User Guide 1 Hailo World: Running Your First Inference on a Hailo Device Using DeGirum PySDK
This guide is for ML developers who want to learn how to configure DeGirum PySDK to load a precompiled model and run inference on a Hailo device. Instead of a “just run this magic two line script” approach, we’ll focus on the essential details and steps involved. By the end of this guide, you’ll have a solid understanding of how to work with precompiled models and adapt the process to your needs.
What You’ll Need to Begin
To follow this guide, you’ll need a machine equipped with a Hailo AI accelerator, either Hailo8 or Hailo8L. The host CPU can be an x86 system or an Arm based system (like Raspberry Pi). Before diving in, make sure the necessary drivers and software tools are installed correctly. You can find the setup instructions here: Hailo + PySDK setup instructions.
Here’s what else you’ll need:
  1. A Model File (.hef): This is the compiled model for Hailo hardware. We’ll be using the mobilenet_v2_1.0 classification model, available for Hailo8 devices at Hailo8 Classification Models.
  2. An Input Image: The image you want to process using the model. For this guide, we’ll use a cat image, which you can download from Cat Image.
  3. A Labels File (labels_ILSVRC2012_1000.json): This file maps class indices to human-readable labels for ImageNet. You can download it from Hugging Face.
Download these assets and keep them handy, as you’ll use them throughout this guide.
Summary
In this guide, we’ll walk you through the steps to run inference on a Hailo device using DeGirum PySDK. Here’s what we’ll cover:
By the end of this guide, you’ll have a comprehensive understanding of how to configure, load, and run both manual and optimized pipelines using PySDK.
Loading a Model with DeGirum PySDK
The starting point for running inference with DeGirum PySDK is the load_model function. This function loads an ML model and returns a model object, which you can use to run inferences. For this guide, the function takes three arguments:
  1. model_name: The name of the ML model to be used for inference. This is the name of the model’s JSON file, without the .json extension (explained further under zoo_url).
  2. inference_host_address: Specifies where inference will run. PySDK supports three options:
    • @local: Runs inference on a local machine with a connected device (e.g., Hailo8).
    • ai_server_ip: Runs inference on an AI server.
    • @cloud: Runs inference on devices hosted in the DeGirum AI Hub.
      For this guide, we’ll use @local since we are working with a Hailo8 accelerator attached to our machine.
  3. zoo_url: Points to the model zoo containing model assets. For local inference, this is the path to the directory with all required assets. Each model in the zoo has a JSON file containing metadata like preprocessing steps, model parameters, and postprocessing details.
Understanding the Model JSON File
The model JSON file defines key configurations for the model, such as supported devices, preprocessing requirements, model paths, and postprocessing steps. Below is a simple example of a model JSON file that directly passes the input to the model and outputs raw results without additional processing:
Example: Simple Model JSON
    "ConfigVersion": 10,
    "DEVICE": [
            "DeviceType": "HAILO8",
            "RuntimeAgent": "HAILORT",
            "SupportedDeviceTypes": "HAILORT/HAILO8"
    "PRE_PROCESS": [
            "InputType": "Tensor",
            "InputN": 1,
            "InputH": 224,
            "InputW": 224,
            "InputC": 3,
            "InputRawDataType": "DG_UINT8"
    "MODEL_PARAMETERS": [
            "ModelPath": "mobilenet_v2_1.0.hef"
    "POST_PROCESS": [
            "OutputPostprocessType": "None"
Breaking Down the JSON
ConfigVersion
Specifies the JSON schema version. The current version is 10.
DEVICE
Defines the supported hardware. For Hailo devices:
  • DeviceType: Use HAILO8 for Hailo8 devices and HAILO8L for Hailo8L devices.
  • RuntimeAgent: Set to HAILORT.
This ensures the model isn’t loaded onto incompatible hardware.
PRE_PROCESS
Describes how input data should be formatted before inference. In this guide, we’ve simplified preprocessing by configuring PySDK to pass the input directly to the model without alteration.
  • InputType: Set to Tensor to indicate the input is already preprocessed.
  • InputN, InputH, InputW, InputC: Define the input’s batch size, height, width, and channels.
  • InputRawDataType: Specifies the input’s data type (e.g., DG_UINT8).
Note: The input size (InputH, InputW, InputC) and type (InputRawDataType) are essential for validation purposes. PySDK uses these to check that the input data matches the model’s requirements before running inference.
