I’m trying to install the hailo model zoo to compile a trained model and i’m getting this message:
Warning! The current version of the Dataflow Compiler is 3.32.0. Current Hailo-Model-Zoo works best with DFC version 5.0.0. Please consider updating your DFCRunning setup.py develop for hailo_model_zooerror: subprocess-exited-with-error
× python setup.py develop did not run successfully. │ exit code: 1 ╰─> [65 lines of output] Warning! The current version of the Dataflow Compiler is 3.32.0. Current Hailo-Model-Zoo works best with DFC version 5.0.0. Please consider updating your DFC running develop /media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/command/develop.py:41: EasyInstallDeprecationWarning: easy_install command is deprecated. !! ******************************************************************************** Please avoid running ``setup.py`` and ``easy_install``. Instead, use pypa/build, pypa/installer or other standards-based tools. See https://github.com/pypa/setuptools/issues/917 for details. ******************************************************************************** !! easy_install.initialize_options(self) /media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/cmd.py:90: SetuptoolsDeprecationWarning: setup.py install is deprecated. !! ******************************************************************************** Please avoid running ``setup.py`` directly. Instead, use pypa/build, pypa/installer or other standards-based tools. See https://blog.ganssle.io/articles/2021/10/setup-py-deprecated.html for details. ******************************************************************************** !! self.initialize_options() Traceback (most recent call last): File "<string>", line 2, in <module> File "<pip-setuptools-caller>", line 35, in <module> File "/media/ic32k/DATA/Hailo/hailo_model_zoo/setup.py", line 95, in <module> main() File "/media/ic32k/DATA/Hailo/hailo_model_zoo/setup.py", line 78, in main setup( File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/__init__.py", line 117, in setup return distutils.core.setup(**attrs) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup return run_commands(dist) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands dist.run_commands() File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_commands self.run_command(cmd) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/dist.py", line 1104, in run_command super().run_command(command) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1020, in run_command cmd_obj.ensure_finalized() File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 135, in ensure_finalized self.finalize_options() File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/command/develop.py", line 51, in finalize_options easy_install.finalize_options(self) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/command/easy_install.py", line 317, in finalize_options self.set_undefined_options('install_lib', ('install_dir', 'install_dir')) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 320, in set_undefined_options src_cmd_obj.ensure_finalized() File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 135, in ensure_finalized self.finalize_options() File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/command/install_lib.py", line 25, in finalize_options self.set_undefined_options('install',('install_layout','install_layout')) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 323, in set_undefined_options setattr(self, dst_option, getattr(src_cmd_obj, src_option)) File "/media/ic32k/DATA/Hailo/hailo_model_zoo/hailo_dataflow/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 131, in __getattr__ raise AttributeError(attr) AttributeError: install_layout. Did you mean: 'install_platlib'? [end of output] note: This error originates from a subprocess, and is likely not a problem with pip.
But in the Hailo Downloads page there is no Dataflow version 5 available…
