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 319, in optimize_model
optimize_full_precision_model(runner, calib_feed_callback, logger, model_script, resize, input_conversion, classes)
File “/mnt/c/Users/Roman/Desktop/Hailo_working/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 305, in optimize_full_precision_model
runner.optimize_full_precision(calib_data=calib_feed_callback)
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1996, in optimize_full_precision
self._optimize_full_precision(calib_data=calib_data, data_type=data_type)
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1999, in _optimize_full_precision
self._sdk_backend.optimize_full_precision(calib_data=calib_data, data_type=data_type)
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1483, in optimize_full_precision
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1374, in _apply_model_modification_commands
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 381, in apply
pp_creator = create_nms_postprocess(
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1661, in create_nms_postprocess
pp_creator.prepare_hn_and_weights(hw_consts, engine)
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1103, in prepare_hn_and_weights
super().prepare_hn_and_weights(hw_consts, engine, layers_to_sigmoid)
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1071, in prepare_hn_and_weights
self.add_postprocess_layer_to_hn()
File “/home/roman/.local/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1022, in add_postprocess_layer_to_hn
raise NMSConfigPostprocessException(f"The layer {encoded_layer.name} doesn’t have one output layer")
hailo_sdk_client.tools.core_postprocess.nms_postprocess.NMSConfigPostprocessException: The layer yolov8s/conv41 doesn’t have one output layer
I am running datacompiler 3.28 and model zoo 2.12
All the other guides doesn’t answer on that problem so I don’t really know where to go with that.
Note I haven’t edited the model in any way.
what may be the issue and what do I do?