MODEL_PARAMETERS
Specifies the ModelPath, which is the path to the compiled .hef file required by Hailo devices.
POST_PROCESS
Defines how to handle the model’s raw output. In this guide, OutputPostprocessType is set to None, allowing you to work directly with raw model outputs. Advanced guides will explore PySDK’s built-in postprocessors, which can interpret outputs like bounding boxes, class labels, or keypoints.
Preparing the Model Zoo
Now that you understand the structure of the model JSON file, it’s time to organize your model assets. Choose a directory where you want to store all the assets for your models.
  1. Copy the JSON configuration example above into a file named mobilenet_v2_1.0.json.
  2. Place the corresponding mobilenet_v2_1.0.hef file in the same directory.
  3. Place the labels file in the same directory
If you prefer to organize models into separate directories for easier maintenance, you can create a dedicated directory for each model and store its assets there. PySDK will automatically search for model JSON files in all sub-directories of the specified zoo_url.
Running Inference
The mobilenet_v2_1.0 model takes a UINT8 array of size [1, 224, 224, 3] as input and outputs a UINT8 array of size [1, 1, 1, 1001]. Let’s start with a utility function that prepares the input image in the required format:
Utility Function to Prepare Input
import cv2
def resize_image_to_given_shape(image_path, input_shape=(1, 224, 224, 3)):
    Reads an image using OpenCV, resizes it with INTER_LINEAR interpolation, and ensures it matches the specified size.
    Args:
        image_path (str): Path to the input image.
        input_shape (tuple): Desired shape of the output array (batch_size, height, width, channels).
    Returns:
        np.ndarray: Image array of shape matching the input shape.
    if len(input_shape) != 4 or input_shape[0] != 1 or input_shape[3] != 3:
        raise ValueError("Input shape must be in the format (1, height, width, 3).")
    # Read the image using OpenCV
    image = cv2.imread(image_path)
    if image is None:
        raise FileNotFoundError(f"Image at path '{image_path}' could not be loaded.")
    # Convert BGR to RGB
    image = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
    # Resize the image using INTER_LINEAR interpolation
    resized_image = cv2.resize(image, (input_shape[2], input_shape[1]), interpolation=cv2.INTER_LINEAR)
    if resized_image.shape != (input_shape[1], input_shape[2], input_shape[3]):
        raise ValueError(f"Resized image has an unexpected shape: {resized_image.shape}")
    # Expand dimensions to match the batch size
    return np.expand_dims(resized_image, axis=0)
Running Inference
Now let’s load the model, prepare the input image, and run inference:
import degirum
from pprint import pprint
# Load the model
model = dg.load_model(
    model_name='mobilenet_v2_1.0',
    inference_host_address='@local',
    zoo_url='<path_to_model_zoo>'
# Prepare the input image
image_array = resize_image_to_given_shape('<path_to_cat_image>', model.input_shape[0])
# Run inference
inference_result = model(image_array)
# Pretty print the results
pprint(inference_result.results)
Interpreting the Results
The inference_result is of type degirum.postprocessor.InferenceResults. For now, we focus on inference_result.results, which is a list of dictionaries. Here’s how the output looks like:
[{'data': array([[[[0, 0, 0, ..., 0, 0, 0]]]], dtype=uint8),
  'id': 0,
  'name': 'mobilenet_v2_1_0/softmax1',
  'quantization': {'axis': -1, 'scale': [0.003921568859368563], 'zero': [0]},
  'shape': [1, 1, 1, 1001],
  'size': 1001,
  'type': 'DG_UINT8'}]
The output is a UINT8 array of shape [1, 1, 1, 1001], representing the probabilities of each of the 1001 ImageNet classes (1000 categories + 1 background class).
Post-Processing
The raw output from the model contains probabilities for all 1001 classes in the ImageNet dataset. To make the results meaningful, we extract the top-5 predictions and map them to their corresponding class labels using a labels file.
However, there’s a critical step to consider: adjusting the class index. Some models trained on datasets like ImageNet include an extra “background” class, which results in an off-by-one mismatch between the model’s output and the labels file. This adjustment ensures the predictions are mapped correctly to their labels.
Below is a function that performs the necessary post-processing, including dequantizing the raw output, extracting the top-k predictions, and mapping the adjusted class indices to labels:
import json
def postprocess_classification_output(output, labels_file, topk=5):
    Postprocesses the model output to extract top-k predictions, maps them to labels,
    and adjusts class indices based on label length compatibility.
