Hi @Cameron_Ward
Please change HAILO8l to HAILO8L (small l to capital L) and HAILORT/HAILO8l to HAILORT/HAILO8L.
That fixed it, thanks!
@Cameron_Ward
Thanks for confirming. We will see if we can clearly call this out in our docs/guides so that future users do not face this issue. Since edits are not allowed, we need to think of a better way.
Hi @shashi , actually I’m stuck while running multiple inferences on multiple models using the DeGirum Suite as the code that the DeGirum repo has provided uses their own compiled versions of the hef models but when I try to run the same script for multi-inference using my custom hef models which are basically custom trained yolov11n models, then I’m getting the following error:
Exception: Error detected during execution of AiSimpleGizmo:
<class 'degirum.exceptions.DegirumException'>: Failed to perform model 'Person_Vehicle_CCTV' inference: [ERROR]Execution failed
Condition 'input_tensor->shape()[ 1 ] == 4 + m_OutputNumClasses' is not met: input_tensor->shape()[ 1 ] is 1, 4 + m_OutputNumClasses is 11
dg_postprocess_detection.cpp: 1612 [DG::DetectionPostprocessYoloV8::inputDataProcessBaseline]
When running model 'Person'
<class 'degirum.exceptions.DegirumException'>: Failed to perform model 'fire_smoke_drone' inference: [ERROR]Execution failed
When running model 'fire_smoke'
The config of both my models look like the following:
"Checksum": "dummy_sh",
"ConfigVersion": 10,
"DEVICE": [
"DeviceType": "HAILO8",
"RuntimeAgent": "HAILORT",
"SupportedDeviceTypes": "HAILORT/HAILO8",
"ThreadPackSize": 6
"MODEL_PARAMETERS": [
"ModelPath": "Person.hef"
"POST_PROCESS": [
"LabelsPath": "labels_Person.json",
"OutputNumClasses": 7,
"OutputPostprocessType": "DetectionYoloV8"
"PRE_PROCESS": [
"InputN": 1,
"InputH": 640,
"InputW": 640,
"InputC": 3,
"InputQuantEn": true
Is there any way I can compile my models in accordance with the DeGirum environment like the DeGirum’s model compiler or should I do something else because the models that I downloaded from their AI Hub are working perfectly for multi-inference ?
Hi @Nitheesh_Bopparaju
The postprocessor is configured incorrectly. Please see our guide: User Guide 3: Simplifying Object Detection on a Hailo Device Using DeGirum PySDK
Just to bring to your attention: the link to the models points to the H8 model, but for the Pi 5, it should definitely be the H8L. Could you please confirm if this is correct?
Hi @Info_Turnix
Welcome to the Hailo community. PySDK supports both Hailo8 and Hailo8L. Please note that there are two versions of RPi Hat: Hailo8 with 26 TOPS and Hailo8L with 13 TOPS. The examples and guides need to use the appropriate model based on the hardware and hence we cannot say that for Pi5 it should definitely be 8L. Hope this clarifies.