    Args:
        output (list): The raw model output containing quantized data and metadata.
        labels_file (str): Path to the JSON file containing the list of labels.
        topk (int): Number of top predictions to extract.
    Returns:
        list of dict: List of dictionaries containing adjusted_class_id, class_id, labels, and probabilities.
    # Load labels from the JSON file
    with open(labels_file, "r") as f:
        labels = json.load(f)
    # Extract the first output (assuming only one output is present)
    output_data = output[0]
    # Extract relevant fields
    data = output_data['data']  # Quantized data
    scale = output_data['quantization']['scale'][0]  # Quantization scale
    zero = output_data['quantization']['zero'][0]  # Quantization zero point
    # Dequantize the data
    dequantized_data = (data.astype(np.float32) - zero) * scale
    # Flatten the data (assumes shape [1, 1, 1, N])
    dequantized_data = dequantized_data.flatten()
    # Get the top-k indices and probabilities
    top_k_indices = np.argsort(dequantized_data)[-topk:][::-1]  # Indices of top-k predictions
    top_k_probs = dequantized_data[top_k_indices]  # Probabilities of top-k predictions
    # Determine if class_index should be adjusted
    if len(labels) == len(dequantized_data):
        subtract_one = False
    elif len(labels) == len(dequantized_data) - 1:
        subtract_one = True
    else:
        print(f"Warning: Labels file is not compatible with output results. "
              f"Labels length: {len(labels)}, Output length: {len(dequantized_data)}")
        return []
    # Process the results and map to labels
    processed_results = []
    for class_index, probability in zip(top_k_indices, top_k_probs):
        if subtract_one:
            # Adjust class_index if needed
            adjusted_class_index = class_index - 1
            if class_index == 0:
                label = "Background"  # Background class exists only when subtract_one is True
            elif 0 <= adjusted_class_index < len(labels):
                label = labels[str(adjusted_class_index)]
            else:
                label = "Unknown"
        else:
            # No adjustment needed for class_index
            else:
                label = "Unknown"
        processed_results.append({
            "category_id": adjusted_class_index,
            "label": label,
            "score": probability
    return processed_results
Top-5 Predictions
You can use the above function to get the top 5 predictions as follows:
top5_predictions = postprocess_classification_output(inference_result.results, '<path_to_labels_file>', topk=5)
pprint(top5_predictions)
Example Output
[{'category_id': 285, 'label': 'Egyptian cat', 'score': 0.20000002},
 {'category_id': 287, 'label': 'lynx, catamount', 'score': 0.16078432},
 {'category_id': 282, 'label': 'tiger cat', 'score': 0.14117648},
 {'category_id': 281, 'label': 'tabby, tabby cat', 'score': 0.121568635},
 {'category_id': 189, 'label': 'Lakeland terrier', 'score': 0.011764707}]
Conclusion
With this workflow, you can run inference on any compiled model using Hailo devices and DeGirum PySDK. While basic inference might be possible without PySDK, the real advantage of PySDK is its ability to simplify the development of complex AI applications. Future guides will explore advanced features, but this guide gives you a strong foundation to start experimenting!
Leveraging Built-in PySDK Features
The code provided in this guide is instructive and easy to follow but not practical for production systems. Developers often write boilerplate code for tasks like pre-processing and post-processing for each model, leading to scattered snippets that must be carried along with the application code. Over time, this approach becomes cumbersome, and developers start building structured classes to avoid repetition, which can eventually balloon into a development effort of its own.
At DeGirum, we’ve been down this road and recognized that managing pre-processing and post-processing code is a significant challenge when working with ML models. While we don’t claim to have a universal solution, PySDK provides a framework that simplifies this process. For common use cases and popular model architectures, PySDK integrates highly optimized C++ post-processors and built-in pre-processors, enabling developers to focus on solving real-world problems instead of writing repetitive code.
To illustrate the power of PySDK, here’s an example of a modified JSON configuration that leverages PySDK’s built-in pre-processors and post-processors. This configuration handles tasks like resizing, padding, quantization, and classification post-processing directly within PySDK, eliminating the need for custom Python code:
JSON with Built-in Pre-Processor and Post-Processor
  "DEVICE": [
  "PRE_PROCESS": [
      "InputType": "Image",
      "ImageBackend": "opencv",
      "InputPadMethod": "stretch",
      "InputResizeMethod": "bilinear",
      "InputN": 1,
      "InputH": 224,
      "InputW": 224,
      "InputC": 3,
      "InputQuantEn": true
  "POST_PROCESS": [
      "OutputPostprocessType": "Classification",
      "OutputTopK": 5,
      "OutputNumClasses": 1000,
      "OutputClassIDAdjustment": 1,
      "LabelsPath": "labels_ILSVRC2012_1000.json"
Instructions
  1. Save this modified JSON file as mobilenet_v2_1.0_optimized.json in your model zoo directory.
  2. Ensure that the corresponding .hef file (mobilenet_v2_1.0.hef) and the labels file (labels_ILSVRC2012_1000.json) are also present in the same model zoo directory.
  3. Update your Python code to use this new JSON file by specifying the updated model_name and zoo_url.
  4. Simplify your Python code by removing the manual pre-processing and post-processing logic, as PySDK’s built-in handlers now take care of these steps. The simplified code looks like this:
import degirum
# Load the optimized model JSON
    model_name='mobilenet_v2_1.0_optimized',
# Run inference directly on the image
inference_result = model('<path_to_cat_image>')
# Print the results directly
  1. Run the updated code and observe the results. You’ll see that the output is similar to the manually implemented pipeline, but the code is significantly cleaner and easier to maintain.
Benefits of Using Built-in Features
  • Simplified Code: The JSON configuration handles pre-processing and post-processing tasks, reducing boilerplate code in your application.
  • Optimized Performance: Built-in features are implemented in highly optimized C++ for better speed and reliability.
  • Ease of Maintenance: Centralizing logic in the JSON file makes it easier to share and reuse configurations across projects.
With PySDK, you can quickly get models up and running while leveraging its built-in tools to develop complex applications with minimal effort. This guide is just the starting point—explore our PySDK Examples Repo, Hailo Examples Repo, and official documentation to dive deeper into advanced capabilities.
The idea for naming the intro guide as Hailo World was suggested by @Jakob_Tschavoll in HailoRT minimal working example for Python and Hailo8
I’ve just started following your great tutorials.
At first, I couldn’t run this code “as is”. I had to make some modifications as follows.
- import degirum
+ import degirum as dg
checksum to json file.
    "Checksum": "0f140ee8c1bd0be693753a55396772f5f341c7a5f0c39606cd10562284957cbf",
After this, the code runs on my Hailo device with no problem!
@Masahiro_Kisono
Thanks for pointing this out. We realized the error on import line but discourse does not allow edits. Hopefully, people will read your comment below and adjust :slight_smile:
Faced with issue that model couldn’t be find.
degirum.exceptions.DegirumException: Model ‘yolov11s_v1’ is not found in model zoo ‘../hailo_model’
My file strcucture:
  • DeGirum/main.py
  • hailo_model/yolov11s_v1:
    - labels.json
    - yolov11s_v1.hef
    - yolov11s_v1.json
    This is my json file:
“ConfigVersion”: 1,
“DEVICE”: [
“DeviceType”: “HAILO8L”,
“RuntimeAgent”: “HAILORT”,
“SupportedDeviceTypes”: “HAILORT/HAILO8L”
“PRE_PROCESS”: [
“InputType”: “Image”,
“ImageBackend”: “opencv”,
“InputPadMethod”: “stretch”,
“InputResizeMethod”: “bilinear”,
“InputN”: 1,
“InputH”: 640,
“InputW”: 640,
“InputC”: 3,
“InputQuantEn”: true
“MODEL_PARAMETERS”: [
“ModelPath”: “yolov11s_v1.hef”
“POST_PROCESS”: [
“OutputPostprocessType”: “Classification”,
“OutputTopK”: 2,
“OutputNumClasses”: 1,
“OutputClassIDAdjustment”: 1,
“LabelsPath”: “labels.json”
after I changed from @local to localhost I just started receiving:
degirum.exceptions.DegirumException: Unable to connect to server hub.degirum.com: could not get zoo by name ‘yolov11s_v1/info’
@shashi could you help with this?
I am running on Rasberry Pi 5 + AI Kit Hailo 8L
@user131
Please see comment by @Masahiro_Kisono above. You need to add another field in the model json and local inference will work. Please let me know if you still encounter issues.
Can you give me the same steps that i can follow for the face detection using the scrfd_10g.hef
